Question about Husqvarna Designer I
The bobbin willot come free from the spindle - Husqvarna Designer I
  • 201 Answers
It is possible that the bobbin was wound too fast and the plastic has overheated and expanded. There's nothing for it but to pull all the thread off and then try again - gently - to remove the bobbin. If it still won't come off, get some pliers and very very carefully remove the bobbin by breaking it piece by piece. Take care not to let any of the pieces fall inside the machine. Once you have freed even part of one side it will most likely come off without the need to completely break it up.
Whenever you wind a bobbin, reduce the speed of the motor by three clicks. It does not say this in the manual, but it is a wise precaution.
Posted on Oct 05, 2010
Testimonial: "how do i reduce the speed?"
Singer 3232 machine was sewing fine now motor runs but needle does not move up and down
Check if the machine is in the bobbin winding mode. To wind the bobbin, the bobbin spindle has to be moved to the right. (The hand wheel will not turn if the bobbin spindle is in this position.) If it is, move the spindle to the left.
If the hand wheel turns, then check for a thread jam. Remove the top thread and take out the bobbin case. Gently turn the hand wheel forward and backwards until the thread comes free of the hook in the bobbin race. Follow this by cleaning any lint from the bobbin race of the sewing machine.
The last possibility is that the belt has failed. This belt transfers the energy from the motor to the needle bar. One source of the belt is http://www.sewingpartsonline.com/motor-belt-singer-007158xxl5.aspx . You can find YouTube videos on changing the belt. There are other parts that transfer the forces form the belt to the needle bar. However, I suggest you find a good sewing machine mechanic if any of these parts fail.
The manual has good pictures of the bobbin spindle on page 11 (page 18 of the PDF). Singer has the manual on their support page: http://www.singerco.com/support/instruction-manuals . The direct link to the manual is http://www.singerco.com/uploads/download/e06cb85928ace9753f1a7124f4a2df6168ffecf0.pdf .
I hope this helps.
Jul 28, 2017 | Singer Sewing Machines
Brother VX1100, the spindle on which to fill the bobbin is not turning, so I can't fill a bobbin. Any advice?
If you can see down the spindle, check to see if any thread is caught that would prevent it from moving. If there is nothing caught, you can put one drop of oil on the spot where the spindle and the housing in which it rotates meet. If it is free to turn by hand, but won't turn when engaged, the tire may need to be replaced.
Jan 06, 2017 | Brother Sewing Machines
Singer curvy
Three possible causes: 1.Bobbin not push fully down the bobbin winder spindle
2.Need to push bobbin winder spindle to the left before you can wind the bobbin
3.The bobbin winder spindle rubber ring has worn out. This will need a local technician to fix it.
Aug 16, 2013 | Sewing Machines
Bobbin stuck on bobbin winder spindle
you might have to use some force but not enough to break
the bobbin winder spindle. it's also possible that there is something
wrong with the bobbin for it to get stuck on the bobbin winder spindle
like that.
Nov 29, 2012 | White Sewing 2037 Mechanical Sewing...
What's your problem?
if the bobbin thread is winding around the bobbin winder spindle then
the bobbin is not sitting correctly on the bobbin winder spindle,,
the bobbin (metal or plastic) should lock in on the bobbin winder spindle
& the the thread should be around the bobbin tension guide
Apr 04, 2012 | Sewing Machines
The bobbin spindal won't turn to put thread on the bobbin?
Either the winder rubber is worn down one side, or, the spindle has seized which is quite common because of the fast speed they wind in which case you need to put a few drops of WD40 on the spindle and let in rund down, get an ordinary electric drill and put it over the spindle and slowly start the drill to free it off.
Feb 12, 2010 | Kenmore Sewing Machines
Bobbin rewind problems
Either the winder rubber is worn down one side, or the spindle has seized, take the top off and check and see if you can turn the winder by hand, if not then it has seized and the only way to free it is to put a couple of drops of WD40 on the spindle, put an electric drill on the end of the spindle and start the drill very slowly.
Feb 07, 2010 | Singer 8280 Mechanical Sewing Machine
Bobbin spindle won't spin
Check the bobbin winder rubber, it may be worn or broken and insufficient friction against handwheel to turn.........or a thread jam around spindle is stopping the spin. In this case, carefully unwind, DO NOT cut thread.
Sep 01, 2009 | Necchi 3537 Mechanical Sewing Machine
Winding bobbin- elna
The bobbinwinder spindle is on the top of the machine on the right.
Try to turn the spindle with your fingers. If it is turning easily, good. If not, see below.
Push the spindle to the right and it should turn when the handwheel turns.
If the spindle does not turn properly, remove the two screws that hold the top cover on. DO NOT REMOVE THE SCREW THAT IS ON THE SMALL BLOCK NEXT TO THE BOBBINWINDER SPINDLE.
The top cover will not remove because of the handle. While lifting up the cover, peer under to make sure that there is a small rubber tire on the under side of the bobbinwinder spindle.
If the tire is there, place a small drop of oil on the spindle and turn it until it frees up. Try not to get oil on the tire, it will make it slip. Wipe it off if it gets oily.
Replace the top and retry.
Jul 26, 2009 | Elna 2007 Mechanical Sewing Machine
Kenmore 15516 bobbin
1. Remove the bobbin case
2. Release the clutch by pulling out the handwheel
3. Draw the thread from the spool andguide the thread throught the hole in the bobbin from the inside to the outside
4. Put the bobbin on the bobbin spindle
5. Push the bobbin to the right
6. Hold the free end of the thread and depress the foot control, wind until full
7. Push the handwheel in (to wngage the clutch)
8. Push the bobbin spindle back tot he left to resume sewing mode.
9. Place the bobbin in the bobbin case (thread should feed clockwise)
10. Draw the thread through the slot in the bobbin case
11. Continue to draw the thread under the tension spring and through the opening Pull out about 4"' of thread
12. Holding the latch open position the bobbin case into the shuttle and release the latch
13. Case should lock into place when released
Hope this helps!
Bonnie
Sep 27, 2008 | Kenmore 15516 Mechanical Sewing Machine
Sewing Machines Logo
53 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
