Question about Dewalt DW618 Router
Dewalt 625E-LX vriable speed control will only work up to setting 3 , i have bought a new speed control unit but the fault is still there
2 Suggested Answers
yasinabdirah
  • 22 Answers
SOURCE: Dewalt D25601. Red service Light flashing after 3 seconds.
Return o the store
Posted on Mar 05, 2014
Testimonial: "Thanks for the tip but I am the repair agent just waiting for Dewalt to get back to me as the engineer I spoke with had not dealt with breakers for a long time."
I have a Dewalt 625e type 2 router which just quit working. I replaced the switch and the PC board but it still doesn't run.
Check both brushes. Some DeWalt brushes have a spring loaded plastic pin built into them so when it wears down the pin pops out and prevents damage to the armature. Other brushes have a copper wire that, when the brush wears to a certan point, it will no longer touch the armature again preventing damage to the armature.
Dec 07, 2012 | Tools & Hardware - Others
Technics SL B210 - New belt, but still "plays up" on 45rpm I bought and installed a new belt, which worked fine, but after a couple of months of not using it, I now find that I have to run the...
Do on thing Oppen the Turntable and replace the 5 electrolytic capacitor ( 330mfd 16V,3.3Mfd 25V, two 2.2mfd 25V and 47mfd25v )in the circuit board. Also try to replace the 2 Vriable resistor ( 2K and 5K) in the circuit board of which one is for setting the speed of 33.33 and another for 45 rpm. If you need the srevice manual then just get in to the following link. You have to wait for some time until you will get a notification that Get the manual.
Ajin
Service manual
Feb 27, 2012 | Technics Audio Players & Recorders
Do on thing Oppen the Turntable and replace the 5 electrolytic capacitor ( 330mfd 16V,3.3Mfd 25V, two 2.2mfd 25V and 47mfd25v )in the circuit board. Also try to replace the 2 Vriable resistor ( 2K and 5K) in the circuit board of which one is for setting the speed of 33.33 and another for 45 rpm. If you need the service manual then just get in to the following link. You have to wait for some time until you will get a notification that Get the manual.
Ajin
Service manual
Feb 27, 2012 | Technics SL-DZ1200 Turntable
I bought a new dewalt hammer drill and i love it but when you use the number 1 speed it just clicks and smells hot once and a while it will work and when it works it works good its just getting it to work....
Hello. In the gear mechanism they use planetary gear set to get the torque they need to operate this hammer drill. What has happen is the gears are made of heavy duty type of PVC. Why, some how it strip off the teeth on some these gears and the only thing is work is electric motor moving broken gear around in that planetary gear housing.
Take it back where you bought this Dewalt drill and ask for a replacement. GB...stewbison
Sep 09, 2011 | Dewalt 18 Volt Compact Drill Kit
Just stopped working completely no power
This is an excellent tool, I have 3 myself and I've had similar issues. Here are a few things you can try.
1. Dewalt seems to have a glitch in the speed control slide on the top. I say this because with two of my drills I sometimes have to slide it from low speed to high, and then back again to get it to engauge.
2. I have also had to clean the contact points in the charger, as well as the ones on the drill.
I hope one of these will help resolve your issue.
Jan 27, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
Hi my dewalt 708 lx sliding mitre saw, 110v, seems to only have half the power(speed) that it should have, and cannot cut timber on a compound cut because of this, any suggestions please.
I have heard complaints that this saw does not do well on angled cuts because of its low power. Try running a shorter and/or thicker extension cord and checking your input voltage. That's about all I can think of, hope it helps.
Mar 12, 2010 | Dewalt D51321 3/4" 1 3/4" Heavy Duty Coil...
Clutch and speed selector problems
drill needs transmission and switch probably co'z it's loosing the varaible speed.
Jan 19, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt DW618 Router Logo
160 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
