Question about Dell (E210882) Motherboard
I have 2 network cards and both show no connectivity (led remain orange). any suggestions to fix that?
  • 540 Answers
If both the cards have the same chipset then this can happen.
Posted on Oct 02, 2010
Samsung syncmaster 910N when turned on shows "check cable" and when connected to graphic card goes black. How to fix it??
you may change the vga cable for your sync master, and try another video graphics card.
one more thing, if you happen to see that your monitor led goes orange, that would only mean it needs to be replace by a new one, or a technician might help you. orange led light means, internal problem.
Dec 29, 2012 | Computers & Internet
Hi guys my Toshiba m35x s149 fell 2 feet to a wooden floor.The battery meter shows power of 63% but upon removing the power cord it switches it off.Tried another battery same response.when all is off( no...
I would think that the internal battery connections have been damaged from the fall. They may only need re-soldering. Any drop on to a hard surface from almost any height can damage your laptop.
Apr 18, 2011 | Toshiba Satellite M35X-S149 Notebook
My nokia 6730 shows white display when i insert my sim card of nepal.it was originally brought from israel-orange.
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here http://www.theunlockarena.com/nokia-6730-classic/rs13wp9/
Jan 20, 2011 | Nokia 6730 classic Cell Phone
No wireless connection for laptop. Linksys router - model #wrt160n v2
you can run a direct line to that router and go to the cisco web site and get the information you need to run that router. its a pdf format and is 2.56 Meg. Try this
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
Nov 26, 2010 | Computers & Internet
I have a compaq presario F500 and it wont connect to the wireless router. The light remains orange even when i activate the "blue light switch" on the front of the laptop. I have just installed a new...
More than likely. Especially if you bought the new card from a different company than the one that made your machine. Look on the card for model info, and google "(#model) wireless driver download".
May 20, 2010 | Compaq Network adapter
My Acer netbook will only keep an internet connect when plugged in.
This netbook has a little orange led that blinks to let you know that the wireless is turned on. Then you know you can connect to wireless networks. Take a look at the photo here:
www.geekzone.co.nz/images/news/AcerAspireOne.jpg
To the right of the touchpad, at the front edge of the palmrest (closest to you) you will see a small silvery stripe. This is where the wireless led is.
First, look and see that the little orange led is blinking. If not, slide the little switch right beside it to turn on the wireless (you should see 'wireless lan enabled' in large green print) If you can't seem to get the orange led to blink by doing this, check device manager and check that the wireless card is enabled. If it has a red X on it, right-click on it and left click enable.
If the led is blinking, but you still can't connect to wireless, see if you can connect to another wireless access point other than your own.
Let me know if this helps or not :)
Aug 17, 2009 | Acer AOA150-1690 Aspire Notebook
Modem and computer are not communicating.
Are all your connections in the appropriate place? Did you press and hold the re-set button on your router for 40 seconds and wait until all the lights are green on your router?
Jun 27, 2017 | Computers & Internet
When I connect the ethernet cable to my tower, I gave an orange light. What could be causing this to happen?
What Orange light are you refering to? You have an orange and green LED on the block of the Ethernet connecter, if the cable is plugged into the plug and the other end is terminated into another deive such as a modem,bridge,router or switch the orange light(led) should come on as that indicates a valdi link hence being called the link light, the green light(led) indicates data being received or transmitted. If orange flash with sparks(bad) from the plug it means there is power on the cable..very bad as this could be due to the ethernet card that is faulty or the device on the other end of the cable is faulty.
Aug 01, 2009 | Intel Ethernet 10/100 Network Adapter
Philips 170c Lcd star`s but it didn`t remains on
Make sure that the video card (if you have one) is firmly inserted into its slot.
Make sure that the connector from the monitor is firmly plugged into the CORRECT video slot on your back panel... Your video card may support more than one monitor and you may have it in the non default port.
Also make sure that the video driver is up to date or even installed.
As much as I hate to say it, there is also the possibility that the monitor is bad.
Feb 21, 2009 | Computers & Internet
Wireless network card in PC loses connection
The best reccomendation I might make is to stop using the manufacturer's proprietary management software. Use Windows' own built in wireless management. You can select this by selecting the network adapter in the 'network connections' control panel and checking the box that says 'let windows manage this device' That should fix the problem. Also, try getting the most recent updates for both windows and the network adapter.
Nov 09, 2007 | Computers & Internet
Dell (E210882) Motherboard Logo
20 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
