Question about HP OfficeJet G85 All-In-One InkJet Printer
I replaced the black cartridge and the machine asked me to align.. I have done this several times and the machine will still not print in black. What do I do?
  • 68 Answers
You might have to remove a strip first that comes with the new ink cartridge. Or, perform the function that cleans the printer heads
Hope this helps. :)
Posted on Oct 02, 2010
After replacing 901 black cartridge printer keeps saying aligning cartridges please wait
every time replacing an ink cartridge, printers asking for alignment.do it once , following instuctions which appears in printers monitor.after,look at printed page and saw if is asking to scan once this page.
Feb 15, 2015 | HP Officejet 4500 All-in-One -...
Black ink will not print
Have you tried setting the color to black cartridge only. You may be printing the black with a combination of colored inks. I occasionally have a similar problem. Sometimes I can get the black to work by taking a paper towel dampened with distilled water and holding it against the cartridge print head until I see black ink coming out. Replace the cartridge and try printing again. If this doesn't work try a new cartridge and run through your Printer Settings, making sure they are all set properly.
Mar 17, 2014 | Hewlett Packard Printing & Imaging HP...
HP 3n1 keeps printing out a
This happens regularly in some models when the alignment of paper is not done correctly. If the cartridge does not have a good print quality, the scanner can not correctly read the alignment and alignment repeated several times until you get it right.
Check the alignment with cartridges in excellent condition.
Feb 28, 2012 | HP Photosmart C3180 All-In-One InkJet...
On an HP PSC 950, I'm getting a repeated "Press Enter to Align Cartridges" message when I try to copy. Got a response from a previous expert that wasn't even applicable to this model, and no response...
hello, the reason your printer is constantly trying to align cartridges, is it did not complete the alignment, machine must complete alignment, so this message will go away, this machine requires all #15 black ink cartridge and #78 color ink cartridge, it requires the color ink to be working since it uses either yellow or magenta ink for calibration,also black ink has to working for this to work. now if the ink cartridges are known good ink or printing ink cartridges, then the problem maybe the sensor that detects the color when it prints, you may try with a soft wet or damp paper towel, when cover is open as if you are replacing the inks, unplug printer from power, move carraige to left alittle bit more, on the right hand side of carraige, you might see a black piece of plastic, behind that is the sensor, use the wet towel and wipe the bottom part of carraige and sensor, do this several times. now go ahead and close machine and power up, see if machine will pickup paper, print the calibration page. if all is working it should pass.
Oct 06, 2010 | HP PSC 950 All-In-One InkJet Printer
My HP Officejet 4500 keeps telling my to align my printer cartridges and I have done it several times. After I align them and print something it requires me to align them again.
Try removing the cartridges, closing the printer, and disconnect the power. Let sit for at least 10 minutes, then hook up the power, wait until it stops making noises, the reinstall the cartridges, black first, then color, and if the alignment comes up again, press cancel. This should remove the error.
Sep 30, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Cartridge alignment
Put a teeny tiny bit of oil (3 in one on fingertip) all over the slide (chrome bar that you see looking into the printer from the front) and retry. Just a thin film, NOT enough to drip.
The self test and align 'scan and print' procedure is timing out.
Mar 27, 2009 | HP PSC 2175 All-In-One InkJet Printer
Printer won't print color only black and white
Reinsert the color cartridge. Give print command for page. Open Preferences in print window. Open the Color tab. Click on Print in Color. (It may have been set for black only.) Try printing.
May 23, 2008 | HP PhotoSmart C4180 All-in-One Color...
HP Photosmart C3100 series
I just got off the HP help line.  After changing my black ink cartridge a test page was printing each time I turned the machine on.  This is very costly, in both time and ink as the cartridges themselves for this machine hold very little ink.  I tried to learn from HP tech how to turn off the test-print while keeping my color cartridge empty.  It turns out that you cant do it.  HP requires you to keep buying and using cartridges whether you need them or not.If you buy the color ink it will use it up in its testings.  And if you dont buy the color cartridge it will use up your black ink by printing the test each time you turn on the printer.  The printer was inexpensive sure, but I'm paying for it in wasted ink.
Dec 26, 2007 | HP Photosmart C3180 All-In-One InkJet...
Printer will not copy
It Does keep asking if it fails to get it right, usually it fails to get scan of alignment page completed correctly because it fails to see one of the colours printed on its alignment page correctly,
I would guess that you should change colour cartridge as well (these I have seen deplete themselves trying print black when black ink is not present.
There is also a way of telling your printer to forget about alignment would you like to know how......Press and hold the Setup button, and then press Options (or Copy Options ).
Here is a link to how an alignment page should look and HP answers to your problem, please rate my solution for me.
Nov 21, 2007 | HP PSC 2175 All-In-One InkJet Printer
HP OfficeJet G85 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
