My touchpad wont work on my advent pc - Computers & Internet
  • Gregory Brown
    Gregory Brown May 11, 2010
    is it used, new, under warranty, was it working before. need more info
    Sergeant:
    Champion:
  • 326 Answers
If using vista, U may have to get the right driver from the manufacturer. Before U reinstall the device, add/remove any programs the pad cd installed and uninstall the pad at the system device manager first. and check to make sure the driver is for Ur os.
Posted on May 27, 2008
  • 86 Answers
Go in the device manager find the touchpad drivers and reinstal them
Have fun dude
My Advent 5421 Touchpad Is Not Working!!!
Advent laptop computers are equipped with a touchpad and two buttons that service the function of an external mouse. The touchpad can be turned on or deactivated, depending on the user's preference. It's not difficult to either activate or deactivate it.
Power up the computer. Connect a plug-and-play computer mouse to a free USB port on the laptop. The mouse is just temporary to help you get the touchpad working again. Locate the touchpad icon, which is in the lower right-hand side of the screen. The icon will appear as a gray square or rectangle, with two rectangular buttons underneath. Use the mouse to double-click on the touchpad icon, opening a window on your laptop screen. Inside the touchpad window, click the option labeled "Enable Device". Select other options for the touchpad, such as pointer speed and shape. Click "Apply", then "OK". Disconnect the mouse from the laptop.
Feb 02, 2013 | Advent Computers & Internet
How do I disable touchpad
usually you have to press both Fn ( the blue button next to the right control button ) with F7 button . if it doesn't work please specify what is the brand of your pc and which model .
Jan 23, 2013 | Advent Modena M101
Advent monza mousepad working poorly
If you have a Advent Monza N3 Laptop, to disable the touchpad it is use the function key called fn. Keep this key pressed and also press f6. This toggles the totouchpad on/off.Good luck
Dec 11, 2011 | Advent Computers & Internet
The touchpad on my laptop wont scroll, i have tried synaptics drivers but this doesnt solve the issue. My laptop is an advent 8555GX.
Hi. Try uninstalling and re-installing your Touchpad driver from the device manager and reboot your system.
^_^
May 18, 2010 | Computers & Internet
Advent 5401 left touchpad button broken
Had a similar problem a couple of months ago, The left button started playing up, not working with every mouse click, it gradualy got worse till it was nearly unusable.. I suspected that the microswitch under the silver button had some dirt in it. After taking a deep breath I removed the battery and the screws that hold the case lower and upper halves together and was able to seperate the case front by about 3/4 of an inch. Then using a contact cleaner Servisol Super 10 and supplied flexible straw I squirted cleaner into both mouse click buttons. After waiting for cleaner to evaporate and resecuring case halves and replacing battery I switched on .... The button works 100%..
Feb 02, 2010 | Advent Netbook
Advent 4211 netbook touchpad not working
Go to the device manager and remove the device. let windows reinstall it for best results
Dec 24, 2009 | Advent 4211c Notebook
THE LEFT BUTTON LIGHT STAYS ON ON THE TOUCHPAD
this is due to a faulty touchpad. it needs replacement. call the manufacturer.
Aug 04, 2009 | Advent Netbook
Disable track pad when using the mouse on advent 6311
Do you want to disable the onboard touchpad while you use an external mouse?
To do this there should be a key sequence on the laptop like Fn+ F8 (or another key) it has a mouse symbol on it.
May 11, 2009 | Acer Aspire 3680 Laptop
Mouse pad not working
A mouse pad is a thing you put your mouse on....
now what you are talking about is your touchpad.
Check these first:
  • some laptops have a switch that turns off the touch pad (usually a button right on the topside of the touchpad)
  • did you reboot completely? full shutdown, then power on?
  • goto the device manager (with a usb mouse of course) and find the touchpad... delete the device... then reboot again it should try and find the touchpad and ask for the driver, point it to the directory that you have the driver located.
good luck!
Apr 21, 2009 | Computers & Internet
Istalling mouseb has turned off touch pad ?
This usually happens so you dont have 2 mice running at once. Unplug the new mouse and your touchpad should come back.
Mar 12, 2008 | Recoton Advent Advent Q2035A 20" TV
Open Questions:
Cloud Backup, Data Recovery, Data Backup, Cloud Back up Solutions 'Dataalign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Cloud Backup For Small Business technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Online Backup Pricing is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Server Cloud Backup Solution up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
Apr 23, 2018 | Quantum Computers & Internet
Computers & Internet Logo
138 people viewed this question
David Payne
David Payne
