Question about Indesit 24 in. IDL500 Built-In Dishwasher
The water decpenser will not spin to clean the dishes
  • Indesit Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
Posted on Oct 02, 2010
Water coming in dishes not getting cleaned enough.possibly not coming out of the sprayer and spin blade
Look inside the spin blade and see if there is food or paper inside of the spin blade exit holes blocking it from spraying and spinning. Also if the spin blade is not aligned with nozzle which sprays water into the blade it will not work. I have had both happen several times. Sometimes dishes or pans pushing against the spray nozzle will also miss align the spray jet so the water does not get into the spin blade. I have also had the spin blade be completely worn and would not spin creating the same problem you've had so I had to replace it. Hope this helps.
Oct 04, 2013 | Maytag Dishwasher
Top rack not cleaning dishes. model # FDB1050RES2
Hello, check the sprayer arm on the top of the dishwasher inside and to see if it spins. Don't block this spray arm with glasses or dishes that could block the operation of this sprayer cleaning arm.
Now, if it not spinning, check out the fitting arount hing bolt. If this wore out then you will have water pressure lose. Replace if need be. Also, check the feeder water spout that runs the upper spray army, it could be pluged. GB...stewbsion
Aug 31, 2011 | Maytag Dishwasher
We have had this dishwasher for approximately 2 years. Dishes do not clean well. For example, I put a mixing bowl in that I just mixed brownie in--and the bowl did not come clean (simply a thick...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Mar 01, 2011 | GE Profile PDW8480JSS Built-in Dishwasher
The top drawer of my FP dishwasher is not cleaning everything properly. The glasses or dishes in the front left side are always dirty and are covered with crumby dried residue when the cycle is complete....
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Feb 20, 2011 | Fisher and Paykel 23 in. DD603H SS...
Dishes are not clean and white residue is left on dishes
clean the filters or get new ones.make sure your water in is connected to the hot water not cold.Also put new rubber O rings on the spinning arm water sockets.
Jul 20, 2010 | Maytag MDB5100A Dishwasher
Asko 1996 appears "dead".....no lights flashing, won't respond to repeatedly pushing on/off button. Some water left in the bottom...siphoned it out, cleaned filters, no blockage there. Almost like it's...
Don't know if this will help, but my dishwasher has a "propeller" device above the top and bottom racks that spins while dispensing the water. If the dishes on either rack are stacked too high (i.e. if even one plate comes in contact with that propeller, keeping it from spinning properly) the dishwasher will go through its full cycle but will not use the soap (soap door will still be closed and soap packet still intact) and will not get the dishes clean.
However, it sounds like you either have a bit of a drain issue as well--or perhaps your dishwasher acts the same way as mine (if that's the case) but ceases to drain as well if blocked.
Jun 26, 2010 | Asko D1996SS Built-in Dishwasher
Dishes not getting clean
Are dishes too greasy!
Check incoming water for free flow
Add correct quantity of soap as per manual. Use dish washer friendly soap. Fill rinse aid liquid in the dispenser meant for it.
Select a different cycle programe and give a try.
May 27, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Will not clean dishes
if there is no water pressure and arms dont spin dishes will not be cleaned so please check the inlet water filter and the arm spinners.
Nov 10, 2009 | Dishwashers
Dishes not clean enough. as if rinsing in dirty
If your dishwasher drains it's water to a garbage disposal, give the disposal a spin while the dishwasher is pumping out. Check around the bottom of the dishwasher to make sure something is not clogging the drain.
May 01, 2009 | Kenmore Dishwashers
Dishwasher not washing
By chance have you cleaned the spray arm out lately? There could be something blogging the water from getting into the arm. In most dishwashers, the arm only spins because water pressure makes it spin.
Miss Midget
Nov 19, 2006 | Frigidaire 24 in. FDB126RB Built-in...
Indesit 24 in. IDL500 Built-In Dishwasher Logo
85 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
