Question about Vacuums
Manual for creda 79151/141/143 storage heaters
I stored my FH50220 in my storage unit over the winter and now it will not spray water
If your storage unit got below freezing it may have frozen and damaged something. It's hard to drain all of the water from pumps, tubes, valves, heaters etc. inside a carpet cleaning machine. If a machine must be stored where it may freeze one way to keep it from freezing up is to pour automobile windshield washing solution into the fresh water tank and run it through the machine until it comes out all of the Jets and cleaning attachments. Remove the fresh water tank and continue to run the solution through the machine to flush the windshield cleaner out of the machine. Be sure to use a cleaner with the proper anti-freeze rating and run fresh water through the machine before using it to clean carpets.
Apr 01, 2016 | Hoover FH50220 Vacuum
Stops
I had the same problem when I renovated my kitchen. With boxes of stuff everywhere it was impossible to use Roomba. When I tried to use it again a few months later, it would stop after only a few minutes work. I had to buy a new battery which cost in excess of $100. Its better to loan it to a friend to be used than to put it into storage.
Apr 30, 2013 | iRobot Roomba 530 Robotic Vacuum
Bissell 8920/9500 ProHeat 2X The Floor Cleaner base doesnt spray any liquid. I would take the base apart(and possibly trigger assembly), but the manual does not cover disassembly and assmbly of the tubes...
I just repaired my Bissell 8960 no spray from the base or the flex hose nozzel. Tried to find a diagram or service manual online but no luck. I removed the 2 jets that spray on the brushes and
there was small pieces of silt that would plug them up. only used this unit twice before but it's been
sitting in the basement for a year. anyways ending up takeing the unit all apart. All of the items you
need to get to are in the base not in the handle sections (except of course the spray switch) I put the whole thing on my large work bench to make it easier to work on. If you do take it apart make sure to take alot of pictures or you may not get it back together again. I labeled the hoses with different colored tape and was glad I did.The main problem was the 700 watt heater that is in the very bottom of the base. it was filled with white specs of silt. the heater can be removed and opened up so you can wash it out with a water and a brush. We have city water here thats supposed to be pretty good but know I know why the wife uses distilled water in her iron. Thats what I will be useing from now on in the Bissell..
Apr 05, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
Error 1203 on a Dell Printer - what is this?
2080 1203 2055...Critical / Failure / Error...2080 1203 2346The Storage Management Service performs alert monitoring and logging. By default, the Storage Management Service starts when the managed system starts up. If you stop the Storage Management Service, then alert monitoring and logging stops. Alert monitoring does the following:
  • Updates the status of the storage object that generated the alert.
  • Propagates the storage object's status to all the related higher objects in the storage hierarchy. For example, the status of a lower-level object will be propagated up to the status displayed on the Health tab for the top-level Storage object.
  • Logs an alert in the Alert log and the operating system (OS) application log.
  • Sends an SNMP trap if the operating system's SNMP service is installed and enabled.
    http://search.dell.com/results.aspx?s=gen&c=us&l=en&cs=&k=Error+1203&cat=sup&x=10&y=12
Mar 23, 2011 | Vacuums
I have a McCulloch Model PM 310 , Gas Chainsaw. How would the spark plug be accessed?....Rich
Storing a chain saw for longer than 30 days requires storage maintenance. Unless the storage instructions are followed, fuel remaining in the carburetor will evaporate, leaving gum-like deposits. This could lead to difficult starting and result in costly repairs. Never store a chain saw for longer than 30 days without performing the following procedures:
Remove the fuel tank cap slowly to release any pressure in tank. Carefullydrain the fuel tank.Start the engine and let it run until the unit stops to remove fuel from carburetor. Allow the engine to cool (approximately 5 minutes).
Using a spark plug wrench, remove the spark plug.
Pour 1 teaspoon of clean 2-cycle oil into the combustion chamber. Pull starter rope slowly several times to coat internal components. Replace spark plug.
