Okay. I have a DSD 1110 (+2) decoder. The decoder does not want to scan. It just shows a number 8 first then dL then a number 1 with a line turning around and then the numbers 8118 and then it starts again from the beginning going with that cycle on and on. Can someone please help me?
Hi, been having the same problems that you described and im not sure what to do. electricity was down for about 12 hours and when it returned i noticed the problem as well as all 3 indicator lights (red,green,yellow) showing on the front display. im just wondering if you found a solution. what did you do and did you eventually fix the problem?
Posted on Feb 12, 2011
  • ogwalr Jun 22, 2011
    that problem is common esepcially when you keep your decoder out of use for a long time. Decoder software is updated on a regular basis and once your unit is turned off for a long while, you are bound to miss some of these updates thereby causing ur device to 'crash'. In such cases, you will have to carry the decoder to your nearest service center for technical help
  • Tina Nov 19, 2012
    When it started I thouht it was just remporairly but mine was never out of use it indicates those 3 lights with a 8118 code like it will search but never concludes the search until it shows that code again.What shoul I do.
Its just a problem with psu,open up the decoder and check the capacitor C10 and C1 for buldging and if so replace them
Posted on Feb 13, 2012
Just press reset from the decorder, and scan again
Posted on Feb 27, 2012
DSD 1131 does not respond to a new remote control which is exactly the same as the old one. the remote is not faulty because itworks with other decoders
Some remotes , while looking the same on the outside are much different on the inside. Example: Two remotes in a household with 2 decoders in different rooms. To eliminate one from interfering with the other, each remote is matched to its decoder.
Jul 24, 2016 | Televison & Video
Tip
The Fisher & Paykel Smart Drive and EcoSmart electronic washing machines are...
The Fisher & Paykel Smart Drive and EcoSmart electronic washing machines are equipped with fault detecting software to help easily determine the cause whenever a problem occurs. Not like other electronic washing machines, these ones do not have displays to flash the code, but rather use the eight (8) light-emitting diodes (LED) of the Wash Progress indicators to indicate the fault code. The eight (8) LEDs stands as an 8-bit binary number (zeroes and ones) that must be decoded and then converted to the decimal number system to get the fault code.
The fault code can be decoded by determining which Wash Progress LEDs are lit. Once determined which of the LEDs are lit, write down the 8-bit binary code; 1 for lit LEDs and 0 for the off ones. For example; the final wash, rinse, and spin LEDs are lit; the binary code is 00001101. This in turn can be converted to the decimal number system by multiplying each digit with its corresponding place value then adding up the result. From left to right, the place values are 128, 64, 32, 16, 8, 4 , 2, and 1 respectively. Therefore, the decimal equivalent of 00001101 is 128(0) + 64(0) + 32(0) + 16(0) + 8(1) + 4(1) + 2(0) + 1(1) = 8 + 4 + 1 = 13; the fault code is 13.
on Apr 17, 2010 | Electrical Supplies
Tip
Decoding Fisher & Paykel Electronic Washing Machine Fault Codes
The Fisher & Paykel Smart Drive and EcoSmart electronic washing machines are equipped with fault detecting software to help easily determine the cause whenever a problem occurs. Not like other electronic washing machines, these ones do not have displays to flash the code, but rather use the eight (8) light-emitting diodes (LED) of the Wash Progress indicators to indicate the fault code. The eight (8) LEDs stand as an 8-bit binary number (zeroes and ones) that must be decoded and then converted to the decimal number system to get the fault code.
The fault code can be decoded by determining which Wash Progress LEDs are lit. Once determined which of the LEDs are lit, write down the 8-bit binary code; 1 for lit LEDs and 0 for the off ones. For example; the final wash, rinse, and spin LEDs are lit; the binary code is 00001101. This in turn can be converted to the decimal number system by multiplying each digit with its corresponding place value then adding up the result. From left to right, the place values are 128, 64, 32, 16, 8, 4, 2, and 1 respectively. Therefore, the decimal equivalent of 00001101 is 128(0) + 64(0) + 32(0) + 16(0) + 8(1) + 4(1) + 2(0) + 1(1) = 8 + 4 + 1 = 13; the fault code is 13 which is a pump fault.
Once the code is determined, search the web for the meaning and indicate it when requesting for an online assistance to facilitate a quick and precise response.
on Apr 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
How do i hard rest the dsd 3u decoder its failing to boot, its just showing the orange light
download the software on net
put the software on 256mb pendrive
insert and flash or update
Nov 18, 2014 | Computers & Internet
How do I setup 2 tv,s on a single view dsd 1131 decoder, 1 tv and decoder upstairs an 1 tv downstairs. The dish is already installed and can rust very easily for the area.
very simple ,, the tv next to the decoder must be conected using a rca cable and then run normal tv cable (RF out ) to the other room
Apr 04, 2013 | Televison & Video
My decoder - dsd 1131 does not respond to his remote control.Ive checked the batteries..they are ok.
Don't worry about it. You have mistakenly pressed Shift + exit. What you need to do is to press Shift + i. What you have done is used by the people using two decoder. They use it to switch between the two decoders.
Nov 28, 2010 | Televison & Video
Free to Air on a Dstv
how can i have codes to tune east african channels plis for free. am using dsd 1131 decoder of dstv. am in johannesburg.
Jun 18, 2010 | Televison & Video
Problems with activation of adobe acrobat 8 professional
Follow these steps to install "Adobe Acrobat 8 Professional" :
1. Double-click on the setup file.
2. Folow the instructions, and the installation will continue.
3. When asked to activate the product, choose "More Activation Options" and "Activate Over Phone".
4. You will now be given an "Activation Number / Authorisation Code".
5. Use this code and serial to activate your product!
* Internet or Phone connection is required for "Adobe Acrobat 8 Professional" product activation !
please rate this advice if it helps...tc! :)
Jan 15, 2010 | Adobe Acrobat® 8.0 Standard Full Version...
My motorola cls 1110 is frozen and the screen says f 8
Here is a link to the user guide. Your radio is a one channel radio, and the F8 indicates it is set to frequency number eight.
Dec 07, 2009 | Motorola CLS 1110 (1 Channel) 2-Way Radio
I like the look and price of the Marantz SR 6003 receiver, my only question being whether it suppports DSD data output from a SACD player like the ONKYO like the OPPO DV-980h. In other words can it receive...
Downloaded the user manual for the Marantz SR 6003 A/V Receiver. In this it stated that if a SACD player was connected to the SR 6003 with an HDMI interface earlier than 1.2 then the digital data from the SACD could not be transferred over the HDMI cable to the SR 6003. This implies, but does not confirm, that if a SACD player does provide a digital output on an HDMI 1.3 interface, then SACD audio data can be transmitted to the SR 6003 and, presumably, decoded and converted to 6 analogue streams which are then amplified and deleivered to the (6) analogue output terminals.
I'm fairly sure that the native DSD data from the SACD has to be converted to PCM before transmission over the HDMI interface which is better than nothing. What I was hoping for though was for the data to be transferred in DSD and converted in the SR 6003 directly to analogue, avoiding two intermediate conversions. This ideal solution can be done by only a few SACD/ A/V Receiver combinations, which is silly considering that it is also the simplest. One example, which has made a big impression amongst high fi enthusiasts, is the OPPO DV-980H Universal DVD player (plays any audio or video disc and costs almost nothing) and the Integra DTC 9.8 home theatre processor.
Jan 14, 2009 | Televison & Video
Computers & Internet Logo
991 people viewed this question
David Payne
David Payne
