Question about Dualit Kitchen Appliances - Others
When I turn on my Dualit toaster, it trips the whole circuit. Is this because one of the elements might have burnt out?
    Genius:
  • 1,456 Answers
Hi there
The following might be the cause;
Thermal Resistor;The first potential area of trouble could be that the toaster has a defective thermal resistor. thermal resistors control the heater in the unit. If the thermal resistor is defective, it will not turn off the heating components in the toaster, which will cause the toaster to continually heat up. As it keeps heating, it keeps drawing power, which will trip the breaker.
Remove the toaster connections to it and test its conductivity with an Ohmeter. If there is no reading, the resistor is defective and needs replacement.
Faulty Circuit Breakers;
If the toaster is tripping the circuit breaker, it's possible that the circuit breaker itself is malfunctioning. Circuit breakers trip as a safety precaution to prevent an electrical circuit from overloading or shorting. If an electrical circuit was to overload or short, it could lead to a physical damage even electrical fire. If a circuit breaker is not working, it can repeatedly trip because it is not able to handle normal electrical draw. Circuit breaker replacement is not difficult and household circuit breakers can be found in local hardware stores. However, due to the electrical danger involved, contact an electrician to fix it.
Loose Electrical Connections
There could be a loose connection in the outlet. A loose connection in the outlet could consist of wiring that is not functioning and is unable to properly manage current. The current needed by the toaster is being mishandled by the loosely connected outlet and drawing more power from the electrical system, tripping the circuit breaker. Once again, an outlet can be replaced with hardware store parts but an electrician is best suitable to fix it, due to the dangers of electricity.
Posted on Oct 02, 2010
It blows the whole circuit
You will probably discover that a heating element has shorted. The solution is to repair or replace.
Dec 09, 2013 | Dualit Vario 4 Slices Toaster
1978 ge toaster
Their website claims that the ProHeat elements fit toasters made in the last 50 years...
I would say take the thing to a good electrician, and she can inspect one of the ones that still works, compare it to the one that burnt out, and come up with some sort of fix...
Nov 19, 2013 | Dualit Kitchen Appliances - Others
Dualit toaster short circuit
Is not an open curcuit but a short curcuit. Means that one of the wire conections you have made is either contact with toasters body or one contact is touching with other contact. So you need to have all contacts of the toaster from the bottom side to see if their are clear to each other or from the toasters body
Oct 09, 2012 | Dualit 20084 2Slice Toaster
Dualit Toaster trips RCD on consumer unit as soon as the timer switch is turned
One of elements, or one of the wires have be cut and is touching the metallic body so you need to replace the element or wire
Mar 09, 2011 | Dualit 20084 2Slice Toaster
Dualit toaster - timer sticking.
The dualit all electrical parts like elements and timer switch are all manufacture in china and they are not as they used to be. I have a customer with a toaster of 25 years old and we have replace only one heating element up to now. For recent models we replace electrical parts in about 2 to 3 years, some times every year as you describe.
Feb 22, 2010 | Dualit Vario 3 Slices Toaster
Out Dualit toaster keeps blowing the fuse. It's
Probably one wire Loosen up or a wire from one heating element have cut off and is contacting the metal body of the toaster. You need a good visual insect of your toaster, you may use a flush light to see inside the electriacl elents and also open the bottom base to insect the wire conections to the heating element.
I beleive one or more heating elements is the problem and you need to replace them.
Good Luck
Feb 01, 2010 | Dualit CTS4E 4-Slice Toaster
Dualit 4-slot toaster - is this how it's supposed to work?
your toaster is working correctly if both are off you are in BAGEL/BUN mode ( did i spell that wrong ? ) in that mode it will only toast the cut side .... Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 02, 2009 | Dualit Vario Combi 2x2 65-Slice Toaster
Dualit combi heating element 12/95
All the element's are available on e-bay u.k. for about 6.00 gbp. Alternativley you may be able to repair it. Put the toaster on it's side with the bottom facing towards you and the knobs on the top. Remove the crumb tray and then remove the bottom (usually the screws are located in the feet). There may be one more visible screw remove that too, then you will see a rail at the bottom that secures the element's in place. Loosen off the nuts at each end and slide the rail down, undo the two bolt's feeding the power to the element's and slide the element out.Go over it with a continuity meter and see where it's broken then move the element wire about to bridge the circuit.Test it again and reassemble. I repaired mine this way.Or, simply replace the element using the instructions above.Easy!
Sep 18, 2008 | Dualit Vario 3 Slices Toaster
Need replacement dualit 2 slice toaster elements
You can get any part you need at the Dualit Repair Center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Jan 22, 2008 | Dualit 20247 2-Slice Toaster
Kitchen Appliances - Others Logo
943 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Ross Keen
Piyal Perera
Piyal Perera
Joseph Hoffmann
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
