Question about Parkinson Cowan SG340 Gas Kitchen Range
Oven failure Have this oven 10 years. Suddenly this evening about one hour after using the grill the cooker is "dead". No time in the display, and no gas coming in when the knob is turned to either grill or oven. Nothing on bottom oven either. Have checked fuse board - all ok! Have checked electrical switch on wall - it's in the "ON" position. My gas supply is fine because central heating is working.
  • Anonymous Mar 13, 2014
    Clock and timer gone and main oven not coming on and no gas to even light manually only stopped working when clock control went off!
Panick Over!!
We had to pull out the oven and discovered the problem was a blown 3amp fuse in the plug at the back of the cooker! A bit of a scramble for a spare fuse but at least we're back in action!
Posted on May 27, 2008
Indesit cooker
I would contact indesit on there tech help line .Its on line on there site
Apr 21, 2017 | Ovens
F-3 signal on Jenn-Air SVE47600, grill-range, self-cleaning convection oven
The F3 means there is something wrong in the sensor circuit, sensor/wiring/clock. F3 Problem: Shorted or open oven temperature sensor (RTD): Solution: Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Jan 06, 2008 | Ovens
Resetting the clock
You can set the timer on a single oven slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking.The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
INSTRUCTION BELOW.
  • Fill the insert of the single oven slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  • 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
  • Please rate this solution after use.
    Thank you and thanks for using fixya.
    Oct 03, 2010 | Maytag CWG3100A Gas Single Oven
    Tricity bendix se211 electric cooker trips all my electrics
    The symptoms you describe are a classic example of an oven element heating up, and as it gets hotter, the insulation is breaking down, thereby causing the earth leakage trip to operate.
    To confirm this , switch on the oven, and turn all 4 rings on the top to full heat, 2 at a time, let them stay on for at least 10-15 mins, and if it does not trip, then you can be pretty sure it is the oven element(s) that is the problem
    It is not likely to be the wall switch, as if it were faulty, i would expect the trip to go right away.
    If you want to check further, then turn on the oven again and see if it trips, if it does ,then it is definately the oven element(s) that is the problem.
    If it is a fan assisted oven , the element is at the rear of the oven, and possibly one under the base ot the oven. If it is a conventional convection oven, then there is an element at each side of the oven, even if one is faulty, replace both.
    Plz rate my solution.
    Thanks.
    Jan 07, 2009 | Ovens
    My tricity bendix electric cooker/oven trips all electrics
    H iyou can get the electrics cheched that will rule that out but it sounds like a short on the oven it could well be the element in the oven which you should be able to replace as its only 3 years old
    Jan 07, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
    Electric oven & grill not working no digital clock display
    If there is a display on the clock and you cannot reset it to manual, then the oven will not work, if you cannot reset then you will probably need a new timer fitting.
    They can be bypassed, but not recommended unless you know what you are doing..
    If there is no display at all , then check to make sure you have supply to oven
    Thanks.
    Dec 16, 2008 | Neff U1661 Double circotherm super...
    Low flame and not heating oven
    we had the same problem on our 10 yr old creda. gas man said new ffd required (flame failure device). he reckoned on around 80 pounds sterling for new part,even if it was still available, plus maybe 2 hours labour. we bought a new cooker!
    Nov 24, 2008 | Stoves 1000DFDLm Gas Kitchen Range
    Tappen gas 4 burner about 10 years old with about 10 hrs total use time(basement stove)
    Hi Carlsr,
    The F1 error code description is an electronic oven control failure. To fix this error, you need to replace electronic oven control (also called EOC or clock).
    Hope it helps.
    Thank you for using FixYa.
    Apr 13, 2008 | Tappan TGF320 Gas Kitchen Range
    Jenn-Air electric range
    my jen-Air has a problem with it continuing to beep. Ive tried to get it to stop by pushing all the buttons. When I pust the off/cancel button it just keeps beeping. Tried the stop timer button and same thing. When I turn on either the bake or convection bake button it automatically just shuts off by itself. It is approx 10-13 years old. HELP, or please tell me to get a new one.
    Jan 06, 2008 | Jenn-Air SVE47100 Slide-In Electric...
    Leisure rangemaster 55 gas cooker
    It sounds exactly the same as I am experiencing on my oven of the same model. My theory is that the full flame gas is controlled by a thermostat, and that this has broken hence why the oven only stays on preheat. This will be a matter of a replacement part. Most likely the thermostat is a bi-metal strip that, because it has heated and cooled so many times in it's life it has simply finally given up. Try searching online for the correct part and get a corgi registered fitter or another suitably qualified fitter to come and replace it.
    Nov 13, 2007 | Ovens
    Parkinson Cowan SG340 Gas Kitchen Range Logo
    441 people viewed this question
    Top Parkinson Cowan Kitchen Ranges Experts
    Paul Carew
    Shehu Pro
    Shehu Pro
    Tim Whalen
    Are you a Parkinson Cowan Kitchen Range Expert? Answer questions, earn points and help others
