Question about Samsung DualView TL220 Digital Camera
My samsung st500 wont turn on and the lens is open. ive tried some of the solutions suggested but it doesnt work.what do i do now?
    Brigadier General:
  • 3,006 Answers
Your camera has a lens error, but as you haven't said which solutions you've already tried I shall provide you with all of them.
This is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Samsung service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Posted on Oct 02, 2010
  • Michael Snabel Jul 09, 2011
    Hey, i recently dropped my samsung st500 from about 3ft, whilst trying to take a photo of myself, should have used a tripod rather than balance it on a towel rail :(, 2/3 of the rims were slightly bent and a small piece of plastic snapped from somewhere and the barrel was jammed. (stuck out), when switching the camera on, it made quite a high pitched electric motor sound for a second or 2, then made the same sound for another second or 2, then switches itself back off. I opened him up as non of the above methods worked for me. It became clear instantly that the little white cog attatched to the bar with a spring on wasn't seated against the teeth of the other cog, so a man-handled it back into place, and then spent along time trying to figure out how to put the 3 piece barrel back together the right way (as i had to take this apart too to unbend the rims so it wouldn't catch), i eventually got everything back together and hey presto! Works fine! Shame a cracked the screen when repairing it, but its ok, got a replacement screen for £20 from ebay, saved alot of money in the long run though. This job requires gentle hands, and patience, if you are failing, please enjoy a cup of tea and return to camera, you will find that whatever you're trying to do will now work. :)
  • Obertelli
    Obertelli Jul 09, 2011
    Thanks for the comment, Mr.Mike. That's an encouraging and positive contribution and it's good to learn that you fixed it against all the odds. Cups of tea can fix almost anything ;-)
Have a samsung camera that seems to be frozen. The lens is open but there is nothing on the screen. When pushing the power button the power light flashes, the camera makes a beep and the the power light...
Hi, this happened to my Samsung ST500, it took me months to find out what was wrong with it!, i found out the it gets stuck when the lens is different or has dirt in the lens.
  • I Got Mine working by cleaning the lens but if that dosnt work try this, mine started working when i dropped my camera quite high onto the ground which can make your lens pop back in if this dosnt work, try your warranty!:)
Oct 24, 2010 | Samsung DualView TL220 Digital Camera
My Samsung won't turn on :(
Try to move the lens a bit or straighten it out, that usually works when it makes the three beep sounds.
Jul 22, 2009 | Samsung L100 Digital Camera
Doesnt work
ok well first u hold the rest button for 10 seconds then let it charge on a diffrend computer for 4 hours
Mar 24, 2008 | Samsung YP-K3 MP3 Player
Digimax samsung s500 beeps 3 times lens stuck wont stay on
Mine got stuck with lens out. The batteries were new so I never imagined it could be the batteries, but they were cheap ones so I recharged a pair of good ones and once I put tried them on it worked just fine again. Conclusion, the "new" cheap batteries had only enough energy to turn it on and then they couldn't give it enough energy to make it work anymore and that's why I couldn't retract the lens or even turn it off properly. So in your case, try using a couple of good and new batteries.
Dec 14, 2007 | Samsung Digimax S500 Digital Camera
It wont turn on, And the zoom is extended.
I had exactly the same problem. Lens stayed open, when powered on you get three beeps and nothing. I found when I pulled the lens out a little harder it gave a little click. When I powered on it worked perfectly.
Nov 25, 2007 | Samsung Digimax S800 Digital Camera
Frozen camera
your lense is jammed try to put your finger in it and close the lense all the way it might me like hardly closed, i had that problem and now my is open all the way so i cant close it yuo can email me at minimacaluso@yahoo.com or im makaluso06
Jan 26, 2007 | Samsung Digimax S500 Digital Camera
Samsung DualView TL220 Digital Camera Logo
554 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
