Question about Samsung CLX 3160fn All-In-One Printer
Printing too dark - Samsung CLX 3160fn All-In-One Printer
  • 33 Answers
The toner cartridge may not be installed
properly. Remove the cartridge and reinsert it.
? The toner cartridge may be defective and
need replacing. Remove the toner and install new one.
Posted on Oct 03, 2010
C451 prints too dark
copies or prints to dark or both????
Mar 24, 2014 | Konica Minolta Office Equipment & Supplies
Ir 3300 the print out is dark
keep the develop setting between -30 to +30.If the image is too dark then chck the toner you are using as in most case it is the culprit.
Apr 19, 2012 | Office Equipment & Supplies
I need to lighten print on my richo2210L fax machine
To adjust the contrast, Press Darkness. Each time you press the button, the LED labeled with the selected mode turns on. You can choose from the following darkness modes:
1>Lighten: works well with dark print.
2>Normal: works well with standard typed or printed documents.
3>Darken: works well with light print or faint pencil markings.
Dec 07, 2011 | Office Equipment & Supplies
Print is to light. How do I get it to print darker
there is a option u can do it dark and light,,,
press dark or light botton, than its gives u dark print ,,
if there is ok than change your cartridge,
May 04, 2010 | HP Officejet 5610 All-In-One InkJet...
Dark print out
check the fuser... to see if one of the rollers has toner all over it... then check your paper path... to see if you see any obvious signs... then try printing 20 pages and opening the copier at various times during the printout process... you want to see if you can catch it where the dark starts appearing... chances are where it starts... is right next to the bad part... you are looking for a print out with one half no dark and the other half real dark...
Dec 16, 2009 | Canon NP 6035 Copier
Zebra Z4MPlus not printing dark enough
In your label software there should be a setting option for print darkness (I assume it adjusts the head temperature) In ours (bartender) you can get to it when you select 'print' and a window appears with a 'documents properties' button. Click on this and select options and a darkness bar appears which you can adjust. You may also need to slow the label print speed if the darkness adjustment is not enough. I suspect it isn't in the printers best interest to run the print head at maximum darkness/heat so a sensible balance of darkness and print speed is best.
Another, less likely, possibility is an incompatability between the label material or surface finish, and the ribbon type. We did have a problem once whem Homebase changed their price label design and we had to test a load of other ribbon types until we got one that did the job. A chat with the label or ribbon supplier is always usefull, they sent us several sample bits to test.
Sep 30, 2009 | Zebra Z4Mplus Label Printer
Printer not printing dark enough
go to the print settings select the dark scale
u can get print darker than the previous
May 27, 2009 | Samsung CLX 3160fn All-In-One Printer
My ink prints too dark is there an adjustment on the printer
yes.there is a adjust ment.go to printer properties and there printing preferences and there adjust the print quality to normal which is set on beat mode so the prints are comming extra dark.
Dec 11, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Can't save the printer darkness in the printer
go to printer driver properties.. 1.click printing preferences set it to USE PRINTER CONFIGURATION 2.go to advance click Printing Defaults set it to USE PRINTER CONFIGURATION
you must set this two configuration note: fresh installed driver defaulth to software control
Oct 14, 2008 | Zebra Z4Mplus Label Printer
Dark streaks
Dark streaks are an indication of "burned" or overheated ink. This will occur when the printer sets for a long period of time and nothing is printed. The problem will usually disappear after 50 pages or so, unless the printhead is damaged.
If the print remains dark, the printhead will need replaced.
(Very expensive)
(Dark print can also be caused by using Non-Xerox ink)
Sep 10, 2008 | Xerox Phaser 8400 Laser Printer
Samsung CLX 3160fn All-In-One Printer Logo
53 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
