Question about Tomtom ONE GPS Receiver
Voice commands I cannot get any voice commands, volume level is set at maximum, selecting another voice has no effect, test voice selection produces no effect.
  • vudy Jun 13, 2008
    went on the internet turned the volume up yo 50 percent but its not 100 percent what else can we do?
    Novelist:
  • 158 Answers
Most likely cause is a faulty speaker . Very common. See other questions on Fixya where I ahve posted the solution.
Posted on Jun 12, 2008
HOW TO INCREASE VOLUME IN XOLO A500S
here are some steps to increase incall volume
open your dial pad thwn input *#*#3646633#*#*
go to hardware option nd select audio then select sph.....select level 6 then select volume lwvel at 160 then press on set key
now reboot your dewice
The first step is to get in the "Engineer Mode" by pressing the following set of keys in the dialpad "*#*#3646633#*#*"
Xolo A500s low microphone volume fixby Sbplus 20/09/2013 ' 3:39 6 Posted in Tutorials
If you are a Xolo A500S owner, then you might have noticed the low microphone volume on this handset. So think no more, just follow these simple steps and this problem will be fixed.
You can watch the video or follow the steps below.
The next step is to go to the " Hardware Testing " and select " Audio "
Now select " Normal Mode "
From the dropdown, select " Mic "
Now we will increase the value to the highest possible number, which over here is "255" You can also select the level as " level 6 " , which will set the maximum value.
Now press "set" to apply, and then restart/reboot the handset.
Repeat the procedure if the settings are not saved the first time.
Sep 09, 2013 | Cell Phones
My volumn on my ipod 4th gen is not working and when i go to settings it only shows languages no volumn setting
One of the major warnings Apple includes with all of its iPods is the permanent hearing damage that could occur if you have the volume on your iPod turned up too high.
To help combat the problem, the iPod comes with a feature that allows you to set a maximum volume level that your iPod can be played at that level is controlled by a combination that can keep others namely children from turning the volume up to dangerous levels.
The good news is, if that combination falls into the wrong hands, it can be reset.
Use your iPod's click wheel to scroll down to "Settings."
Press the center button located in the middle of the click wheel to select the settings menu.
Scroll down to "Playback" and press the center button to select it.
Scroll to "Volume Limit" and press the center button to select it.
Use the click wheel to scroll to the first number of the old combination and press the center button to select it.
Repeat this process for all four numbers of the old combination.
Use the click wheel to scroll to where you want the maximum volume to be set and press the center button.
Use the click wheel to scroll to "Lock" and press the center button.
Use the click wheel to enter the first number of the new combination when the message "Enter New Combination" appears on the screen repeat the process for the three remaining numbers.
Once the four numbers have been entered, your iPod's maximum volume will be set and your password will be changed.
hope this helps
Oct 17, 2012 | Apple iPod Audio Players & Recorders
Alesis DM6 electronic drum kit module sound problems: The mix in, display and sensors are working on the module but no drum sound is produced through the monitor or through headphones (but an ipod can be...
It appears that you have to select a "Kit" of drums when using the external triggers. It appears that the volume level for the kit and that for each voice MAY all have to be set, especially after new firmware download. Read manual about KIT volume level and selecting voice and volume level for those. Manual is NOT very clear about these things and you have to try them as this is where the probllem is.
May 08, 2011 | Alesis DM6 Electronic Drum Set
Remove lock from volume setting
Limit the volume Listening to loud sounds for longer than a moment can be harmful to the listener. You can set the volume level of the player to suit your preferences: 1 From the main menu, select Settings > Sound settings > Volume limit > Settings. 2 Press Vol- or Vol+ to adjust the level. 3 Press to set. > When you set a volume limit, you can no longer exceed the set volume, even if you press the Vol+ button. To enable maximum volume again, set the volume limit back to maximum or turn off, select Settings > Sound settings > Volume limit > Off.
Thanks for rating Good luck
Dec 22, 2010 | Philips Audio Players & Recorders
LifeCam VX-1000 Webcam: i can't get any voice responce. I have checked ev...
If you have a laptop and a webcam you have 2 mics - you need to set your webcam mic as default.
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Configure audio to the chat program
May 17, 2010 | Microsoft LifeCam VX-1000 Webcam
The volume on my acer aspire 5532 is not very at maximum level
Go to Device Manager and up date your drivers if this don't fix the issue. Try removing the driver and visit http://www.acer.com/worldwide/selection.html select your location.
Visit the drivers download section and download a fresh driver.
Dec 26, 2009 | Acer Computers & Internet
Cit200
Adjusting the volume of the caller's voice
You can increase or decrease the volume of a caller's voice during a call. There are 5 volume levels for selection.
To adjust the volume, during a call: While the phone is off hook (i.e. dial tone can be heard), press Up or Down.
The display shows the current volume level. Press Up or Down again to adjust the volume.
Still can't find the most comfortable level?
Besides adjusting the volume on the handset, you might also need to adjust the volume on your PC in order to set the speaker to the most comfortable
volume.
To set your handset's ringing melodies and volume:
1. Press MENU.
2. Press Up or Down to select SOUNDS. Press OK.
3. Press Up or Down to select HANDSET. Press OK.
4. Press Left or Right to change the volume level. Press Down.
5. Press Left or Right to select the external melody. Press Down.
6. Press Left or Right to select the internal melody. Press OK to confirm when finished.
Nov 01, 2008 | Linksys CIT200 IP Wireless Phone
How to increase volume in samsung E250
Try the code below at your own risk. I will not be liable for any damage this may cause to your phone.
Type the following codes on standby menu
*#0206*8378#
after typing you will be presented to a Test Mode menu
Select H/W Test
Select Audio Settings
Select IIS Normal (option 10) this is the normal volume for the phone. Scroll down to select Rx vol. then change level 14 to a higher value. Maximum is 30,000, i set mine at 5000
You can do the same for IIS Normal2 this is the volume for Music Player
Aug 16, 2008 | Lands Phones
Garmin nuvi 760
Go to tools-settings-language-voice and make sure it is set to "American English-Jack (TTS) or to American English-Jill (TTS)
Aug 10, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Tomtom ONE GPS Receiver Logo
153 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
