Question about Lexmark X4270 All-In-One InkJet Printer
INSTALLATION I cannot get my printer to install to my computer.
  • ghostgrl43 May 29, 2008
    my all in one lexmark 4200 series will not download to windows vista,it was working when i had xp,it keeps saying cant find or no connection,and i have tried everything i can think of to fix it, please help? sandy
    President:
  • 2,351 Answers
Hi kessa, if you are using a windows XP operating system, try this. Make suer you're printer is plugged into a power source & you also have a USB data cable connected from the printer to you're PC's USB (Free/opend) USB port. (Some printer's do not provide the USB cable when you buy a printer.) If you do not have the USB data cable, you need to buy one. Once the cable's are connect. Power on you're printer. Window will ask you to insert the CD software for you're X470 printer. If windows does not. Than one of the cables is not connected correctly to the PC or power outlet. (Re-check). Link to buy a USB cable.
http://www.mptools.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=M&Category_Code=UP&gclid=CM-P9rL7xJMCFRUdsgodlBS3Dg
Link to updated WinXP software drivers. (Click on the link).
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:439:0:0&searchLang=en&os_group=WinXP&target=
If you have check all the above & still can not get you're printer to install through windows. Please explain what you have tried so far. (Is this a new printer)? You can also get free support from Lexmark. Click on the link provided.
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_652569481_0_en,00.html
Good Luck!
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
Posted on May 26, 2008
Hp photosmart 310c will not install on windows 7
IssueThe HP printer software installation fails to run in Windows 7 on a computer with an AMD C-50, C-60, or Z-01 1.00 GHz processor. After you insert the HP printer software installation CD or run the driver installation downloaded from the HP website, the setup does not open. You might receive an "HP Installer Setup has stopped working" error message.
'HP Installer Setup has stopped working' or Setup Does Not Run When Installing the HP Printer Software in Windows 7IssueThe HP printer software installation fails to run in Windows 7 on a computer with an AMD C-50, C-60, or Z-01 1.00 GHz processor. After you insert the HP printer software installation CD or run the driver installation downloaded from the HP website, the setup does not open. You might receive an "HP Installer Setup has stopped working" error message.note.pngNOTE:This document does not apply to HP LaserJet printers.Preliminary stepThe solution in this document resolves software installation issues only for Windows 7 computers with an AMD C-50, C-60, or Z-01 1.00 GHz processor.
  1. On the Windows taskbar, click the Windows icon (c01319360.gif ), right-click Computer , and then click Properties .
  2. In the System section under Processor , find the manufacturer, model, and speed (GHz) of the processor.
If your computer runs an AMD C-50, C-60, or Z-01 1.00 GHz processor, continue with the steps in the following solution.SolutionFollow these steps to download and install the newest, full-feature version of your HP printer software. Then, download and install a software patch to complete the installation.Step one: Download the softwarenote.pngNOTE:You must download the Full Feature software to resolve the installation issue.
Mar 24, 2013 | HP PhotoSmart Office Equipment & Supplies
Dont have disk to install
Welcome to FixYa.
You can download the installation software from the manufacturer's support website by clicking this link.
On the page which opens, click the "Download" button to start the download process.
Kindly refer the detailed installation instructions given on the download page to install the printer.
For your reference, here are the installation instructions again:
Installation Instructions:
  1. Verify that your computer meets the system requirements.
    NOTE: WINDOWS XP 64-bit Operating System is not supported.
  2. Disconnect your all-in-one printer from your computer.
  3. Verify that you logged on to the computer using the administrator account.
  4. Close all programs.
  5. Download the software onto your computer.
  6. Double-click the *.exe file, then follow the on-screen instructions.
  7. When the installation is complete, connect your all-in-one printer to your computer.
  8. Select Start > Programs > Kodak > Kodak AiO Home Center.
Hope this helps. Thanks.
Nov 26, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
Lexmark 1300 printer won't work.
Solution#1- If your printer does not show in your hardware list its means that problem belongs to data cable. Kindly check your printer's data cable and plug it properly.
