Question about Estate TGDS840JQ Gas Dryer
My whirlpool estate dryer tub will not rotate
I have an estate dryer and it will not rotate. My husband noticed the belt loose, and the pulley come off, how do you fix this.
  • faith_71031 May 26, 2008
    my estate dryer comes on but the tumbler will not rotate, the belt is loose and the pulley is off, how do I fix this?
  • Anonymous Sep 15, 2008
    How do I get to the belt. I took off the back panel and the belt is not visible. what do i need to do next
    Novelist:
  • 177 Answers
Which pulley came off the one on the motor, or the Idler wheel that keeps tension on the belt. You probably will need a belt
Posted on May 26, 2008
Dryer belt is loose, how to adjust tension in idler arm?
It sounds like you didn't install the belt onto the idler pulley in the correct S-shape. The idler pulley should always keep the belt tight under spring tension (no adjustment screws).
Here is a video, and tho it is a completely different model, almost all dryer belts/pulleys are installed in this manner. You can skip to the 2:30 to 2:45 time frames, where it then shows exactly how to re-install the belt on the idler pulley.
Nov 02, 2014 | Frigidaire FGX831FS Washer/Dryer Laundry...
I have a Whirlpool Duet Washing Machine (GHW9100LW1). The washer stopped spinning, but the motor was going. I took off the back and noticed that the belt had come off and there was a lot of black...
The first thing to determine is if the pulley is loose due to wear on the pulley or if the spin bearing in the outer tub is bad.
Remove the belt. Make sure the nut holding the pulley in place is tight.
Wiggle the pulley while shining a bright lamp on it.. is it loose on the shaft or is the shaft moving.
If the shaft is moving.. outer tub needs to be replaced.. and in some cases this means the spin basket as well.
If you remove the pulley..and the inside mating surfaces which are flat on two sides are worn or rounded off.. bad pulley.. the retaining nut may not have been tightened properly.. or it became loose up over time,
However the black dust means the belt has been slipping ..some dust is probably normal due to age.. rubber breaks down..but a lot of dust means friction.. which means something is not turning as freely as it should.
So it has to be a loose retaining nut, worn pulley..or worn failing outer tub bearing.. I am afraid it's more than likely the last one.
Sears Parts Direct will have diagrams for your model..
Best of luck
May 12, 2011 | Washing Machines
The interior tub is not rotating
You either have a loose or broke drum belt, idler pulley or tension spring are broke, or a loose or broke motor pulley. If you want to check yourself you need to remove screws below lint trap door, remove screws from bhind control panel on the outerback, take a flathead screwdriver or putty knife to the bottom front corners of the lid to loosen clips, and lift shell to view drum and belt.
Apr 11, 2011 | Dryers
The dryer makes noise likes it's working, but it's not rotating
check th belt on unit most likely the belt has broke or the idler pulley located below the tub has come loose... good luck to you
Jan 06, 2011 | Dryers
Changing dryer belt on kirkland/whirlpool dryer took apart dryer but dont see where belt suppose to mount.
Hello. The belt goes around the tub and the tension pulley. In fact, it is always a good idea to replace both the belt and the idler/tension pulley at the same time. J.
If you want a schematic go to searsdirect.com and enter your model number. J.
Jun 27, 2010 | Whirlpool LER4634J Electric Dryer
This is a Estate (Whirlpool) Dryer. My son turned
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Nov 06, 2009 | Estate Dryers
Belt drum replacement
If this is a Whirlpool manufactured dryer (which inlcudes Kenmore, Roper, Estate, Kitchenaid, and Frigidaire), just follow these steps:
a. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
b. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
c. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and locate diagram H.
NOTE: It is normal for the idler pulley to come loose when there is no belt tension.
If your dryer is not manufactured by Whirlpool, or if you simply aren't sure, please post back with your model number so I can give you more accurate information. I hope you find this helpful.
Sep 01, 2009 | Dryers
My Estate gas dryer will not tumble. What should I look for to repair? Model number is TGDS740PQ1
Most dryers are driven by a belt around the drum, motor and tention pulley. Check the belt.
Jul 14, 2009 | Whirlpool LER5636P Electric Dryer
To replace the belt unplug the dryer, remove the lint filter, remove the 2 philip head screws,with a stiff putty knife pry up in the top of the cabnet on the right and left to litf the top, disconect the door swithch remove the screw from each side and lift the front off romove the old belt the reinstall put new belt around the drum groove side toward the drum. put the idler pully in the slot closest to the motor be sure the tab is under the base and the 2 catches stit in the slot. now pull the belt through the idler pully and around the motor shaft. the reinsatll the front secure with the screws reconect the door switch,close the top, put the 2 screws back in where the lint filter goes then put in lint filter, plug in dryer and test.
Jan 19, 2009 | Estate EED4300SQ Dryer
Whirlpool Dryer Motor Removal
stand that baby up!!! acess is from front, try removeig 2 screws from under lint filter and then pop top with screw driver lean top back.. youll see the tub and belt(if not broken right there),no belt??? order a 341241 whirlpool dryer belt. 2 5/16screws on either side of iside facade remoivefront caver, disconnect door switch and remove front panel. belt slips over drum , you need to reset tension pulley and wrap around motor shaft. .
Feb 26, 2008 | Whirlpool LER5636P Electric Dryer
Estate TGDS840JQ Gas Dryer Logo
587 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
