Question about Dell POWER SUPPLY Power Supply
Is a fuse fitted on the PS 5161-7DS - Dell POWER SUPPLY Power Supply
My running lights dont work. keeps blowing fuses
I would take out the bulb and make sure the bulb and terminals are clean on both sides of the vehicle, then make sure you have the right fuse fitted and we'll cleaned contact ps after that get some one with a multimetre to check the electrics with that colin
Jun 10, 2017 | Cars & Trucks
Where is the fuse for the power steering,, its not marked on the fuse box
First, your car has to have electric power steering fitted (other wise it will be the usual hydraulic PS system ) and secondly, you have not mentioned the year, brand and model of vehicle you have.
Dec 18, 2015 | Cars & Trucks
I need the original routing of the V-belts with power steering and air for a 1971 ford 302.
Im not 100 % sure if that combo will work but if you have any contacts with any classic car clubs and they have southern car models that had that option in 71 should steer you in the right direction
Dec 10, 2015 | Cars & Trucks
My hp 1320 laserjet printer is not powering, i open the printer and check the wiring and i see everything normal. try to check if they are properly fitted and did not see anything improper.
Hello:
Check the main fuse if the unit blown especially if the unit is totally dead meaning no light on the main panel comes on. You may of had a power surge that blew the fuse. If you find the fuse good and the unit still does'nt power up then you have a power supply problem or something external of the PS is loading it down.
Sep 22, 2011 | HP LaserJet 1320 Printer
I have a whirlpool had a tech come out to look at it, it needs a fuse. he said it will be $65 but i found the same part online for $17. is this guy ripping me off?? ps the part # is W10258275 it is a...
Did he say it would be $65 for the fuse or for the fuse and labor?
If he's charging $65 for just the fuse then he's ripping you off. If his quote includes labor, then it's a fair price as the tech will have made 2 visits to you.
If you're unhappy with his price for the fuse and you are CERTAIN this part will solve your problem, you could buy the fuse and fit it yourself if you are competent - or pay a different tech for fitting only, with the part supplied by you.
Hope this helps.
Oct 28, 2010 | Whirlpool 24 in. DU1148XTP Built-in...
Won't turn on - PS light on but no PS fan
Surely sounds like the power supply is in need or replacement, or fuse replacement at absolute least.  the fuse that you will be in search of will be located inside of the power supply unit.  Use caution when working inside the power supply.  If you don't see a fuse in the power supply, OR you come to find that the fuse is not damagaed then you will likely need to replace the power supply.
Regards,
Joe
May 07, 2009 | Computers & Internet
On 98 intrigue water pump removal how do i clear the ps pully
Im not sure what engine you have since this information was not provided. But the Power Steering Pump pulley usually has some 'holes' on the pulley in which you can get a wrench through to loosen and remove the bolt.
Dec 29, 2008 | 1998 Oldsmobile Intrigue
Chieftech HPC-360-102 Power Supply dead
check the size of power supply most are a standard size some from propriety manufacturers are smaller. most are fitted top of case at the back and take up the space across the back about about
6inch wide 4 inch high 6inch deep if yours is this size its standard and most should fit get one that is rated at least 400 to 500 watts
ensure it has at least 6 4pin power sockets floppy power socket and the same motherboard sockets as your old one
Mar 10, 2008 | Chieftec (ADX-01GNDU/SPX-02GNF) ATX...
Blows fuse with no load
Sure sounds like your power supply has a short and should be replaced.
Oct 30, 2007 | Codegen POWER SUPPLY CG|PS-350XA-12 RT...
Dell POWER SUPPLY Power Supply Logo
292 people viewed this question
Alun Cox
