Question about Motorola Mobility RAZR V3x Cellular Phone
Set is not getting charged - Motorola Mobility RAZR V3x Cellular Phone
  • 358 Answers
Hi, when a phone does not charge, possible cause forphone not charging is,
: The charger,
and the charging port.
The charger might cause phone not to charge if it is damaged.You can test the charger with another phone if it will charge to confirm if the charger is working.
The charging port can also make phone not to charge, it's located at the low end of the phone where the charger is inserted in the phone.
You can check both to confirm which is faulty.
I think that will help.
Take care.
Posted on Oct 02, 2010
Fast boot & rescue mode
It's a new feature of the TouchPal keyboard app. Open the app, hit the menu, select Settings. Select General Settings and scroll to the bottom where you'll see Boost Charge. Tap it and you'll get another screen where you can change the Boost Charge setting. If you uncheck it, it will disable the Boost Charge function and restore your old charge screen (and your old charging algorithm).
Aug 25, 2017 | Cell Phones
Hi i have a uniden ZO68 i want to add another hand set to this i have brought another uniden ZO68 second hand hand set and i can't set it up can you help me please
did you get the charging base with the hand set
is it a charging base or a base station base
if it is just a charging base , follow the instructions as how to get the base station to recognize the next phone
if it is a base station, probably won't work as you will have 2 base stations trying to work and that will create conflicts
talk with a telephone technician to see what can be done
Oct 30, 2016 | Uniden Lands Phones
My fitbit charge gets stuck on the finishing up step.
I'm having trouble setting up my tracker using ... - Fitbit Help
help.fitbit.com/.../en.../I-m-having-troubles-setting-up-my-tracker
FitbitJul 31, 2015 - I'm having trouble setting up my tracker using my computer ... If you followed the steps in How do I set up my Fitbit tracker on a computer? and couldn't complete ... Your tracker is charged. ... Or, if you'd prefer to get in touch:.
Oct 31, 2015 | Cars & Trucks
My zte sonata 4g won't charge even though the lightning bolt charging sign is on saying its charging. what do I do to get full charge?
Sounds like either it set a memory or the battery is bad. Let the phone totally die and then try to charge. If it want charge then, get a replacement battery
Jan 13, 2015 | ZTE Sonata 4G Aio Wireless
How do I set the settings on my NAPA automatic starter/charger 85-435 to charge my car battery or to try to quick start my car? I have a 1997 VW Cabriolet.
It is best to "trickle charge" a low/dead car battery using the lowest setting. The "jump start" function will probably not have enough juice to start your car by itself. Refer to the manual of your charger for safety precautions.
Oct 03, 2014 | Cars & Trucks
My nokia e5 does not start. i push start button and the power is not coming.
Check your battery , check the adapter voltage. Now connect the adapter to the phone and check the voltage at the battery terminals. Insert the battery and allow the battery to charge for few hours. if the battery/set gets warm it indicates that a charge is flowing .
If the phone does not trigger even after the set charges up or is warm, then it is possible that the mother board has damaged components, Get help, get estimate from Nokia care before you decide.
Jan 18, 2011 | Nokia E5 Cell Phone
Dell HQRP 19.5V charger not charging, idle
Are you using the correct replacement?take the battery out .use a toothbrush ,brush the contacts on the battery and the contacts on the computer try charging again.
good luck
Sep 11, 2009 | Dell HQRP Replacement Laptop AC Adapter
Sony SPP-A946 base unit intermittently charges the hand set.
Clean the contacts on the handset and base that charge the battery.
AL
Mar 17, 2009 | Sony SPP A946 Cordless Phone
Charging the Razor
I would set it for the max timebecuae, when you charge it for shorter times it ruins the battery faster.
Apr 04, 2008 | Motorola Mobility RAZR V3
Phone wont ring during charge
does it charge when its not on charging...if it does then its not the speaker...check the settings because if u press the 1'st button on the left side..it can change the setting for ringer type
Jan 06, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3x Cellular Phone Logo
104 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
