Question about Precor EFX 546i Elliptical Version 4
Where do you find the fuse for a precor 546i? I have a low battery warning and have changed the battery, and power cord to battery, but it still says low battery???
Hi - did you find a solution to this? I am having the same problem. Thanks, any help would be appreciated.
Posted on Jan 07, 2012
You must have an incompetent boyfriend ... chuck him out then throw the machine out on top of him ..
Posted on Oct 07, 2010
Reset the error code on a precor elliptical
Not familiar with an error 400 - and error 40 is an elevation error - it needs to be addressed(fixed) cannot really be reset otherwise. Check connections and fuses first. If it was recently put together, make sure the data cable was not pinched. If it is battery operated, an error 40 can occur when the battery is low.
Oct 02, 2014 | Precor EFX 546i Elliptical Version 4
ERROR 46
Precor Error 46, Low Battery Voltage (AMT12 Only) Probable Cause 1. Blown fuse in the positive battery wire of the AMT12 2. Faulty or poor connection on the battery or LPCA 3. Low or no output voltage from battery
Corrective Action
  1. Remove the power from the unit and move the lift fuse from the in line fuse holder on the positive battery cable
    • Measure the fuse with an ohm meter (multi meter), the fuse should read approximately 1 ohm or less
      • If the reading is significantly high, replace the fuse
      • If the fuse is open, refer to next solution before you continue
  2. Check connector of the battery cable for shorts or poor connections
  3. Enter the diagnostic program per procedure, P80 Settings or Accessing the P30 Diagnostic Software
    • Using the diagnostic program allows you to test the incline system without continuously pedaling the unit if you have an external power supply
      • Otherwise, you will need to continue to pedal the unit
    • Connect a DC voltmeter to the J3 connector on the lower PCA as follows:voltmeter common lead to terminal 3 (black wire) and voltmeter "hot" lead to terminal 2 (red wire)
    • Using the STRIDE HEIGHT Up and Down keys, operate the incline
      • The voltmeter should read about +12VDC when the incline is instructed to move upward and about -12VDC when incline is instructed to move downward
    • If either voltage measurement is significantly low, replace the battery
Precor Error 46 AMT12 Only Low Battery Voltage
Apr 03, 2014 | Precor EFX 546i Elliptical Version 4
CROSSRAMP ON PRECOR 546i DOESNT GO UP OR DOWN
I would definitely check the battery first. The battery may not have enough charge to power everything plus the lift motor.
Here's a link to the various 546i models:
Repair Parts for Precor EFX 546i Ellipticals SPORTSMITH net
Drill it down on the left side under "narrow your search" and look for the serial number prefix. This will let you find all the correct parts and information specific to your model and serial number.
Jan 17, 2014 | Precor EFX 546i Elliptical Version 4
Is there a replaceable fuse for the efx 546i
Battery operated 546s have a fuse on the lower board, plug in models have a fuse on the lower board and fuses in the power inlet.
Jan 01, 2014 | Precor EFX 546i Elliptical Version 4
How do I replace the battery on efx 546i
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Warning Notice for Battery Installation of certain Precor Ellipticals This notice provides details about the battery replacement procedure that should be considered by anyone performing this repair. Following is the warning about the battery installation for certain models of the Precor ellipticals.
Precor Elliptical Models Affected:
  • EFX C524 with serial#s beginning I7, K7, LH, SW, SX
  • EFX C546 with serial#s beginning NF,SZ, IK, IL, IU
  • EFX C546I with serial#s beginning X8, XG, Z2
  • EFX C556 with serial#s beginning NG, SY
When replacing the battery on your Precor elliptical it is important to make sure that the battery terminals are not allowed to make contact with the metal surface of the battery bracket. **Damage to the battery will occur**.
Electrical tape can be wrapped around the battery terminals to prevent them from making contact with the metal surface of the battery bracket.
Battery replacement on the EFX C524, EFX C546, EFX C546i and EFX C556 instructs you to remove the (4) screws that fasten the battery bracket to the frame. This allows you to turn the lower PCA and battery assembly away from the frame so you can slide the battery out of the battery bracket. It may be necessary to remove the nut that fastens the front retaining bracket or "L" bracket in order to slide the battery out of the battery bracket.
Warning Notice for Battery Installation on Precor EFX Ellipticals
How do i change the battery on a precor efx 5461
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH Warning Notice for Battery Installation of certain Precor Ellipticals This notice provides details about the battery replacement procedure that should be considered by anyone performing this repair. Following is the warning about the battery installation for certain models of the Precor ellipticals.
Dec 25, 2013 | Precor EFX 546i Elliptical Version 4
The ramp will not go up or down and it doesn't state low battery (546i precor)
It doesn't always say low battery - check the battery first. If the battery is fine, then check the lower board and the incline motor.
Sep 26, 2011 | Precor EFX 546i Elliptical Version 4
Dead battery on Precor EFX 546i Elliptical - options on how to handle, please? Thanks very much.
This link will allow you to use your model and serial number to find the correct battery along with the service manual with replacement instructions.
Feb 13, 2011 | Precor EFX 546i Elliptical Version 4
The ramp will not go up or down. It's states low battery (546i precor)
The ramp system has a battery monitoring system. If the battery voltage falls below 11 Vdc when the ramp movement is initiated or the battery voltage falls below 10 Vdc after ramp movement has been initiated, ramp movement will be stopped and gives that error message. The ramp will not be enabled until such time as the battery voltage exceeds the above limits. The battery voltage must be raised to be to correct this problem either by charging or replacing the battery.
Dec 29, 2009 | Precor EFX 546i Elliptical Version 4
Precor EFX 546i Elliptical Version 4 Logo
910 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
