Question about Pentax Optio A10 Digital Camera
Hello, I have a problem with my Pentax Optio A10 because I don't know why but when I turn the camera on, just stay on 5 seconds and then it turns off. I have charged the battery and the camera. Do know which can be the problem?? Thanks
    Brigadier General:
  • 3,006 Answers
This is very likely to be a lens error. This is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Pentax service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Posted on Oct 02, 2010
Testimonial: "Thank you very much, I will try to fix it myself"
  • Ken Collier Nov 29, 2010
    Excellent and very thorough article. Solved my problem.
Lens won't stay out on Pentax Optio A10
This happen after a hard hit on the floor
Jul 24, 2014 | Pentax Optio A10 Digital Camera
Got my Pentax Optio A10 soaked in the rain today. TOTALLY!
soak and, I mean soak your camera inside and, out in 90% isoprophyl (rubbing) alcohol remove the battery first then after 24 hours dry the camera out using a hair dryer on the warm setting.
Jul 15, 2010 | Pentax Optio A10 Digital Camera
Pentax Optio a10 turns off automatically after I turn it on
It sounds like you may have a bad lens assembly. If it is sticking, it will buzz. If it fails to open all the way, it will turn itself back off. This is what it sounds like you are saying. I can fix this for $40, or you can send it to Pentax in Arizona. I don't know what they charge for a lens assembly, but the minimum charge for this camera seems to be about $90. If you just want to get rid of this camera, I also buy all Pentax Option a10, a20, a30, a40 cameras.
Contact me at: mrfixitmark at comcast dot net
Jul 19, 2009 | Pentax Optio T10 Digital Camera
Pentax camera optio a10 won't retract
It sounds like you may have a bad lens assembly, or a bad main board. If it is sticking, it will buzz. If it fails to open or close all the way, it will turn itself back off. This is what it sounds like you are saying. I can fix this for $40, or you can send it to Pentax in Arizona. I don't know what they charge for a lens assembly, but the minimum charge for this camera seems to be about $90. If you just want to get rid of this camera, I also buy all Pentax Option a10, a20, a30, a40 cameras.
Jun 19, 2009 | Pentax Optio A30 Digital Camera
Pentax Optio A10 Camera Lens won't retract
It sounds like you may have a bad lens assembly. If it is sticking open or closed, it will usually make a buzzing noise. If it fails to open or close all the way, it will turn itself back off. This is what it sounds like you are saying. I can fix this for $40, or you can send it to Pentax in Arizona. I don't know what they charge for a lens assembly, but the minimum charge for this camera seems to be about $90. If you just want to get rid of this camera, I also buy all Pentax Option a10, a20, a30, a40 cameras.
Mar 27, 2009 | Pentax Optio A30 Digital Camera
Damage pentax a10 digicam
I don't see what the problem is, so I don't know what to suggest, but if you just want to get rid of this camera, I also buy all Pentax Option a10, a20, a30, a40 cameras.
Nov 30, 2008 | Pentax Optio A10 Digital Camera
Storing my photos
Hello sir ,
U need the vists compatible drivers for it !!
Mar 16, 2008 | Pentax Optio A10 Digital Camera
Power issue
First of all try the Pentax web site Technical support line. also when fire it up press the battery compartment door shut it may be tired contacts. But it looks like a repair job is needed- or it it is getting on a bit - replacing
May 30, 2007 | Pentax Optio A10 Digital Camera
Pentax Optio A10 Digital Camera Logo
194 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