Solution#2- Uninstall printer's software take a reboot and then reinstall its software and then attach your printer or during installation if installation requires.
Good Luck
Sep 03, 2009 | Lexmark C772dn Laser Printer
Hello I am unable to get my HP all in one printer working? it will copy a page for me, but I cannot print anything/
Did you plug in the printer before you installed the drivers from your installation CD? If not, you need to uninstall the hp printer drivers and unplug the usb cord from the computer.
Restart your computer, run the installation cd, and then after the HP installation says it's complete then plug the usb cable into your computer. NOTE: Some HP driver installations ask you during the install to plug in your printer so the software can find it. If thats what happens then only plug in your printers usb cable when the installation software tells you to. Once it detects your printer the installation will continue. Make sure you keep hitting next or continue until the software tells you everything is installed. Now your all in one printer should work.
Wilcocoop
Dec 09, 2008 | Office Equipment & Supplies
Lost my installation disk
Here is the driver download page:
Lexmark Z640 - Drivers & Downloads
Download the software into your computer, locate downloaded files and start installation program.
Start installation with printer USB cable unplugged, plug when required by software setup.
Vote the solution.
Thanks
Aug 15, 2008 | Lexmark Z600 InkJet Printer
Help
DOWNLOAD
Please follow the steps below to download the necessary drivers:
1. Go to the website http://support.epson.com
2. Under the ALL-IN-ONES heading select FLATBED and then your printer model.
3. Under the Drivers & Downloads section select WINDOWS. Download the most current version of the Printer Driver and Scanner TWAIN Drivers to your DESKTOP for your Windows operating system. You can also download the Status Monitor, if listed.
DOWNLOADED DRIVER INSTALLATION.
Scanner Installation
1) Before beginning, ensure the cable for the printer is disconnected and the printer is turned off.
2) Locate and double click on the downloaded Twain driver installation file.
3) Click on OK at the first WinZip screen.
4) Click on UNZIP at the second WinZip screen.
5) Click on OK when WinZip is finished extracting files.
6) Follow the prompts to complete the installation.
Printer Installation
1) Locate and double click on the downloaded Printer Driver installation file on your DESKTOP.
2) Click on OK at the first WinZip screen.
3) Click on UNZIP at the second WinZip screen.
4) Click on OK when WinZip is finished extracting files.
5) At the PRINTER UTILITY SETUP screen, click on OK.
6) The installer will now copy files to the computer. When this step is complete, it will tell you to attach the cable and power on the printer. Please connect the USB cable and turn on the printer.
7) The computer will install the new hardware.
8) Click on OK when the driver installation is completed.
Status Monitor 3 Installation (optional)
1) DOUBLE-CLICK on the downloaded file.
2) Make sure the STATUS MONITOR is highlighted and then click on OK. The installer will now copy the necessary files to your computer.
3) When finished click OK and restart your computer.
Aug 11, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Aug 02, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Lost installation disk for canon pixma iP 1500 inkjet printer
how do i install my printer onto my new computer if i lost the installation disk or cd rom?
I've lost the installation disk for mu Canon PIXMA iP4000. How can I download for free to reinstall? Thanks.....George
Jun 03, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Install of IBM infoprint printer drivers
make sure you are logged on a the Administrator to the computer then try installing..
Dec 26, 2007 | Office Equipment & Supplies
Won"t print- will copy:
You need to reinstall your printer driver. If you have the installation cd,
1. unplug your printer from the computer,
2. install the driver from the cd,
3. plug your printer back into the computer
4. turn the printer on
5. print your document.
If you do not have the installation cd, try the printer manufacturer's web site for the print driver. Before installing the driver, disconnect the printer from the pc to make sure installation goes smoothly.
Once the driver is installed, when you plug the printer into the computer and power it on, the computer will find it and finish the installation process automatically.
This will not help the problem posted by guest. His problem is totally unrelated.
Dec 06, 2007 | HP DeskJet F380 All-In-One Printer
Lexmark X4270 All-In-One InkJet Printer Logo
52 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
