Question about Sharp R-1601 Microwave Oven
How to reset the machine as program hang up unable to cance.
  • Sharp Master
  • 9,085 Answers
A hard reset is simply unplugging the oven for about two minutes, plugging it back in and trying it again.
The owner's manual is here:
http://031d26d.namesecurehost.com/mwd/r1600_r1601_r1602_om.pdf
The service manual is here:
http://031d26d.namesecurehost.com/mwd/r1600_r1601_r1602_sm.pdf
You can order parts for this brand from Encompass here or you can call them toll-free at 866-779-5835.
We do repairs, so let me know if you need more help.
Posted on Oct 02, 2010
Power 100 code
you must try this:God bless you
If you are unable to adjust the power level, there may be a defective triac or a problem with the circuit board.
  1. Controller is confusedA power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
  2. Defective Interlock switchesThis can result in the controller thinking the door is open and ignoring you.
  3. CleaningCleaning solutions (spray cleaner) may have gotten inside and shorted out the touchpad or controller. If this happens remove the touchpad, let it air dry for a few days, and then attach it back on the microwave.
Nov 14, 2013 | Kenmore 66469 / 66462 / 66464 Microwave...
Computer panel is frozen, where is the reset button?
You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time.
Hopefully one of other experts will be able to provide you with a real solution.
Thank you for using FixYa.
Jan 10, 2012 | Microwave Ovens
Where is the reset button
Hi Janet:
Jan 10, 2012 | GE Microwave Ovens
By mistake all the points were pressed hence unable to delete and restart
What model microwave is this? Usually switching power off and then on again will clear the control panel and reset it.
Mar 10, 2011 | Samsung Microwave Ovens
The oven is in lock mode and will not change its mode. Unable to start oven the way it is. No manual available.
You don't seem to have specified the make and model number of your microwave oven. I'm at best guessing. Try pressing the Stop/Reset button repeatedly, until you see it unlock. If that doesn't work, try unplugging it, which might reset all the settings, or leave you equally bad off. I know how frustrating it is to have appliances mysteriously lock themselves. Good luck.
Jan 12, 2011 | Microwave Ovens
I have a GE Profile JVM1790 microwave that needs to be installed. However, it will sit in front of a 3/4" thick granite backsplash that I would rather not drill holes through. Would it be safe to mount...
The front weight hangs from the cabinet above the microwave, the rear weight needs support also. It is intended to be fastened to two studs. If the granite does not go all the way up to the cabinet above, install a wood spacer, the same thickness as the granite, then extend the wall plate, at the corners, with some flat stock aluminum strips, available at most hardware stores. Fasten the aluminum strips to to wall plate with short machine screws. - If the granite goes up to the cabinet bottom, shim out the bottom frame of the cabinet to the face of the granite and use the same aluminum flat stock to extend the wall plate up to the necessary location.
Jul 06, 2009 | Microwave Ovens
I have a 1.5 over the range fridgidaire microwave...it seems the door hangs a little low because in order for it to work you have to put your thumb on the bottom of the door to raise it up a little and...
Does it seem to hang low or does it actually hang low? Readjust it. There is a switch that may hang high when the door closes. You just have look at what does what and what ain' doing what it is supposed to. first.
May 04, 2009 | Frigidaire Over-the-Range Microwave
Sharp Carousel Microwave R-320FQ Serial # 26805 Mfg. Dec. 2002
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
It may have an intermittently shorting keypad or another problem on the control panel, which we repair for customers nationwide with our guaranteed $39.95 service.
Jun 08, 2008 | Sharp R-1480 Microwave Oven
Microwave installation under cabinet, no rear wall
Hi , I would like to suggest to visit near appliance center to purchase hanging for oven . ace hardwares.
Jan 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp R-1601 Microwave Oven Logo
56 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
