Question about GE Dishwashers
Dishes are not clean after cycle. Soap dispenser opens but leaves soap residue in dispenser and on the dishes. Food particles in the bottom of the dishwasher. Is there a filter that needs to be cleaned out and if so, where is it?
  • Anonymous Mar 15, 2014
    dishwasher manual dispenser won't open for cleaning cycle
  • GE Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
Posted on Oct 02, 2010
Model GSD2100R00BB - the soap dispenser opens and the arm extends but the dishes do not get clean, just wet and does not leave soap residue on the dishes.
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Aug 28, 2011 | GE Dishwashers
My office's GE QuietPower 3 dishwasher detergent
heatman101
Jul 29, 2011 | Maytag Dishwasher
Hi. My problem is with my dishwasher detergent dispenser. It does open (at least it is open at completion of cleaning cycle), appears to deliver soap to dishes (as they appear clean), however, from the...
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
heatman101
Feb 14, 2011 | Maytag MDBH985AWB / MDBH985AWS 24 in....
Soap does not disolve and residue left on all
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Jan 17, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwasher not washing and leaving residue on dishes
We have the same problem with the soap dish. I found that we have to be careful how the dishes are in the bottom rack. Sometimes the dishes will block the cover on the soap dispenser and keep it from opening.
Jul 12, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
OLD KITCHENAIDE MODEL KDI-20 LEAVES SOAP GRANULES ON DISHES.
I have this same problem, plus the pre-wash soap dispenser doesn't open sometimes even though a service guy replaced that. Could he have replaced just one side and not the other? this dishwasher also has a new motor. sometimes it washes beautifully. but other times it does not. even if both dispensers opened.
Dec 04, 2008 | KitchenAid Dishwashers
Dishwasher does not clean. soap door does not open every time.
Well the 2nd part of your question is probably the the reason it doesn't clean. If the soap door doesn't open then the dishes will probably not be cleaned. So.. I would focus on why the door doesn't open first.. is it sticking from old soap residue? If so, clean the dispenser with white vinegar and cycle it a few times without detergent and use the hottest/sanitary setting.. Then make sure you are using an approved dishwashing detergent for yuour wash cycle. Add some detergent to the dispenser and try cycling it without any dishes .. does the door open? If no, then you need to resolve that first.. If it does open, try running a cycle with about 1/2 the normal dish load and see if the door opened and the dishes came out clean.. Routinely, check and clean the drain filter so you aren't redistributing the food sediment from the previous load all over the next load of dishes.. Hope that helps..
Sep 06, 2008 | Kenmore 24 in. 16009 Built-in Dishwasher
Dishwasher Issues
I would try using a different soap or less of your current soap.
Jun 21, 2008 | Maytag 24 in. MDB4100 Built-in Dishwasher
Dishwasher
If you are you using a liquid soap or packets that will be the main problem.If your unit fills with water circulates the water and drains the water,and also heaters are working then you probally need to change to cascade powder soap.The film on the dishes is soap.The unit has so much build up in it that when it gets to the rinse cycle it is rinsing dishes with soapy water.You need to get 2 medium bowls fill both 2/3 up with white vinager,place one in upper rack and one in lower rack and run unit on longest cycle letting the vinager splash out during wash.do this with no soap and no dishes.Having soft water will allow you to use less soap.
Apr 23, 2008 | Dishwashers
Dishwashers Logo
131 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
