I'm trying to get hold of a Halstead CBX boiler 'user guide' and a Halstead RFTH1 room stat 'user guide'. Where can i get these docs?
  • 43,501 Answers
Here is a site that seems to have everything in that line...
May cost you a few $$ but it will be worth it...
Halstead Boilers Ltd
heatman101
Posted on Oct 02, 2010
Baxi back boiler. Heating only works when hot water is on, and cylinder stat is calling for heat (Y plan). Is this a problem with room stat?
Turn cylinder stat down turn room stat up y plan valve should move to heating check you have power from stat to valve . It may be the valve not moving over to heating side .
Nov 08, 2016 | Heating & Cooling
The wifi connection from worcester boiler to room thermastat Honeywell Cm921 , boiler not receiving signal
Can't help you directly, but Honeywell will have user instructions on their website.
It's something like holding the 'stat within a metre of the boiler when the batteries are inserted. Best to RTFI.
Jan 27, 2013 | Heating & Cooling
My Baxi Solo 3 PF60 Boiler was serviced 2 weeks ago be a Corgi registerd agent. The Boiler had worked very well in fact and up until last Sunday morning when the boiler failed to come on. On inspection,...
It could be something as simple as an improperly placed thermostatic sensing bulb. Those controls are pretty tough. Look for obstructions that would cause air restrictions and overheating. You've done all you can do then. Call the tech back back and get him to check or replace the aqua-stat.If it turns out to be ok them your limit may be weak and in need of replacement.
Oct 27, 2010 | Kitchen Ranges
I have a Y plan heating/domestic instalation.The boiler will go off and on even if the programmer is off,If the programmer is off and I turn the cylinder stat up the c/heating pump will run,i recently...
Hi the cylinderstat controls the hot water only not the heating the boiler stat controls the water temp the room theromstat controls the rads , if you have one ,
so boiler stat set on 180f or number 5 cylindersat set on 140f to 120f roomstat to your comfort , the boiler stat works as a over heat so if the cylinder stat or roomsat fail it will turn off on the boiler you should beable to check wiring from that .
Mar 10, 2010 | Heating & Cooling
Central heating system boiling
more information required but if the boiler supplies the domestic hot water cylinder then the stat on the cylinder may be bringing on the boiler also the boiler stat may be up too high try turning it down.
Jan 05, 2009 | Heating & Cooling
My Worcester Bosch 35cdi boiler is flashing temp then backwards t forwards t, whats wrong with it.?
35 cdi worcester combi about 3 years old,heating not working,hot water works fine.It's been serviced not long ago.Room stat turned up and trv's ,but boiler want fire up,there's power to the boiler and the room stat the built in time clock is switched to on, but still nothing. do you think it could be the diverter valve, when i got there it was flashing SE which mean's it needs a service,cleaned the heat exchanger and burner with the proper worceter brush etc then re set boiler with technical, they also said it could be the built in clock and told me to disconect it, and just use the heating stat to control it.It still want fire.
Sep 03, 2008 | Heating & Cooling
I have a 6 year old Halstead Ace High boiler which has many recurring problems due to a bad fitting. It was never flushed out causing the heat exchange needing to replaced TWICE through clogging and then...
Firstly your system needs a power flush to get rid of the grot, then it needs a good inhibitor to slow up the reappearance of the sludge.
Changing the boiler won't help. Any boiler will get clogged up but the halstead DHW heat exchanger is particualrly prone to getting gummed up. You can clean this out and refit without having to buy a new one. - but without a power flush it will happen again.
Jul 31, 2008 | Heating & Cooling
Heating & Cooling Logo
388 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
