Question about Zanussi ZEBF250W Bottom Freezer Refrigerator
I looking electrical connection for Zanussi ZEBF250W
Zanussi fridge freezer fan sticking
See the picture below:
It is best to perform a visual inspection of the fan and measure the winding resistance. In this case there is no possibility of blocking the fan due to the excessive amount of ice. The reason is clearly visible from the the picture. The fan is located above the battery evaporator.
So, could be faulty: fun, wiring between fun and PCB, printed circuit board (PCB).
Dado
May 04, 2014 | Zanussi ZEBF250W Bottom Freezer...
The freezer is staring to ice up please help!
please switch off your refrigerator for at least 8 hrs. than again switch it on. i'm sure that the problem will be solved...................have a nice day :-)
May 14, 2009 | Zanussi ZEBF250W Bottom Freezer...
Zanussi fridge /freezer
the drain located under the evap. maybe stopped up pour some boiling hot water into it and see if it drains underneath into the drain pan
May 06, 2009 | Zanussi ZEBF250W Bottom Freezer...
Fridge does not cool
lo1972
Sounds like ice built up on the evaporator coils inside the freezer. thus hindering air flow to the refridgerator section. Is there ice build up in the freezer? This is assuming the temperature control didn't get changed inadverttily.
Hope this helps
handiman518
Jan 16, 2008 | Zanussi ZEBF250W Bottom Freezer...
Power light flashing on & off
Try to unplug and plug the power cord this may help, flashes is an error code. Try also the defrosting, error codes alarm the owner if there are some abnormal operation int the unit.
Jan 08, 2008 | Zanussi ZEBF250W Bottom Freezer...
Zanussi 920/g R
your thermostat is faulty you will have to replace it if you keep doing what you are doing your gas will run out ok go to your local appliace shop and give them the model number and they should get you one cheap
Jan 06, 2008 | Zanussi ZEBF250W Bottom Freezer...
Zanussi Freezer ZVC67 - replace the seal
yes u can fit it yourself the door seal shoould just push in which u might hear a small click when it is in properly not a major job m8
Aug 15, 2007 | Zanussi ZEBF250W Bottom Freezer...
sounds like the freezer evaporator has iced /frosted up and you will not get cold airflow through it. try a 24 hour defrost to clear it. then check fridge cooling.
Jun 03, 2007 | Zanussi ZEBF250W Bottom Freezer...
Zanussi ZEBF250W Bottom Freezer Refrigerator Logo
29 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
tony denham
Level 1 Expert
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
