Question about Gaiam Walking Fit Kit Pedometer Intermediate
Lost the directions need to know how to set all the buttons
  • 43,501 Answers
Here see if this helps....
http://www.gaiam.com/product/pedometer+fitness+kit+-+intermediate+level.do
How to use the pedometer:
Take out battery insulator pull tab.
Set the metric / imperial system.
  • Press the S5 (Up/Mode) to enter step mode.
  • Press S3 (Set) and hold button for 3 seconds.
  • Press S5 (Up/Mode) to toggle between metric / imperial.
  • Press S3 (Set) to select.
  • Basic operation buttons:
    Time mode
  • The display shows the current time.
  • Press S6 (Down) to toggle 12/24 hour display format. If 12-hour display format is selected, PM times are indicated with a P.
  • To set time: press and hold S3 (Set) to adjust mode. Hour will flash and display.
  • Press S5 (Up/Mode) of S6 (Down) to adjust the flashing digits. Hold the button for fast scrolling. Press S3 (Set) to confirm and move to minute. Adjust the minute.
  • Press S3 (Set) to confirm, and return back to the time mode.
  • Step mode:
  • Press MODE key to enter step mode.
  • The display shows the steps you have dones.
  • Press and hold S2 (CLE) to reset the step count. All information regarding the step counter/distance/calorie will be erased.
  • Distance mode:
  • Press mode to key enter distance mode. It shows the distance traveled.
  • To set personal stride: press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and / or S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to distance mode. Set stride: 30-180CM (12-70 inch).
  • Calorie mode:
  • Press mode key to enter calorie mode.
  • It will show the calories burned.
  • To set personal weight: Press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to calorie mode. Set weight: 10-15kg (20-330 lbs.)
  • Measuring your own stride:
  • An individual's stride may vary in length. Input the appropriate length by measuring the distance of 10 steps and dividing by 10 to get your own stride length.
  • How to adjust:
    Motion sensitivity slide switch
  • Attach the unit correctly and walk 100 steps. If the reading is 105 steps or more, slide the Motion sensitivity switch to the left. If the reading is 95 steps or less, slide the motion sensitivity switch to the right.
  • How to wear your pedometer:
  • Your pedometer clips easily and snugly to either side of the hip portion of your pants or shorts. For best results, keep the unit in line with the crease line of your pants.
  • The pedometer must be directly perpendicular to the ground. The pedometer needs to be at a 60 degree angle to the ground. Dragging your feet, walking with sandals or uneven footsteps in a crowded area can affect the accuracy.
  • The pedometer only works when walking, jogging, or walking up/down stairs.
  • How to use the panic alarm:
  • Pull out the panic alarm pin S7 (Panic Alarm) from the unit to trigger the alarm.
  • Press and hold S1 (RES) to stop sound temporarily.
  • Insert the panic alarm pin back into the unit to stop the alarm instantly.
  • Battery replacement:
    Panic alarm and LED Torch battery:
  • Open the battery door by unscrewing the secure screw.
  • Flip out the exhausted battery and replace with two new *CR2016 (3V) batteries. Make sure the polarity is correct. Close battery door and fasten the screws.
  • heatman101
    Posted on Oct 02, 2010
    I have Equity Time Insta-Set Model 40018. I lost the directions about how to set it. How do I get the directions? Are they available online?
    Model 40018: You do not need the 9-volt battery to operate this clock.
    NO TIME DISPLAYED WHEN PLUGGED INTO AC POWER:
    If the display is blank when plugged into the AC outlet, unplug from AC power and remove the Insta-Set battery (lithium button cell), then plug into AC power again and manually set the Time and Date.
    • HOUR: Press and hold the DST SET button for 7 seconds until the 12:00 flashes. Use the PLUS and MINUS buttons to set the Hour. Press and release the DST button to move to the Minutes.
    • MINUTES: The Minutes will be flashing. Use the PLUS and MINUS buttons to set the Minutes. Press and release the DST SET button to move to the Month.
    • MONTH:The Month will be flashing. Use the PLUS and MINUS buttons to set the Month. Press and release the DST SET button to move to the Date.
    • DATE: TheDate will be flashing. Use the PLUS and MINUS buttons to set the Date. Press and release the DST SET button to move to the Year.
    • YEAR: The Minutes will be flashing. Use the PLUS and MINUS buttons to set the Year. Press and release the DST SET button to secure the setting in the memory.
    After completing the manual set for time and date, insert a fresh Insta-Set button cell battery and the settings will automatically be stored in the clock.
