Question about Xantrex Technology Heart Xar 12 Alternator Regulater
How to change alternator on a citroen zx aura
Change alternator belt
ZXR 750 alternator belt change - ZX Forums
www.zxforums.com/.../zx-7r.../37625-zxr-750-alternator-belt-change.ht...Jun 3, 2010 - Hey there is no belt the bike just had a seperate alternator like the early zx9's and it fits the engine and is driven by a gear off the crankshaft so ... Alternator belt adjustment on 1989 zx7 - ZX Forums
Apr 28, 2015
H-model alternator belt adjusting. - ZX Forums
Sep 21, 2012
89 zx-7 Engine Options - ZX Forums
Feb 29, 2012
1990 zx750r - ZX Forums
Oct 11, 2011
More results from www.zxforums.com
kawasaki diagram replacing alternator belt Questions ...
www.fixya.com/tags/diagram_replacing_alternator_belt/browse/kawasaki
kawasaki diagram replacing alternator belt related problems. ... ZXR750 H1/H2 - need above to find if bike has rectifier/regulator, to run continuity test on it, ..
Sep 06, 2015 | kawasaki ZXR 750 Motorcycles
I have a citroen Aura the indicators don't always work. Any suggestions
Check the ground cables. Depending on the model there can be several ground points. You will need a manual to show yo where they all are. A ground can look okay, but if you remove it there often will be hidden corrosion. Clean, grease and use correct torque when refitting.
Oct 20, 2014 | Citroen Cars & Trucks
My indicators don't always work. I have a citroen aura
sounds like earth fault get it checked out by a auto electrician , will save you a lot of time
Oct 20, 2014 | Cars & Trucks
Intermitten start problem citroen zx
hi there guys, my td zx wvo ; all good over one year, but now starts but do not switch off??? helpanyone
Nov 04, 2012 | Cars & Trucks
Security code panel Citroen ZX
I have a problem with my security code panel for the ignition on my Citroen ZX.Having put in the number the red and green lights BOTH stay on and it won't start.Can anyone help please to help me reset it? Or could some kind person email me a copy of the pages in the driver's manual as I've lost mine? Thank you very much.
Jan 16, 2010 | Vehicle Parts & Accessories
How hard is it to change alternator and thermostat on a 2007 Saturn Aura
Those are both hardy parts that should last close to 100,000 miles, but if you need to replace them it's not real difficult, especially since there's plenty of room under the hood. The alternator is a matter of 3 or 4 bolts. Remove the plug-in wire harness from the alternator, loosen the adjuster bolt to take tension off the belt, then remove the mounting bolts and pull the alternator. Reverse the steps for the install. For the thermostat, follow the upper radiator hose to the point where it enters the engine. The hose is connected to a metal housing that's bolted to the engine. Unbolt the housing from the engine to expose the thermostat. Lift the thermostat out, remove all traces of gasket from the housing and engine, then install the new thermostat and gasket.
Dec 29, 2009 | 2007 Saturn Aura XR Sedan
Citroen zx relfex 1.9d
try changing the glow plug relay box located to the side of the battery ... easy fix if not then maybe a solenoid
Mar 31, 2009 | Peugeot 505 Cars & Trucks
Citroen zx immobiliser
dont know how to do it, sorry, but same thing happened on mother-in-laws car, mechanic just by-passed immobiliser, cheaper than new parts and loads of labour charges. Good luck
Oct 24, 2008 | Peugeot 505 Cars & Trucks
Xantrex Technology Heart Xar 12 Alternator Regulater Logo
90 people viewed this question
Top Xantrex Technology Boating Experts
Tre Elkins
Steve
Steve
Are you a Xantrex Technology Boating Expert? Answer questions, earn points and help others
