Question about Maytag Neptune MAH5500B Front Load Washer
Door locked dorr will not open and displays a "do" message when pressing the start button. After pressing start, the machine begins to cycle up but stops within 10-15 seconds.
  • 1 more comment
  • granny7 May 29, 2008
    Mine is also doing this. I called for assistance and was told to push the off button and hold in for 3 secs and try again. If this didn't fix it to try several times more, which I did and still no resolution. I also have a FL message blinking every now and then. Does anyone know what to do to resolve this?
  • Mo3219 May 30, 2008
    5/29/08 We have the same problem. Door locked flashing the do and fl. HELP!!!!
  • ryo_chan Jun 01, 2008
    I have the same problem here!! I have clean laundry trapped inside!! I tried to knock the pin out of the hinges but realized it can only be done when the door is open. I have unplugged it numerous times, held the off button, and pressed the start button just to see if that would do anything. I even tried tricking it into washing the clothes again... nothing. Please someone help us!!!
To all of you who have your door locked, i have had that same problem and my husband found out how to open it. under the bleach and softner dispenser there is a light green plastic chord. pull on that and it will open your door.
Posted on Jun 15, 2008
Granny 7: i have the same problems you have. i dont have a solution yet. thank you for your post.
1help
Posted on Jun 02, 2008
Washer will not run or complete a diagnostic.
1. The washing machine needs to be plugged in and in stand by mode with all indicators off.
2. Choose any one button on the washer's console except Power, Start, or Stop. Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds.
3. If the diagnostic test mode has been successfully entered, all of the indicator lights will glow for five seconds with 88 on the time display. (If it didn't work try #2 again One one thousand...Two one thousand...Three one thousand)
4. If there are any saved fault codes they will be displayed. If there are no save fault codes all indicator lights will turn off for a moment then back on with 88 displayed and the automatic diagnostic test mode will begin in five seconds.
5. If you are unable to enter the diagnostic test mode, press the power button and verify that the button you were trying to use operates properly to program the washer's cycle function. There may be something wrong with that function button. Find another button on the control that appears to work and try to enter the diagnostic mode with that button. You may also want to verify that the user interface has a good connection to the washing machine control board at the P11 terminal.
Back to Top
Note: Pressing the STOP or POWER button at any time to exit the washing machine's diagnostic mode.
Mar 14, 2015 | Kenmore Washing Machines
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Can't get machine to start a cycle. When press the start/pause button, the door open light begins to flash. After a few seconds, it stops flashing and the start/pause button begins flashing. I have checked...
It is hard to tell if there is no model number. Normally, WP machine has error code appeared on the display. I guess your unit does not have display, so the combination flashing is a signal to tell you what wrong with the system. You can check the service manual normally taps inside the unit.
Oct 22, 2013 | Whirlpool Washing Machines
Getting this code
Hello there and wdelcome to fixya
Resolution: DL is a failure of the door to lock. The door must lock before any cycle begins. This can be caused by any of the following conditions:
  1. The door lid is not completely closed due to an interference.
  2. Wash media buildup is preventing the lock bolt from extending.
  3. Machine/Motor control is detecting an open door/lid switch when it attempts to lock.
  4. Machine/ Motor control can not determine if the door/lid switch is in a locked state.
  • In some cases the control can be non-functioning and not accept any activation from the keypad, to clear and restart the control follow the below listed steps:
    • Unplug or turn the circuit breaker off for a 30 second period.
    • Reconnect the unit to the power source, breaker back on or plug into the wall outlet.
    • Press the Pause/Cancel/Stop button twice to clear the PF in the display
    • Try to start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Mar 22, 2013 | Washing Machines
My washer machines door is locked wont open. And won't wash the clothes in them
  • Unplug your Maytag washing machine for 30 seconds.
  • Plug your washing machine back in, and after 30 seconds, push the "Pause/Cancel/Stop" button two times. Choose a wash cycle.
  • Press the "Start" button until the wash cycle begins to ensure that the washing machine is functioning properly
  • Nov 09, 2012 | Washing Machines
    'washing machine miele w1714 lock on Message demo programme how i do unlock?
    Demonstration Mode (Dealer Displays)
    Initial requirements
    - Switch off the machine.
    - Close the door.
    Note
    Once you begin the access procedure, it must be completed within
    10 seconds.
    Accessing
    1. Press and hold the Start Button while switching the unit on with
    the On/Off Button.
    2. As soon as the Start LED lights up, release the Start Button.
    3. Immediately press and hold the Start Button, until the Start
    LED turns off.
    Deactivation
    Repeat the accessing procedure.
    Note
    The Demonstration Mode is NOT deactivated when the power is
    shut off with the On/Off Button, or by unplugging the appliance.
    Nov 04, 2012 | Washing Machines
    LG WM1814CW Front load Washer dE error? I get the dE error everytime I push the start button. The door wont open or close. I can hear the latch moving inside but nothing will happen. The "Door...
    A dE error code indicates that the washer door was unable to lock. This can normally be resolved by performing a simple reset on the washing machine.
    How to reset the washing machine:
    1.
    Press POWER to turn the washer off.
    2.
    Unplug the washer from the power outlet or turn the circuit breaker to the unit off.
    3.
    With the power disabled, press and hold the START/PAUSE button for 5 seconds.
    4.
    Plug the washer back in, or turn the circuit breaker back on.
    5.
    For more information about how to reset your specific model, please refer to the owner's manual.
    Press in on the door firmly and select any cycle. The washer door should lock, and the cycle should begin without an error code appearing on the display. If the cycle does not begin and the dE code appears again, repair service is required.
    Feb 03, 2018 | LG WM1814CW
    E27 and e95 code
    I had this problem. I tried to interupt a cycle just after it started and then couldn't start the cycle again, with the E27 code coming up.
    e27 refers to a problem with the door locking mechanism which could be due to a number of causes. The problem I had was with the solenoid in the door, not a genuine problem with the door latch mechanism.
    Here is how I fixed it:
    (1) Set knob to off
    (2) Hold down spin selector and Allergy rinse buttons and turn the knob to the LEFT (right does not work)
    (3) The display then shows a number of program codes P01 to P14. (Pressing spin selector rotates through the codes).
    (4) Press spin selector until you reach P02 on the display, then press the start button, the door will click and the machine will begin a cycle.
    (5) Turn the knob to OFF, and then you should be able to use the machine as normal.
    Jul 18, 2011 | Bosch Nexxt 300 Series WFMC2201UC
    Water is not coming into my Maytag dishwasher.
    Is the door open or unlatched?Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if the door is not latched. Check for obstructions (spoons or utensils), that may be interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure. The lights for cycles selected will flash if the door is opened while running a cycle.
    Is there power to the dishwasher?Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
    Does your dishwasher have a rotary timer knob?The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
    Is the control lock option activated?
    The indicator light next to the lock graphic will illuminate when the controls are locked. Press and hold the Heated Dry option (button with lock icon) for three seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
    Is the delay start option activated?To cancel the delay and cycle, press Start/Cancel twice.
    Is the water shutoff valve turned on?Make sure that the water shutoff valve is turned on.
    Mar 03, 2009 | Maytag 24 in. MDB6600A Jetclean II...
    No Locked Light
    does the washer actually go into high speed spin? if not the wax motor in the door lock may be no good. that would prevent the door from locking and the indicator on the display would not light.
    Aug 03, 2007 | Maytag Neptune Washer
    Maytag Neptune MAH5500B Front Load Washer Logo
    43 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
