Question about Canon Office Equipment & Supplies
Canon MF3110 - Copy problems When we try to copy a document it comes our blurry, yet if we send a document from computer software it comes out fine.
  • 38gracie May 26, 2008
    Already cleaned the scanner and checked copy and exposure settings.
    President:
  • 2,712 Answers
Try reinstalling the driver first. If that does not work, the issue is with the scanning hardware, which will have to be calibrated. Try doing a calibration of your scanner from the tool box first. If that doesnt work either, then it is definitely scanner hardware defect.
If your all in one is under warranty, I'd recommend you contact the point of sale of the manufacturer. Unfortunately, if your warranty has run out, you will either have to get it serviced or buy a new machine (whichever works out cheaper)
Hope that helps!
Posted on May 26, 2008
    Genius:
  • 1,447 Answers
You can adjust the image quality to the appropriate level best suited for a document with text or photos. Three modes are available for adjusting the image quality.
  1. Press <Image Quality>.
  2. Press <Image Quality> repeatedly until the image quality you want appears.
    You can select from the following: - [TEXT] for text-only documents - [PHOTO] for photographs - [TEXT/PHOTO] for documents with text and photographs
try cleaning the scanner glass as well...
hope this helps
  • Edgar Allan Pagayona
    Edgar Allan Pagayona May 31, 2008
    Have you tried changing the drum? or the photoconductor unit? try replacing it
  • Canon Master
  • 13,433 Answers
Clean the scanner, try again. The copy settings might be set to a bad quality Will check.
  • Ekse May 26, 2008
    Ok, you have checked the copy and exposure setings what about Toner Saver Mode?
What are the uses of a scanner?
Here are a few things you can do with a scanner.
Copying Documents - You can turn a good flatbed scanner into a copying machine by scanning in those receipts and other important documents and then use your printer to have a copy or just keep a digital copy. The best thing about this is that you could use software to improve the documents, if you need to take out a grease smudge.
Other things a scanner can do is copy a quick recipe out of Grandmas old recipe book, or a page from a magazine that shows the instructions for a new at-home project you have been wanting to do. Maybe there are some old documents in the family that you would like to have a copy of for yourself, those can be added to the computer files just as any other document.
Scanning Photos For Printing - Photographs are nice especially if you are a professional photographer, but you could use the photos for websites to display your latest DIY project. The images could be used for desktop wallpaper or sending to friends and family through email. Because they are digitized you can use computer software to edit them, and make interesting images on top of the first.
Here is something else you could do with a scanner and software. Using the edit feature you can enlarge your projects on the computer screen and then print out only that part. This allows you to make a full-sized pattern of anything you wish, turn around and use it to trace the object on plywood. Once you are done, cut out life-sized reindeer, cows, antique cars, you name it.
Faxing Documents - You can Fax a document that is already in your computer, but if that document is on a sheet of paper, you have a problem. A scanner can scan it in, then you can send it out by using the fax driver. When you have long distance relatives, and you find something in a magazine that they need to see, put the magazine in the scanner and then from the computer send them the information.
OCR - Optical Character Recognition (OCR) software is used to convert images to readable text. Once they are converted you can use a word processor to make the changes that are required. OCR software usually comes with the scanner.
There always seems to be a need to try getting a hard copy of some document or picture into the computer files, and a scanner is the only way to achieve that. Having a good scanner could really improve your home or office by allowing you to copy, organize and save important files and photos on your computer.
Mar 15, 2011 | Office Equipment & Supplies
CANON PIXMA MP810 PROBLEMS - Aghhhhh!! I can
Try this,
scan the document to the computer, then view it using a picture viewer.
You may see that the scan is faulty!
The printer may be printing exactly what it sees!
Mar 07, 2010 | Canon PIXMA MP810 All-In-One InkJet...
How can i copy a legal document with cannon MF3200
you can print legal document through print command go to print property and give command on legal size.
but you can't scan legal document in single go.
if it urgent to scan in legal scan it in 2 parts then join using some software like corel draw or word.
Jun 10, 2009 | Canon MF3110 All-In-One Laser Printer
Difficulty printing
First of all, delete all the copies of that printer in the folder and try again. If possible delete them all and reinstall the printer.
Apr 21, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Can't send or receive fax
Your product must be accidently set to copy mode instead of fax mode and when it is, it actually expects a document to be loaded in the tray to "scan/copy" so change to fax mode again and try to sent the document. This should fix your problem.
If you do want to make a copy, make sure a doc. is loaded and press start copy to do so.
Jan 06, 2009 | Canon FAX L-120 Plain Paper Laser
Copying and fax sending problem
  1. Just check & clean the dust in the original feeding area.
  2. if not solved, clean the Document feed sensor or replace the same. But for this you need to open the body of the fax machine.
Mar 11, 2008 | Canon FAX-B820 Plain Paper Bubblejet
COPY PROBLEM
You have a scanner problem.  You might try and make sure you're using the right plug for it.  If you can figure out how to take the glass off, you should try cleaning all the glass and mirrors.  You should also clean the area just above where the scanner rests when it's not being used (you'll see a white strip there).  If none of this works, you'll probably need a new scanner.  Junk the thing.
Oct 26, 2007 | Canon imageCLASS MF5550 All-In-One Laser...
478 people viewed this question
old marine
old marine
