Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Hi, Dishwasher problem: When a programme starts, the machine fills with water then stops and the "check water" light comes on. To empty the machine, I used the reset programme which does empty the machine. Any ideas of about what might be causing and the solution to this? Many thanks, Richard
  • Bosch Master
  • 17,130 Answers
You will need to check the inlet valve and the water level pressure switch. It can also be a low pressure in the pump that is giving out the signal for the control board to shut off.
So first of all check the water line throughly to confirm.
Posted on Oct 02, 2010
Meiko dishwasher. Do I have an eeprom problem?
sounds like it could be a defective cylinoid switch...this will not allow water to flow properly through the machine....this is located at the water connection....try replacing and reconnect water...good luck
May 19, 2014 | Meiko Dishwashers
Bosch SGS43C12 dishwasher fills with water as normal at start of programme, then you can hear a quiet 'click click' normally the cycle would start, but nothing happens. I can press reset and it drains the...
Where does the clicking sound seem to be coming from? Start the machine and when it's filled with water, try to identify where the clicking noise is emanating from. I suggest putting you ear next to the programme selector and start/stop switch and see if you can hear it more loudly/clearly.
Sounds like a faulty control module to me. Try the above and report back . . .
Oct 11, 2010 | Bosch 24 in. SGS43C12 Classixx...
Shortly after turning my indesit idl530 on a fault code appears
the problem you are getting is a f01 fault,this is water in the base part of the antiflood devise.to check this if you tip the appliance backwards and water comes from the back at the bottom this is the problem,if you do this till it stops and then leave for approx 24hrs to dry out any water that may have gone on to motor,then check by switching on to start a program,if appears to work ok but then goes back to the same fault(draining all the time and light flashing)you will have to remove base and check for leaks.
Jul 04, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
Zanussi DCE 5655 dish washer
Unplug at night if doesn't work change the L subport conversion chamber and remove the restricter plate
Feb 27, 2009 | Zanussi 21 in. DCE5655 Free-standing...
I have a c1 error on an AEG oko favorite 50700 What dies this error mean
I don't understand why replies talk about the C2 and C3 errors... The problem is C1! I have the C1 error. I start a programme, it does the draining cycle to check empty then starts filling. MI can hear water entering but it sounds slow at a low flow rate. If I leave it going, eventually the programme stops and the error is displayed: C1 Opening and closing the door allows the programme to continue. I get the error after the various stages of the programme, when it is filling for the next wash or rinse. So it's 4 or 5 times I think during the programme. Now, if I help the filling... When the appliance is filling, I open the door, and poor in a kettle or two of water, then the error does not happen (the fill is within the time expected by the appliance?) So I am thinking one of two things is wrong: 1) I have a flow rate problem BEFORE the water connection to the appliance. E.g. It is blocked somehow. 2) There is something which opens/closes the "tap" within the machine which is causing the flow rate to be low and it does not fill quickly due to that. No idea which of these two, but I did disconnect the hose of the supply and check that water flows quickly from it into a bucket, so I am thinking there is something inside the machine which "opens the tap" and it's not doing a good job of it. Anyone got a clue?
Dec 18, 2008 | AEG 24 in. Favorit 50730W Free-standing...
Bosch classicxx dishwasher not working check water light on
he there,
sounds like there may be something caught in the drain pump itself.
can you provide me with the complete model # on your dishwasher please?
thanks
Sep 25, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Dishwasher stopped mid programme
First place I would go is the door switches, make sure the dor switch assembly is not broken, and switches working.
Jan 05, 2008 | Dishwashers
Hotpoint DF53 will not start.
When you say fairly new , i assume its been used before , so you probably dont have warranty . You could have a programme problem , in which case its cheaper to buy a new one or check the solenoid at the water entry point to the machine , this has to activate and stop in order for the machine to proceed through the programme.
john
Oct 29, 2007 | Hotpoint 24 in. DF55 Free-standing...
Zanussi Aquapulse DE6544 not emptying
Zanussi Aquapulse dishwasher - is filled with water inside, is not washing and the lights keep flashing on and off - has anyone any idea what may be wrong with it?
May 27, 2007 | Zanussi 24 in. DE6544 Built-in Dishwasher
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
190 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
