Question about Sony SA-WM40 Subwoofer
When I do a channel test it shows that the sub has a signal going to it but it just hums very quietly when playing a movie.It worked fine until just after we had a power outage.How can I test wether the problem is the amp or the sub?
  • 21 Answers
SOURCE: bridge a two channel amp
i the search bar type in....subwoofer wiring diagram....then go to crutchfield and it shows you your options.......
Posted on Jan 29, 2009
  • 323 Answers
SOURCE: Amp powers on but sub does not come on
I would double-check your RCA's on the amplifier. You should hear a thud if you unplug them. If not they are either not hooked up or defective.
Posted on Feb 08, 2009
RescueTechLA
  • 2653 Answers
SOURCE: ps3 makes loud humming sound while playing blu-ray movies
Try messing with some the of the BD settings.
It's under SETTINGS, VIDEO SETTINGS.
Let me know if this helps.
I can't say exactly which one you need to change and don't worry about messing anything up, you can always just change them back.
Let me know which one fixes your problem.
Best of luck!
Posted on Mar 03, 2009
  • 3 Answers
SOURCE: No sound from Subwoofers after hooking up amp??
you can **** yourself
Posted on Mar 09, 2009
  • 18 Answers
SOURCE: sony xplod amp(XM-1652Z ) power/protect light
if your amp is overheating your sub is needing to much power that the amp doesnt have.
if its cutting out and the red light comes on you need to check the wiring. nothing not even the tinyest speaker wires can be touching.
proper wiring would be your best bet.
but i would upgrade amps.
cheap bang isnt reliable.
Posted on May 27, 2009
Why is there low humming in the receiver sub channel(only?)
Sounds like a shorted capacitor in the sub out circuit.
May 04, 2015 | RCA Audio Players & Recorders
Tvee 20 subwoofer has distinct hum noise. Any advise?
1.Check the input cable or change it and see the result.
2.Test the subwoofer to a computer.
May 29, 2011 | Boston Acoustics TVee Model Two TV...
No signal going to my subwoofer. All other channels work fine. How can I verify if problem is with Pioneer VSX-D912 reciever or my subwoofer?
First, did it EVER work?
No? Review the speaker setup in the receiver and make sure it knows you have a sub and is sending LFE to it.
Yes? Feed it a signal directly from a CD player or something. Start with a quiet sound passage as you probably will have no control of the volume.
If you need help beyond this, name the sub and how it's connected.
Jan 18, 2011 | Audio Players & Recorders
I have a genius SW-HF5.1 5050 audio system.. everything is working when i test it. but when i play any music or movie the subwoofer is not working. The sub is working when i make the speaker test..
Conected via. 6x cinch? Most of audio signals actualy are not 5.1 - so that is IMAO why your sub is not working. Try search your audiodevice control for something like LFE. Or try playing DVD which has 5.1 audio (check player settings).
Nov 24, 2010 | Genius SW-HF5.1 5000 Computer Speakers
Humming sound in subwoofer after it's been playing for a while
It sounds like you are describing an earth loop problem. I won't go into detail in this post, but try an isolation test first. disconnect everything from the reciever except the sub and try connecting say a BATTERY powered mp3 player or cd player to minimise connections to the electrical mains earth. you could also isolate things by taking your sub to a friend's house and trying it on their system.
If it is an earth loop use a process of elimination to find out which two pieces of equipment causes the earth loop. then apply filtering.
you can buy earth loop isolation transformers for about AU$26 and I've used one on my sub myself. Theyhave RCA (phono)plugs on each end and they connect inline with the signal cable to the sub amp.
as for the thumping sound it might be the speaker protection circuitry cutting off the amp to protect the subwoofer speaker from damaged. This might be triggered if the earth loop sound is causing the sub amp to overload and clip.
Failing this there might be a dried out overheated electro capacitor in the amp circuit causing the hum. Hav a chat to your local electronics person, who should be able to spot it!
Hope this puts you on the right track
Happy Hunting!
Jan 07, 2010 | Sunfire Audio Players & Recorders
I've problem getting any Sub sound from Sony STR DB840. The sub is ok and I've correct setting on my reciever with sub enabled. When performing tone test... I can hear sound from all connected speaker...
make sure sub is working .Power it up , remove sub RCA jacks from receiver .Gently tap on RCA with fingers.You should here a hum when touched .You can also try audio from TAPE REC OUT .If you dont get audio .Check setting at sub .If it working okay check setting at receiver and or sub level at receiver
Jul 20, 2009 | Sony STR-DB840 Receiver
Xbox 360 Not Playing LFE Signal
i dont know anyy thing about xbox
Feb 19, 2009 | Microsoft Xbox 360 Console
No surround sound from my Denon 3805
well as long as all signals are routed through the Denon your on the right track, now what else you have to do is connect all devices to the reciever do not loop one device through another. Also you have to try the different surround fields to hear the one you like the best for music I use 5Ch stereo for movies the surround field varies based on the type of movie
Feb 01, 2009 | Denon AVR-3805 Receiver
Left speaker terminal on the sub doesn't work properly
This is common with the type of powered speakers where the IC package that drives the speakers (the amp) is getting to hot and shuts down. Usually it is damaged and not reversable. There is a lot of reports of this same model loosing one channel or playing quietly. The air most likely cooled the chip down until it heats back up.
Jan 15, 2009 | Logitech Z-2300 Computer Speakers
JBL d110 /w no sound output
There is a standby indication that activates after 10-15 minutes without any input signal. I suspect that might be what the red light is telling you - no signal.
Loud hum from a loosened cable is normal as hum usually means there's an ungrounded connection somewhere acting as an antenna and the amp is doing its job to amplify what it thinks is a signal, in this case 60hz stray ac current is being sensed nearby. It's a good sign that you get hum from the sub because that means the amp is alive.
Avoid manipulating cable connections with the Sub or Receiver turned on as you could introduce a static spike that could harm any connected equipment.
Are you certain a bass signal is making it into the sub? The complexities of modern AV receivers vary in how you configure them to direct LFE to a sub. Bone up on that end of the chain.
Or, just hang a CD player on the Inputs of the sub and play something with a reassonable amount of Low Frequencies.
>>>> Be advised that this way of testing has NO VOLUME CONTROL because amps without volume controls always operate at maximum gain, relying on your external controls to attentuate it (hence, the loud hum from a loose cable); so choose a track that eases into the loud parts with some quiet parts up front and BE READY TO PAUSE THE PROGRAM AT ANY SIGNS OF STRESS. <<<<
A living sub will produce only muffled rumble in the absence of other speakers producing the higher frequencies which carry the intelligence of the signal. If that works, back to the receiver for settings. If not... sigh.
For hum problems, even those you cause yourself:
Disconnect all inputs to see if that helps. If it goes away start with the signal cables and add in things until it comes back.
Sometimes the reversing the orientation of the AC plug can help with hum. Or it could be something like a loose or high resistance connection internal to the sub. Good luck.
Jun 17, 2008 | JBL PSW-D110 Speaker
Sony SA-WM40 Subwoofer Logo
101 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
