Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
My Flyback is burned, questions!
So I opened the back of my D52GW12 and like everyone else, my Flyback is burned. Is this a difficult part to replace myself. My father knows how to solder, but not very small points. Does this thing have small points or big points to solder?
Also, how do you get the board out of the TV? I can see all the ribbon cables can be disconnected, but the cables going out of the top of the flyback don't seem to be detachable.
I was looking through the other problems like this, and I remember I read something about a horizontal transistor that goes bad when this happens, but I can not find that again.
I have had this TV for about 3 years.
Thanks in advance!
  • 1 more comment
  • peterfares May 26, 2008
    What about the horizontal transistor? Should I worry about that? Do I need to buy something to replace it?
    How long will the TV hold a charge for after it is disconnected from the wall? It has been out for a a couple hours. Is there any way to drain the charge quickly?
    How do I remove the wires from the flyback? Am i supposed to cut them and solder them onto the new one, or do the new ones come with wires?
  • 975 Answers
Is not difficult to replace if you have some electronics knowledge and your very handy with tools, first your gonna need a DESOLDERING TOOL , makes the job easier to remove the solder points ( this flyback your replacing have big points) .
I suggest before removing the PC BOARD to take a photo of the board w/ a digital camera , in case you get confused when connecting all the ribbon cables and plugs . know your way around when starting to take the board out . about the FLYBACK long cable that goes up, it could be solder , this is the main FLYBACK that feeds all three color guns .
and about the HORIZONTAL transistor , I suggest to replace it
its not expensive , the HORIZONTAL transistor is usually located near around the flyback , look for a black square with
three legs attached to a metal wall (acts like a heatsink).
hope this information is helpful , AJ
Posted on May 26, 2008
  • ALBERT GARCIA
    ALBERT GARCIA May 26, 2008
    YES !! You need to replace the horizontal transistor , also buy a HEAT SINK creme ,it comes like a tiny toothpaste like ,
    To drain any charge left , your gonna need like a long screwdriver to ground the red cable of the flyback
  • ALBERT GARCIA
    NEW ONE COMES WITH THE WIRES !!!!
    Scholar:
  • 131 Answers
Hi,here is the basic setup you are correct you will need to replace the horz output transistor located near the flyback.
you could replace the fly back but it is hard to un solder..
the board. The ribbon can do disconnect but be careful.
flyback diconnection first check the small red wire follow that it is connected to screen adjustments on the front in most cases you will have to disconnect
the front grill pulls out or there are screws you will see a little black box with pots on it the lead go to that. please be careful this is high voltage and even disconnected it hold a charge. Know you need to disconnect the fat thicker red lead. that gos to a splitter near the
back
it pulls out twist first then pull out becareful it is trickey and could break.
You could have a repair shop look at and give you estimate on job. see how much they charge for estimate .
parts places www.partstore.com
www.mcmelectronics.com
good luck doctor video
  • GE Master
  • 8,617 Answers
You can get the flyback at the following link and they will provide free tech support to help you with it as well as instant messageing tech support to help you remove the board and the Flyback wires. Its a very easy repair and it doesnt require fine detail soldering what so ever. You need flyback 259296 they will also answer any question you have by leaving them an email. heres the link.
http://servicemanuals.vstore.ca/
  • Sonny Berry
    Sonny Berry May 26, 2008
    I would leave that site and email and they can tell you which HOT transistor you need, but most times if the flyback is burned from arching the HOT will most likely be good, but they are only a couple dollars so you may want to change that as well.
  • Sonny Berry
    the wires will pull out of your old flyback. It takes alot of force but they will come out new flybacks for projection units dont have new wires you have to reinstall the origional wires into the new flyback. The flyback wont have a charge to it just the capacitors and the CRTs do but the flyback wont have any charge in it.
D52gw12 flyback replacement
Board has to be removed and flyback disconnected and then all pins unsoldered.
May 24, 2012 | GE D52GW12 52" Rear Projection HDTV-Ready...
Where exactly are the convergence amps?
THIS TV DOESNT HAVE ANY CONVERGENCE AMPS IT USES ABOUT 20 TRANSISTORS TO DO THE SAME JOB. YOUR PROBLEM WILL BE CRACKED SOLDER ON THE FLYBACK TRANSFORMER AND ONE OF THE FUSES THAT LOOK LIKE LITTLE RED BOXES NEXT TO THE FLYBACK WILL BE BAD(OPEN). RESOLDER THE FLYBACK AND REPLACE THE FUSE AND YOU WILL BE GOOD TO GO.
Dec 16, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
THE TV WENT POP, SPARKED AND WENT OFF COULD IT BE THE BULBS AND IF SO WHAT DO THEY COST ABOUT
the flyback or CL031 are the usual causes with that chassis doing that. Usually CL031 will burn a hole through the deflection board its located about two inches in front of the Flyback transformer.
Mar 15, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
Need flyback for GE D52GW12
Tries Tv repair World.com,Ebay.com for the Flyback transformer.
Mar 06, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
Look at the flyback coil
Very easy repair. Heres alink to the flyback for your model which comes with step by step instructions with pictures on how to replace it.
http://servicemanuals.vstore.ca/product_info.php/pName/265409/cName/flybacks
Jun 14, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Same problem. GE Model #D52GW12 Working fine then just caught on fire. Removed the back and found a part that said "Focus and Screen" on it. Can this be replaced or do you have to replace the circuit...
the flyback... very common for the ge version of the rca it222 you may also have to replace the horizontal output transistor. i have found at the shop the flyback and the transistor ussally all that have to replace
Apr 29, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Which flyback should I get and from where?
You will need the 259296 Flyback and the Horizontal output (HOT) is a 2SC5588 You can get both parts at the following link and they provide free step by step instructions on how to do the repair. Heres the link
Apr 22, 2009 | Televison & Video
GE D52GW12, picture is distorted and snaps
its either the HV splitter or the flyback which needs replacement. You can get both items at the following link with free instructions.
Mar 26, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
52" GE tv problem
sounds like the flyback, That model is famous for thr flybacks burning through. If it is indeed the flyback thats a repair which is easy and you could do it yourself for under 50.00 Go to the following link leave them a email with your model number and sympton they have your flyback for less than 50.00 with free shipping and free tech support. Your model uses flyback number 265409
here is the link.
Jun 28, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
Ge d52gw12
Maybe you can replace the flyback?? if you can solder then give it a shot. get the manual and more help here http://servicemanuals.vstore.ca/
Feb 13, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
224 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
