Question about Remington High Precision PG400 7in1 Grooming Kit Beard Trimmer
Hi need spare part for my remington pg400 (mini screen shaver) thanks s degsy
SOURCE: Remington es1000
The Remington ES-1000 was probably the best slot-head shaver ever made by Remington. I cannot believe that the market demand was so low as to prompt a cancellation of production. I believe that the production run was limited to about 4 years or so. I have 8 of these shavers and keep a couple old Remington slot heads around as well. The ES-1000 was not perfect. The batteries were way too small and stressed so battery life was poor.You could not buy individual blades as you could with past Remington slot-head units.Also, the edge of the head was too exposed and sharp and when used for body shaving would tend to cut the skin.Slot-head shavers are superior for body shaving and for skin that is suseptible to shaving bumps.They are also great for young men that are prone to ingrown hairs.My guess is that the Norelco 3 head has taken it's place. Those shavers actually use 3 small slot heads. Rumor has it that shavers.com is trying to have a new slot head manufactured in Asia.
Posted on Mar 02, 2008
SOURCE: Remington MS2-250 shaver disassembly?
This shaver was pretty clearly not designed for battery replacement. To open, first remove the screen and blades, and unhook the metal collar from the tab on the back of the case. Then carefully pry off the black inset on the front of the shaver. Underneath it, near the bottom are two screws. Remove these. The case is now only held together by several plastic latches, which can be carefully pried apart with a small screwdriver. The two 2/3A size batteries are soldered to the printed circuit board, which can be pulled out (don't break the wires to the motor) by a little wiggling. The original batteries in mine are 1100mAh, and I have just ordered 1600mAh replacements. The new ones don't have tabs - so soldering them in place is probably going to be a challenge.
Good luck.
Posted on Dec 28, 2008
  • 5 Answers
SOURCE: Remington R 9170 shaver
http://www.remington-products.com/manuals/ib_mftitaniumu.pdf
In the PDF instructions it describes how to remove the batteries. The instructions fail to mention that there is a spit of yellow glue that is holding one of the batteries to the curcuit board with a death grip. Undoubtedly, you will have to use a knife, not in the glue, but on the skin of the battery. Pull on the teather wire, and slice the battery skin around the glue.
If after removing the batteries, and you are not thouroughly discusted with the manufacturer, then purchase a couple of AA Ni-cad batteries solder the positive of one battery to the negative of the other. then solder the free positive end to the red wire, and then the blue wire to the free negative end. Then try to remember how to reverse the process and put it back together, without leaving any parts out. ;-)
There is a risk of injury by overheating the battery when soldering. That should be avoidable if you remember how to drop solder. Just like its name, it involves having the wire securely held in place. Then hold solder iron over the wire/battery end. Then take some rosin-core solder and apply the solder to the hot tip. Then make sure the newly melted solder lands on the contact. Keep in place until it cools and holds the wire to the battery.
If you think this is better than writing to Remington complaining that they did not make it easier and use contacts, instead of solder, so we can simply pop in a new set of batteries. Or maybe look at other manufacturers, and see if they are any better.
SOURCE: remington shaver ms 280 screen has a hole
How do you replace (change) the screens on a Reminton MS-280?
"Paz"
Roger
Posted on Jul 10, 2009
brector3
  • 1623 Answers
SOURCE: I've bought 2 Remington shavers, the latest an
You will find batteries at shaveroutlet.com. I strongly suggest that you take a look inside your shaver to make sure that you have the skill required to mke this repair
Each of your models uses two batteries. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-shavers-p-211.html
Soldering is required.
Posted on Jan 16, 2010
Testimonial: "useful advice"
Charger cable for remmington pg-400
You will find the charger at shaveroutlet.com using the link below
http://shaveroutlet.com/remington-charging-cord-for-pg-250-and-wpg-250.html
Jun 22, 2014 | Remington High Precision PG400 7in1...
Hi there! anyone help please? i opened up my remington pg-400 to change batteries, but i pulled them out and there is only the information that the batteries are GP and rechargable NIMH.. can anyone tell...
Try the highest mA AAA cells you can find or see Maplins for the pre joined pair. You will need a steady hand and a soldering iron with a fine tip there aint much room in there. The mA wont really matter, if you get a higher rating than the originals they will just take longer to charge.
May 16, 2012 | Remington High Precision PG400 7in1...
Where do I get spare part for the Remington MS2 390 shaving foil in Perth ?
remington SP69 replacement foil screen and cutter blades for electric shaver remington ms2 390 heads replacement parts.
Jan 26, 2011 | Remington MS2-390 Electric Shaver
I've bought 2 Remington shavers, the latest an R836 to replace an earlier model R 875. Apparently if you leave these plugged in at the mains, the battery goes kaput. I haven't been able to find spare...
Jan 15, 2010 | Remington Health & Beauty
Remington HKVAC-2000 Electric Shaver
Hi beebee73
If you are referring to the hkvac2000, it is a clipperstyle shaver, where the blades, because of the cutting action, do not generally need to be replaced. I have checked on the Remington website, and they do not sell any spare part blades for this model. To se what all comes with the shaver... comb sizes etc, check out the user manual for the device here
Hope this helps you. If you need me to do some more research, just ask:) Thanks for using FixYa, a FixYa rating would be great for my efforts to get this information for you. Cheers
regards
robotek
May 08, 2008 | Remington Microflex R-860 Electric Shaver
Remington High Precision PG400 7in1 Grooming Kit Beard Trimmer Logo
294 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
