Question about Nokia 1650 Cell Phone
Appreciate u interested...nokia 1650 when connected to pc via USB connection not working eg .applicatio sofetware not working
    Problem Solver:
  • 16 Answers
TRY DOWNLOADING THE LATEST VERSION OF NOKIA PC SUITE AS WELL AS THEW DRIVER FOR THE USB CABLE MODEL YOU ARE USING.
http://www.nokiausa.com/get-support-and-software/software/nokia-pc-suites/compatibility-and-download
http://nds1.nokia.com/files/support/global/phones/software/Nokia_Con_cable_driver_installation_en.pdf
Posted on Oct 02, 2010
How to connect internet on pc with nokia 1650
I don't see anything that indicates you can use it as a tethered device on a data plan via usb or bluetooth. You'll have to contact your service provider to confirm it you can or not.
Apr 12, 2011 | Nokia 1650 Cell Phone
Sir when i am connect my nokia2626 mobile phone to pc via nokia pc suit when it's not work correctly and the main proble is that when i want to connect my pc to internet using my phone then message shows...
Hi!
You have to select the mode of connection.. through blutooth or by usb data cable.
If by blutooth, you have to stable the pairing of the phone and the pc.. You also need to make sure that your phone has already the settings that your phone provider has sent you to access by phone.. If you can access the net from your phone then its ok to surf internet on your pc via phone as your model.
You also will need to set your phone as your modem.. how? go to control panel and select Phone and Modem, there set up the phone as modem.
If this things are done, then go with your pc suit again and try connecting.
If you are trying to connect via usb data cable.. you will need first to install the driver of your cable before you can start pairing your phone to your pc via pc suit.
I hope i gave you a better idea with that.
Much appreciated if you could rate this help. Thanks
May 19, 2010 | Computers & Internet
How can i connect my nokia 5130c with pc via data
THERE IS TWO PROCESS FOR CONNECTING THE NOKIA 5130 EXPRESS MUSIC PHONE.
1 U CAN CONNECT IDRECTLY WITH DATA CABLE AS A USB DEVICE.
2 U CAN CONNECT UR PHONE WITH PC VIA NOKIA PC SUITE SOFTWARE WHICH CAN BE DOWNLOAD FROM NOKIA WEBSITE.
AFTER INSTALLING THE SOFTWARE, U WILL BE ABLE TO CONNECT THE PHONE VIA DATA CABLE.
I HOPE U WILL GET THE SOLUTION.
Nov 12, 2009 | Nokia 5130 Cellular Phone
Nokia 1650 Firmware Update
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Updating Nokia Mobile Phone Firmware Here I’ll tell you the things you need to do in order to update the embedded firmware in your Nokia cell phone.
Things to do before a firmware update:
  1. Install Nokia PC Suite, and back up all the stuff from your phone to your computer.
  2. Charge your phone battery to its full level.
  3. Beware that any hindrance (like power off, etc.) during the update process can damage your phone.
Let’s get started.
  1. In your Nokia mobile phone, type in *#0000#
    Your Nokia mobile will now display the firmware version it’s running
  2. Carefully open the back case of your mobile, and also take away the battery.
  3. Note the product number down
  4. Go here and type the product number. You’ll now know if a new version of firmware for your Nokia mobile phone is available
  5. Download the Nokia Software Updater. Click here to download it
  6. Install the Nokia Software Updater (I think it’s recommended to run it if you have more than 256 MB of RAM on your computer)
  7. Connect your Nokia mobile phone via the USB port, and also make sure your computer is connected to the internet
  8. Run the Nokia Software Updater by clicking on the icon on your desktop
  9. The Nokia Software Updater connects to the internet, checks for updates, and then detects your phone to start installing firmware updates for your Nokia phone
  10. You might see some fuzzy things going on in your Nokia phone, and that’s perfectly normal to happen during a firmware update
  11. When all’s done, the updater gives a confirmation message and then the phone restarts
  12. You can now disconnect the phone from the computer
That’s how you upgrade your Nokia mobile phone’s firmware. Let me know in the comments if you have any question.
Oct 21, 2009 | Nokia 1650 Cell Phone
My laptop does not recognize my n97 when connected via usb
Have had many similar issue with Nokia phones & PC Suite connections - works fine then stops - in add remove programs there is an entry called PC Connectivty Solution - it does not say Nokia unless you go change then it says Nokia - remove this, the Nokia suite & Nokia Connectivity Cable Driver - restart PC, switch off phone, remove battery, switch on, reinstall and it should work.
Good luck.
Oct 14, 2009 | Nokia N97 Cell Phone
I can't transfer datas from PC to nokia 7210
try to reinstall the software...sometimes taking it out and in again works.
Aug 16, 2009 | Nokia 7210
Connection 6288 to PC
hey me too hv 6288 and just now i updated wid 6.43 furmware...u just take ur usb cable(DKU-2 or CA53)and update ur latest nokia pc suite in dat there is a option of updating software try from pc suite ur problem will get solved but dont try to update ur phone through nokia website...u will not get success from their.
May 17, 2009 | Nokia 6280 Cellular Phone
Connecting problem
you have to check to see if you got the right cable to connect your neukia with, there are 2 kinds, if you have 6610 then you need a different cable then if you have 6610i.
Sep 08, 2008 | Nokia 6610i Cellular Phone
My Mobile has a Powering problem and it doesn`t work because it was connected to my PC via USB and disconnected suddenly
contact nokia or a local phone shop to find out where to get it repaired.
www.nokia.com
You can try removeing the battery for 30minutes and trying again.
Jul 26, 2008 | Nokia N73 Cellular Phone
Nokia 1650 Cell Phone Logo
107 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
