Question about Canon Cameras
The camera switches on but the lens will not open ,the lcd comes on . Any help would be of great help
    Brigadier General:
  • 3,006 Answers
This is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Canon service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Posted on Oct 02, 2010
PROBLEM WITH LENS/ LCD SCREEN
problem with the lens,not with the lcd,the image fomation is bad,so replace the C.C.D
Mar 05, 2010 | Sony Cyber-Shot DSC-H1 Digital Camera
When I try to turn on camera it makes funny noises, the lens tries to come out and open but seems to be stuck, after a couple of attempts it stops and turns off, What can i do
My Olympus Camera when switched on the lens comes out and in 4-6 times then it goes off without the LCD screen showing anything, please help me repair it. my address misiani_bon@yahoo.com
Aug 24, 2009 | Olympus FE-280 Digital Camera
Lens wont open cannot take photos
You have the camera in REVIEW mode... your model either has a a switch on the rear panel to select taking photos OR reviewing. Or it may have a button, but it sounds like yours has the swith type...just flip the switch to the opposite direction and try it... the lens should act normally and allow photos to be taken...LET me know what you find out..
KEN
Apr 20, 2009 | Canon PowerShot A520 Digital Camera
Canon EOS Rebel XS turns on, but nothing else works!
Take the lens off and the CF card out. Just with the battery in, see if the display works. If not, could be a faulty camera. If it does, switch off, insert the CF card, switch on. Do you see the display now? If not, CF may be faulty, replace it. If it does, switch off, add the lens, switch on. Does the display come on now? If so, looks like it is fixed, if not, looks like the lens is faulty - try removing the lens and cleaning the contacts on the lens and the camera body with a pencil eraser, do not let any debris fall into the camera body (hold it opening down is best).
Apr 12, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Problem at switch on
The problem was caused by fine particles getting trapped between the sections of the lens. I tore off a thin strip of paper and wrapped it around the inner barrel of the lens. By rotating the paper, I dislodged the particles, switched on and the camera functioned normally.
Mar 22, 2009 | Kodak EASYSHARE M1063 Digital Camera
Lens error,restart camera
take your finger and slide it inside the lens and pull it out slightly, not all the way but enough that it moves. then hit the power button and it should work fine after that. good luck!
Nov 23, 2008 | Canon PowerShot SX100 IS Digital Camera
"Cover Is Not Open" And The "Lens Cover" Is Open...
the lens cover switch of your camera have a poor contact that why that message is appearing...you have no choice but to disassemble the camera for repairing or cleaning that switch....i suggest you have to go the service center now and don't try open your camera if you are not a technician cause you may damage the flexwire of the lcd monitor if you not properly remove the cover...
Aug 30, 2007 | Sony Handycam DCR-HC21 Mini DV Digital...
Nikon D50 Lens won't work
I have a D50 as well but never experienced this problem. One thing to check as you already mentioned are the metal connections between the lens and the camera body. Make sure they're clean and shiny. Another thing to try would be switching between AF and MF modes on the lens itself.
Jul 02, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
BLANK LCD SCREEN
The shutter in the lens is stuck closed. You need to take the camera to a shop where they will replace the lens assembly.
Nov 25, 2006 | Olympus Camedia D-580 / C-460 Digital...
Zoom lens jammed
this is a protection mechanism against further damage when the zoom/lens mechanism is obstructed. It's a very delicate mechanism, and it's not easy or cheap to fix. The gears probably got misaligned or broken when you dropped the camera. You should get a repair estimate, and only if you decide you'd rather trash it try opening it up again. Good luck
Jun 22, 2006 | Samsung Digimax 420 Digital Camera
Cameras Logo
22 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
