Question about Casio Watches
Bagaimana cara mengatur waktu jam tangan C-k33R1-1
My Dunhill watch is working but it’s second hand is not moving. What’s happening?
Sounds like the second hand is jammed up, if you give it a bit of a tap it should get it moving again.
Nov 17, 2017 | Dunhill Watches
The hour hand on my grandfather clock is floppy after pushing it back to alter time and just falls to 6 oclock
Push it firmly towards the clock. Usually they are just a friction fit and if you push it, it will jam back onto the shaft.
May 18, 2016 | Watches
Animal jam diamond code
Under watches? No not here...
Jul 24, 2014 | Bulova Diamond Watches
It's a 3 key chime and strike clock that chimes every 15 min and strikes hours. for last one month it doesn't chime at 12, 3, 6, and 9 position and the hour strike is not synchronous with min hand
More than likely, there are springs that activate the levers for it to chime, or bong, they may have got jammed up, you can open it up, and see if you see anything like that, if not, you will have to take it to your local jewelry store, or watch/clock makers to have them take a look. You never indicated what type of clock (make or model) so I can\'t be certain. Maybe a ships clock? They may want to charge you for a overhaul of the movement, but you can tell them to just "make it work" if it was running fine before (keeping time well) then an overhaul probably isn\'t necessary. It sounds like something may have got jammed.
I hope this helps !
Nov 16, 2013 | Watches
The illumination button on my Newton is jammed and I can't get it to light up
mcdevito75 Here, The button may be jammed on the inside of the watch, the tab the button rests on inside the watch may have slipped, in this case the back of the watch must be removed then see the tab and affected button. Best Bet, look for a small watch repair shop in your area have them do this job. Unless your very familiar with watches you can easily destroy your watch even with too much hand or finger pressure, let a shop check it out for you.
Feb 09, 2011 | Nixon Newton Red Wrist Watch
Stopwatch second hand stops/jams at 57 seconds point jamming the whole works. Watch stops. Keeps excellent time otherwise if stopwatch not used. 2003 ss model. Bought new from rolex.
This may sound obvious but it needs to be repaired by a jeweler/watch repair shop. Although it is possible that the stop watch second hand is out of sync it would usually mean that the stop watch is starting at 3 seconds before 00:00 for 57 stop. If that's the case you should be able to readjust the start/stop position by pulling the crown out to 1st or 2nd position and then pressing the stop watch start stop buttons. One press, one position. Although I am not certain of the exact sequence.
However if you are unsure or it starts at the 00:00 position you need to find a jeweler you can trust to do the work. Check out a few places and ask to see the credentials of the watch repair person then compare and make an informed decision. Don't just use the jeweler at purchase point.
Most times, if it's a simple repair, like readjusting the hands a good jeweler will do it for nothing.
Good luck
May 14, 2010 | Rolex Daytona 116520 Wrist Watch
Stopwatch second hand stops/jams at 57 seconds point, jamming the whole works. watch stops. keeps excellent time otherwise if stopwatch not used. 2003 SS model. bought new from rolex.
this watch will need a service from a rolex trained repairer wich wont be cheap 700 dollars min or 500uk pounds min..you could try tapping watch in palm of hand to see if a batton or luminous paint has come loose,then all it needs is movement taking out and blown clean inside case.any decent repairer can do this.sometimes the teeth on a wheel can wear in one place hence it always stops in same place.recomend service as best action,you never loose on a rolex...
Mar 26, 2010 | Rolex Daytona 116520 Wrist Watch
Bottom base plate loose damaged after they fitted new battery
It could be that the seal is not seated properly and that is was just "jammed" into place.re-open and make sure the seal is not pinched or placed/seated wrong.Bring it back.
Mar 25, 2010 | Watches
How often do you need to wind up a watch, and do you just turn it in one direction/
Its advisable to wind up the watch at least once 15 days to make sure none of the spares inside doesn't get jammed.
Usually, its just one direction, clock-wise! :-)
Sep 07, 2009 | Watches
Watches Logo
189 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
