Question about HP Office Equipment & Supplies
I have an OfficeJet 6200 Series All In One.. Can't close the door and keep getting warning Close Printer Access Door.. can this be repaired easily? Out of warranty
  • 734 Answers
This isn't the answer you want, but I'm giving it.
1. Load that thing immediately into your car and take it to the recycling center
2. Shop carefully and choose new peinter
3. buy the printer
4. Take it home and install it
5. Continue on in life with a little more peace
(that particular model had, shall we say?, issues.
Posted on Oct 02, 2010
Problem with printer or ink system
PDF]HP Officejet Pro X476 and X576 MFP Series ... - Parts Now
www.partsnow.com/.../Officejet%20Pro%20X476%20X5...
Parts Now LLCFigure 2-6 Printer status report-determining genuine HP ink usage . ..... Thesecartridges are linked by flow connections to the rest of the printbar and supply the ink..... The left door can be opened for jam clearance and has a hall effect .... The document feeder will not function when the document feeder cover is open.
db:: 4.32::Printer door will not close after printing 8p - Hivmr
www.hivmr.com/db/8p83f78d97fk8c883x9p9za3mf993scf
On the 50.8 error message, if power cycling doesn't fix the issue you may need to ...Opened printer cartridge access door and removed paper. ... HP Officejet Pro L7580, the latch to the ink cartidges broke, so the door won't close. ... Can not close the printer door on my HP B210a, after cartridge replacement need help?
Re: Do u need Help? -HP All-in-One's(Officejet,Psc's)
www.fixyourownprinter.com/posts/28357
Also, when reinstalling the HP it does print a test page, but will not print from ...Encoder Strip has been cleaned with water (had some ink residue). ..... when opening the door the cartridge does not move to the middle so i can remove it, clean it ...... Iopened the covering part of the scanner (with the glass) nad cleaned all the ...
HP Officejet 6210- repeated ' FixYourOwnPrinter
Dec 28, 2015 | HP Officejet 6600 e-All-in-One -...
On a clx-6200 message says "paper jam 0-c=open/close door. what door is this?
It is telling you that there is a paper jam. Open the door, pull the jammed paper out, close the door, it should clear the message.
Apr 21, 2012 | Samsung CLX 3160fn All-In-One Printer
Close print cartridge access door. It is closed
try to use a pin to click on the switch for the door and see it may be not working
Nov 08, 2009 | HP OfficeJet J4580 All-In-One Laser...
Error message: "Door Open"
HI there,
Follow the steps below:
Step one: Close the print cartridge access door
1.Verify that the print cartridge access door is completely closed. It may appear to be closed, but if it is not completely closed, the error message will display. Verify that there are no obstructions blocking the door.
2.If you are unsure how to close the print cartridge access door on your model, consult your User Guide for more information.
Figure 1: Examples of closing the print cartridge access door (your model may vary)
f3e57be.gif If you have attempted to completely close the access door and the error still appears, there may be a problem with the door sensor and the unit may require service.
Step two: Service your product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Good Luck!!!
neo
Feb 28, 2009 | HP OfficeJet Pro L7580 Color All-in-One...
Rear access panel open
open the rear panel, check all path is clear. close the rear panel, mkae sure that the sides of the rea panel is locked in place. there is micro switch that detect the door panel. if the door is close correctly the micro switch os actived then you will get the error.
Jan 05, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Error - "Close cartidge access door"
By a door edge or  on  a hong extention
Look for a wire going to the the closing edge near thge latch or to a hinge- one of the hinged may have a curved arm  going to a micro switch buried near by
Oct 20, 2007 | HP OfficeJet G55 All-In-One InkJet Printer
Seeker5211
Seeker5211