    Jan 31, 2015 | Audio Players & Recorders
    I have an Ellies wizared remote control but lost the manual. Unable to set up to Toshiba T,V, don't know what buttons to type
    hello, I enclose you a link to a website containing universal codes, which attempt to find the appropriate code to your TV model. Try the first option of direct income by type of TV code. If that fails, try the automatic scan. Good luck! Let me know if you need additional guidance.
    http://kbase.x10.com/wiki/Four_Digit_Universal_Remote_Code_List#Direct_Code_Entry
    Feb 28, 2011 | Toshiba Televison & Video
    I just purchased a Heritage Mint Ltd Timepiece Quartz Regulator wall clock but it chimes two hours slower than the actual time. Need to know how to correct it. There is a red push button on the back of...
    I have the same clock. Here's what I did to re-set it after changing batteries: After replacing batteries, use the turn dial to set the correct time. Press the RED button 6 times, wait for it to go through that series of chimes, then press the button again to set the time.
    Example: Press RED button 6 times. Wait for it to chime. Press RED button the correct number of times for the hour to be set. For 5:00, press the button 5 times, etc.
    I lost the directions to my clock, and I am posting this from memory and also just had to re-set mine and it works OK now.
    Hope this helps!
    Feb 07, 2011 | Watches
    I have lost channels 5,itv 3,and itv 4,and do not know how to retune my tv, all other channels appear to be alright slightly confused when i press the menu button and not know which links to follow?
    All Freeview channels need re-tuned after 30th September.
    To re-tune your Sony TV...
    1.Press Menu button then go to settings...
    2.Scroll down the menu icons until you get to 'Digital Set-up'
    3.Press enter/centre key next to direction arrows
    4. Select spanner icon and digital audio tuning.
    5. You will then be asked if you want to start digital audio tuning.
    6. Press enter/centre button....and thats it!.... TV will automatically re-tune.
    Oct 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    I need to know how to set this watch. My daughter lost the directions. It says SHP3167 on the back. Can you help me?
    Generally digital watches all set about the same.
    I believe your watch is a Sharp digital alarm/chrono by the number you give.
    Hold down the start/stop button in the right corner until the display begins to flash. Once the display flashes you can go through the fields to be set by pressing the mode button.
    Some digitals use a different combination but are all about the same.
    Sep 15, 2009 | Watches
    I lost the instruction manual for my TV and I don't know how to set up my remote to change channels with the up/down button
    I would just do it manually or get a universal remote,those come with directions and work for any tv
    Sep 06, 2009 | Televison & Video
    Lost directions for ProSpirit Fast Wrap
    press the mode button untill you get to the setting where the seconds are flashing.hit the reset button to menuver through the hours, minutes, days, and months.
    Jun 16, 2009 | Watches
    Direct faxing
    Note: up = stamp button / down = halftone button
    • press function button
    • press down button until "setmode" is displayed
    • press set
    • press down until #4 "fax parameters" is displayed
    • press set
    • press down until #5 "memory" is displayed
    Display should be at 2 = ON
    • press 1 to change to 1 = OFF
    • press red button to close the menu
    The memory light should go off when the menu is closed.
    To reset the memory state, repeat the steps, but instead, press 2 for 2 = ON and close the menu.
    Hope this helps!
    Mar 31, 2009 | Panasonic Panafax UF-550 Plain Paper Laser...
    Need to know "HOW TO" set up RCR312W
    You have to hold the component button (TV) and enter the code from http://www.rca.com/codefinder. The SKU it asks for, on my RCR312W, was under the lid from the batteries. Hope it helps.
    Feb 15, 2009 | RCA Universal Remote Control
    Lost remote codes
    I just bought one for my wife's aunt and have the book in front of me. Without knowing what codes you need, I would have to list all of them. There are quite a few and it would be very time consuming. There is an alternative.
    1. Press and hold the "Code Search" button until the LED stays on.
    2. Press the device button (TV, VCR, etc...). The LED will flash once and stay on.
    3. Keep pressing the On/Off button until your devise shuts off. then press "Enter".
    Hope this helps
    Nov 23, 2007 | Televison & Video
    Gaiam Walking Fit Kit Pedometer Intermediate Logo
    2,160 people viewed this question
    Top Gaiam Exercise & Fitness Experts
    Electro Med Services...
    Howard
    Howard
    Tom Chichester
    Are you a Gaiam Exercise and Fitnes Expert? Answer questions, earn points and help others
