Question about Ryobi 30cc 17" String Trimmer Zrry30530 Wcurve Shaft
How to dismantle a ryoby30cc pbc 3046ye petrolstreammer to replace t he pull cord. the pull cord is stuck and wont turn the motor.
2 Suggested Answers
rwvanlue
  • 486 Answers
SOURCE: My ryobi pbc-3046YE brushcutter wont run.
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
Posted on Nov 10, 2009
Spindle not turning although motor is working fine
The motor drives a heavy duty flexi cable to the head. Get online to a B&D website find your parts list, then ask your B&D agent the likely price of a replacement before you dismantle. It may not be worth it.
Sep 05, 2014 | Black & Decker 14" Grass Hog Xp...
BMW Z4 convertible top opened and now wont close. Motor runs then stops. Latch is stuck and the emergency pull cord will not release. How do I get to the latch to free the top?
try a spray lubricant into the motor mechanism and grease any visable wire cables that run from/to motor ,not the electrical cables the bare wire winder cables,also grease/ lubricate any accessable pivot/hinge points , gently pull the cord and gently push the roof back and forth occasionally trying motor with a bit of patience this should get the roof moving , also look for anything that may be snagging the roof/mechanism as there is a pressure protection system to stop the roof being fully closed on say someones hand so preventing injury
May 03, 2014 | 2004 BMW Z4 Roadster
My kubota motor cord wont turn over when I pull the cord, it is stuck
you need to undo the pull cord spring and check if the spring on the recoil is broken. replace
Sep 30, 2013 | Multiquip Da7000ssa-1 Generator Kubota...
What is the correct oill mixture for Ryobi 30cc pbc 3046ye
Normally it's 2.6 oz per 1 gallon of gas. Purchase the 2 cycle oil with the squeeze top measuring the oz and it gives instructions for the use.
Sep 26, 2012 | Garden
I have a toro personal pace gts self propelled. only model number i foind was 2h802. pull cord broke, would like to know how to replace it
You can buy the whole part...cord,handle,recoil spring all in one piece and remove the old install the new...or you can just buy a legth of pull cord and swap everything over.
First take off the top 4 phillip screws and remove the plastic cover....don't forget to pull off the oil fill cap, next drill out the center of the three pop rivets that hold the recoil spring in place, use a drill bit a little smaller than the rivet, next tap the rivet out using a punch and a hammer, next install the pull chord by first rewindind the coil spring then locking it oin place so it wont twist back and install the new line(pull cord)...next install it on the top of the motor and install 3 new 1/4" aluminumn pop rivets 3/8" long with a pop rivet gun all can be purchased atb Ace Hardware...reinstall the reverse of dismantle proceedure and happy mowing...don't forget to attach the black plastic/rubber pull cord handle.
Happy Mowing!!
Jul 22, 2010 | Toro Garden
Ryobi PBC 3046YE strimmer starts but cuts out when speed control
A lack of acceleration in these units is most likely a fuel delivery related issue. It may possibly be time for a diaghram kit or carb rebuild kit to be installed in your carburetor. Ethanol in the gas deteriorates the parts that accomplish the acceleration procedure and may need to be replaced as they don't function anymore.
Many other things can affect these little machines as well such as clogged air filters, clogged crank case vent, clogged mufflers/exhaust ports./ spark arrestor screens...but more often than not, your problem is a carburetor issue.
Please look at the troubleshooting section on this Zama site PDF file
http://zamacarb.com/pdfs/TechGuide_2007.pdf
Jul 09, 2010 | Ryobi Garden
My ryobi pbc-3046YE brushcutter wont run. When I start with choke it races for a few seconds then cuts out, if I get it started without choke it idles briefly then cuts out, if I try to accelerate it cuts...
1) spark plug
Remove Carburetor
Nov 09, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Power Washer will not start - pull cord seems to be stuck
hi take out the bolts holding the compleat pull starter remove unit pull the cord if it wont move something is jamming it inside if it is ok then the fault is with the motor //seized or washer remove washer pump if engine turns over /pump seized the fault is 1 of the three you have now found out wich 1 starter, motor or pump it will take too long to go over all 3 get back when you have got this far merlinv12
Aug 22, 2009 | Honda Maxus Pressure Washer MX5222
Stuck Camera
Dismantle and free the lens,
pull it oppen,
shake it for the motor to engage.
send it to Kodak for replacement.
Vitally
May 18, 2009 | Kodak EASYSHARE M1063 Digital Camera
Ryobi 30cc 17" String Trimmer Zrry30530 Wcurve Shaft Logo
135 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
