Question about Epson LQ-2090 Matrix Printer
I am not able to take the printout from Windows & DOS also by using following command DIR>PRN Printer drivers is properly installed.
3 Suggested Answers
SOURCE: Dos Program in FoxPro
To answer the question, I need to k**w if your DOS session is running inside Windows. As this is the most likely scenario, I'll answer assuming that - the answer will be different for DOS only systems.
Has the faulty LPT1 port has actually been removed? If it has, why **t just alter the port number of LPT3 back to LPT1 ? This can be done with jumpers on an old style card, or from device manager inside Windows if plug and play. If **t, you can try the following:
1: If the printer is already installed in Windows on LPT3, skip to step 3:
2: Install the printer in Windows. If you don't have a suitable driver for it, you can use Generic/Text only driver.
3: Right click on the printer, go to sharing, and make the printer shareable. Use a share name of 11 or less characters and ** spaces - e.g. EPSONLX500
4: From the CMD prompt, type the command:
net use lpt1: \\%computername%\Sharename
e.g.
net use lpt1: \\%computername%\EPSONLX500
**te that you do **t need to replace %computername% with your exact computer name - the machine will do it for you.
Finally, for others reading this, you can also use this technique to print from DOS to most "intelligent" USB printers (Hi end Laser, Dot Matrix etc). It probably won't work with "dumb" GDI printers or All-in-ones where Windows has to do all the work. If the printer supports PCL or ESCP printing languages, you are probably going to be OK.
Posted on Mar 10, 2008
Basti
  • 1447 Answers
SOURCE: Unable to install Epson TM-U220B[U220 with UB-U02III usb interface] on Windows 7 AND XP!
Hi!
Are you using a third party USB adapter or a USB interface? On the self test page that you printed does it say USB connection or something that will say about USB? or does it say parallel or serial connection? try to check the dip switches setting if its configured properly. visit epsonexperts.com site for more info.
Posted on Sep 20, 2012
I have designed a software to print visitor badges on spot for conferences but i am unable to send the print command to my Brother QL-570 Label printer ..I am not able to generate a .prn file .. please...
Welcome to FixYa.
To generate a PRN file, you need to have the printer driver installed in your computer. You should be able to see the PRN option (in some cases, it is termed as 'save to file') in the printer dialog box.
In your own software, you have to use the printers driver as well to produce a PRN file as well.
Since you are also unable to send the print command to your printer, it seems that your printer driver is not present or might have been corrupted.
Download and install the driver for your printer from >>HERE
Thank you for using FixYa, have a great day.
Jas247
Jul 24, 2011 | Brother HL-2040 Laser Printer
HOW CAN I PRINT FOLDER CONTENTS SIMILLAR TO THE DOS CAOMMAND TREE > PRN
Go to start button. In the start menu click RUN and in the box that opens type "cmd"
In the CLI go to the directory of the folder whose content you want to print and type the following and press enter to create list.txt file first before printing.
dir /b /s /on >list.txt
This will give you a text file (list.txt) in the folder, that you
can manipulate, print etc. in a text editor or
word processor. In order to redirect the output
directly to your printer, instead of a text file, type:
dir /b /s /on >prn
Aug 25, 2010 | Microsoft Computers & Internet
I am using foxpro 2.6 (DOS) with Windowx XP SP2 along with TVSE Printer my problem is when I issue the command ? the printing starts only after 30 seconds (I am not sharing the printer and I had changed...
Try using "Print directly to the printer" option. You will get this option by:
Control Panel->Printers and faxes->Right Click on the Printer Icon and the select Properties->Advanced tab
Hope that answers the question
Nov 04, 2009 | Computers & Internet
Zebra TLC2844 wont print at all
Try to make the self-test first:
Power OFF
Press "FEED" and keep it pressed and turn the power ON again.
Did it print?! if Yes... There must be a cable problem or port.
Is it USB? Serial? Parallel ?
Let's say it's Parallel, go to the command line and type:
"dir >lpt1"
without the quotes and assuming it's connected to 1st parallel port
did it print?!
on serial would be "dir >com1"
or, if it shows up in "Printers", pre-define it and just type: "dir >prn"
Still doesn't work!?
Try with a different cable, or other computer.
You can use it even without installing the drivers...
Sep 14, 2009 | Zebra Eltron TLP 2844 Thermal Label...
31PR supports parallel port or not?
I HAVE DG31PR M/B AND ADD PIC CARD IN PRINTER PORT\r\nADD PRINTER AND PRINT IN ONLY WINDOWS BASED.
other M/b Onboard
I HAVE DOS BASED PRINT Eg. c:\dir >prn to print to directories names.
but could not print out. because printer port is LPT3 is named.
anyway i am try to lpt3 to lpt the following steps
divice manager
ports
com & lpt
lpt3- properties
port setting
port lpt3 to lpt1
apply
then print is successfully
the above setup followed in DG31PR m/b.
lpt3- properties
port setting (tab) not viewed
Why?
Jun 23, 2009 | Intel DG31PR Motherboard
Dos commands in linux
go to http://www.pctechguide.com/articles/gettingDedicated12.htm you will find all the commands you need in there.
Jun 01, 2009 | Microsoft Computers & Internet
Not printing in foxpro 2.6 dos to hp laser jet 1020
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
Feb 05, 2009 | HP PSC 1610 All-In-One InkJet Printer
How to print from DOS?
type
prn and then the file location
you will be able to get printouts from DOS
Jun 09, 2008 | Samsung ML-2510 Laser Printer
e.g.
Mar 10, 2008 | Office Equipment & Supplies
Printer Problem
two possibilities, if you are in possession of the motherboard drivers you will need to install them as windows xp will be using generic ones and may not be suitable for your board, also try installing in a different usb port. The other is that the drivers you are using will probably be win 2000 and in your case it wont work with XP, so go to your printer manufacturer web site and download and install XP drivers.
May 24, 2007 | AOpen AX34-U Motherboard
Epson LQ-2090 Matrix Printer Logo
56 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
