Question about Maxtor Hard Drive
Jumper settings for maxtor
Need jumper settings for maxtor hard drive,,model 91362u3,,13 gb,,want to make slave out of it
  • bobbybaboo May 26, 2008
    please
  • Mehrdadnik Mar 26, 2009
    need jumper settings for maxtor hard drive 500Gb,,want to make slave
THE SLAVE: ______
I have a maxtor hdd and i hope this works........
Posted on Dec 29, 2008
How to setting jumper for external maxtor 80gb model?
Posted on Aug 22, 2008
  • 86 Answers
Http://www.tacktech.com/display.cfm?ttid=379
Go there and enjoy dude ....
Posted on May 26, 2008
    Novelist:
  • 153 Answers
  • Jason Adlard May 26, 2008
    wasnt the information correct?
    According to the info listed they should be the correct jumper settings.
    Let me know if you have a further problem
    cheers
3 Suggested Answers
Drawsalot
  • 38 Answers
SOURCE: jumper settings for an older maxtor hard drive
Support can be found at Seagate.com in case this is not the exact drive. The model number you listed was not an exact match.
Posted on Nov 25, 2007
how many pins in that hard drve?..let me analyze to you this, if the hard is in front of you, you'll see the connection of the ide cable and power cable, then the jumper setting pins is in your left,am i right?..so the pins is figure like this, : : : ., is that right?..the first pin(from top to bottom)is the master, and second one, is the slave and the last is cable select..
Posted on Feb 26, 2008
What are the jumper settings for the maxtor 9064004 6.4 GB HDD?
Most computers 'nowadays' dont really need jumper settings, usually the best approach is to have all your drives on the same ribbon cable, on "cable select" if thats not an option, 'slave slave(or just slave depending on the drive)' will work just fine.
Mar 01, 2011 | Maxtor Hard Drive
Need jumper settings wd800 as Mast. & maxtor Dia.plus as slave??
To use the WD 800 as a master there must be no jumper attached to it.The maxtor has a diagram for the jumper and it MUST be set to slave not cable select.
Mar 24, 2010 | Maxtor DiamondMax Plus 9 160 GB Hard Drive
Maxtor hard drive jumper setting for model 6v200e0
here is a poster of Maxtors jumper settings for each kind of drive.
Nov 12, 2009 | Computers & Internet
What is the jumper setting for 'Slave' on Maxtor
Look at the picture, I cannot memorize all hardisk jumper but almost all drives have label in it. where you put the jumper for the Cable Select, Master, Slave.
See picture below. Opposite pins has label on it to where you put the jumper.
Oct 24, 2009 | Maxtor DiamondMax 6L160P0 160 GB Hard...
I need jumper settings for maxtor n256 model 96147h6 i wish to run it as a slave pls help. thx
For use as slave there is no jumper connected. (Master on/slave off0
Oct 04, 2009 | Maxtor Hard Drive
Jumper settings for a maxtor N256 master with slave
Select the maxtor HDD as master by setting the Jumper to the extreme left of the hdd; i.e. next to the data cable.
Remove all jumpers from the other HDD which you want to put as slave.
Sep 02, 2009 | Maxtor DiamondMax 80 (96147H6) 61.4 GB...
I need to set jumpers on hard drive Maxtor Maxline plus II y653z5le as a secondary drive. How do i do that?
on the drive there should be a diagram for how to set the jumper settings. you want to set it to slave.
Jun 13, 2009 | Maxtor MaXLine Plus II 250 GB Hard Drive
Setting Maxtor HD as Slave.
Howdy,
First "easy" one I've had in hours....
Just pull the J50 pin out of the jumper block and PRESTO it'll be a slave the OFF position literally reffers to having the J50 pin off of the hard drive. Just a note though, I highly recommend using a peice of scotch tape to affix the pin to a nearby surface cause there a real pain to find if and when you need em again.
Chris,
Armor-IT
Apr 23, 2009 | Maxtor DiamondMax 60 (33073U4) 30.7 GB...
Jumper settings
Feb 26, 2008 | Maxtor DiamondMax Plus 6800 (92049U6) 20.4...
Maxtor Hard Drive Logo
2,987 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