Store the unit in a dry place and away from possible sources of ignition such as a furnace, gas hot water heater, gas dryer,etc. When removing the unit from storage, be sure to perform the following procedures:Remove spark plug. Pull starter rope briskly to clear excess oil from combustion chamber.Clean and gap spark plug or install a new spark plug with proper gap.Prepare unit for operation.Fill fuel tank with proper fuel/oil mixture.
This will help. Thanks, please keep updated. please do rate the solution positively .thank you for using fixya
Dec 15, 2009 | McCulloch MC1275 Steam Vacuum
My shampooer will not release water when i push the release button on the handle
noavatar_s.gif xpinto
Rank: Apprentice
Rating: 0%, 0 votes
I wasted a lot of time following the expert advice to repair my unit by taking the cover off of the main unit and using compressed air to blow out the lines. The problem turned out to be in the lower panel of the handle (4 screws to remove). The heater is a large block of aluminum with a stainless cover held on by screws. The lower nozzle of the heater was blocked by water/soap reacting with the aluminum while in storage. Blowing out the lines as recommended with air compressor just warped the stainless cover resulting in time spent flattening this back into shape.
I would recommend the following steps:
1. Make sure that fluid levels are up in both the supply water bladder and the soap dispenser.
2. Pry off the left side access cover and ensure the pump drive belt is still in position. Switch the unit on and see that the pump is spinning.
3. With the unit plugged in and the handle laying flat on the floor (using the foot release lever) , remove the clear bezzel over the red impeller, switch the unit on, and pull the trigger for soap. Liquid stream should shoot straight up past the impeller. If not the lines are plugged somewhere.
4. Unplug the electric power. Remove the four screws and remove the lower handle access cover (with the red light in it).
5. All the fluid lines are clear plastic so you can identify which have fluid movement.
6. Disconnect the line from the soap activation switch (pliers on the squeeze hose clamp) feeding the heater (large aluminum block). Blow air (with your mouth NOT the air compressor) into this line and see if fluid movement is observed in the clear plastic lines. A little tentative about soap in your mouth, use a turkey baster filled with water). I saw no movement of liquid. Nozzle exiting the heater blocked.
7. Remove this hose and use a small drill bit to twist the debris loose. You may elect to remove the heater shinny cover for better access. Gaskets are reusable. Blow thru the hoses again to assure blockage cleared.
8. Button unit up.
9. With the clear bezel off and the red rotor exposed, plug unit in, soap and water supplies in place, switch on power and pull soap trigger. Should see vertical stream. Mine was about 5 inches initially then jumped to about 10 inches high. Knew blockage was cleared.
10. During shampoo operation if soap stops (red impeller stops spinning) first check fluid levels and fill. That doesn't work, I unscrewed the clear bezel and pulled the soap trigger with the unit switched on. Less than a second vertical stream appeared every time.
11. Now you know how to fix and achieve continuous operation.
12. The unit must be thorougly cleaned before putting it away for storage to prevent the reoccurance of the blockage in the heater. After following the manufacturer's instructions, by flushing (operating the unit) with clear water in the bladder and the soap dispenser, I did one final thing. By removing the fresh water storage/collection plastic container, a black round fitting is exposed that channels the water from the bladder into the spray system. I used a length of automotive heater hose that was the same diameter as the seal on this fitting (turkey baster with bulb off will work) and blew hard while the unit was switched on and the clear bezel was off. One last big blast of water spewed from the unit. This cleared all the lines from the bladder through the pump, switch, and heater and blows it out just prior to the spray nozzles.
This is long but specific.
Not so technical, take each step as presented.
Good luck.
Plano Tx
Nov 06, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Sometimes the flow indicator doesn't spin even tho it has solution. I've tried loosening & tightening the lid. what else can I try?8910 Bissell proheat
Rank: Apprentice
Rating: 0%, 0 votes
8. Button unit up.
Good luck.
Plano Tx
Oct 13, 2009 | Bissell 8910 ProHeat Clear View Upright...
Vacuums Logo
353 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
