Question about Cameras
Hi, without warning my camera S5800 view screen displays "! PROTECTED CARD" and does not allow me to access any functions, what can I do Chris
    Brigadier General:
  • 3,006 Answers
Your camera can use either SD or xD memory cards, but the error message you're getting only occurs when using SD cards. As this is such a common error I hope that you don't mind if a paste my generic answer below: no point in me re-inventing the wheel!
Your camera uses SD memory cards. On one edge is a slider switch: towards the electrical contacts is the unlocked position and away from them is locked.
Unfortunately, the switch is easy to move accidentally and it's also easy for it to appear to be unlocked when it isn't. Like any mechanical component it's also possible for the switch to fail.
If the switch is in the locked position then slide it fully to the unlocked position; if it's already in the unlocked position, slide it fully to the locked position and then fully back again. There should be a soft click at each end of the switch travel, if not then the switch is definitely faulty or obstructed.
If that fails, then try looking closely at the switch in both positions to ensure that there is no debris obstructing its movement, if not then check the electrical contacts to ensure that they're completely clean and grease-free. Don't touch the contacts with your bare skin, but if the contacts need cleaning then a cotton bud (Q-tip) moistened with a little alcohol or methylated spirits can be used to clean them.
If you still have no fix, then try a different SD card as yours may have an irreparable faulty switch. If the card does prove to be faulty then on most major brands you may be able to return them to the manufacturer for exchange: I've found that they will often do this on a goodwill basis even if the card is out of warranty.
If all options regarding the memory card are unsuccessful, then you have a faulty camera and further remedies require either a professional repair or replacement of the camera.
I hope you manage to use this information to solve your problem. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Posted on Oct 02, 2010
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
What is a protected card
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 23, 2014 | Fuji Finepix S5800 Digital Camera
What does it mean when it says "protected card"? How do I change this?
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
My Fujifilm S5800 displays the following message..'card not initialized'. And will not allow you to do anything. Can anybody shed some light on this? thanks
My manual sugests the following for that error:
The memory card or internal memory is not formatted or the memory card was formatted in a computer or other device.
Fix: Format the memory card or internal memory using the Format option in the camera setup menu option.
The memory card requires cleaning.
Fix: Clean the memory card contacts with a soft dry cloth. If problem persists, format the memory card.
Camera malfunction.
Fix: Contact a Fuji dealer.
Hope this helps.
Feb 21, 2010 | Fuji Finepix S5800 Digital Camera
Protected card warning
the SD Memory Card switch is to the "Lock" side. (remove memory card)unlock the protection by sliding it back (u can c a small switch in the side of memory card)... this has to work.... happy photography.....
Sep 21, 2009 | Fuji FinePix J10 Digital Camera
Canon rebel xsi gets message card write protected with or without sd card
hi, when i turn on my camera the screen says card write protected? and I can't take pictures on my canon xsi
Jul 23, 2009 | Canon Rebel XT / EOS 350D Digital Camera
The date is displaying on my pictures for our business we do not want this to happen, it just started displaying recently, we have a DC50 zoom camera, top of the line but very outdated
Press Menu, autourg00778004id1973498.jpg to highlight Setup, then OK to access settings Options Return to previous menu.
Camera Sounds
Choose sound effects.
All On (default)
Shutter Only
All Off
Auto Power Off
Choose inactivity time until camera turns off.
10 minutes
5 minutes
3 minutes (default)
1 minute
Date & Time
See Setting the language, date/time.
Date Stamp
Imprint the date on pictures.
Choose a date option, or turn off the feature. (Default is off.)
Video Date Display
Display Date/Time at the start of video playback.
On (default)choose from date formats.
Off
Blur Warning
See Understanding blur warning icons.
On Off
Language
Format
caution.gif CAUTION:
Formatting deletes all pictures/videos, including those that are protected. Removing a card during formatting may damage the card.
spacer.gif Memory Card - deletes everything on the card; formats the card.
Cancel - exits this setting.
Internal Memory - deletes everything in internal memory including email addresses, album names, and favorites; formats the internal memory.
About
View camera information.
Jan 05, 2009 | Kodak Digital Science DC50 Zoom Digital...
Brand new camera - no image in view finder
Have you tried to format the camera? Alternatively, and don't mean to sound rude but have you taken the lense cap off?
Are you getting any menu options on the lcd screen or is it totally blank? If this is the case then likely there is a problem with your camera and you should speak to who ever you bought it from.
Good Luck.
Dec 03, 2008 | Fuji Finepix S5800 Digital Camera
Can't download images: Finepix S5800
you need to update the drivers on your computer by the sounds of things. Or alternatively re-load the software disc for the camera.
Good Luck.
Sep 15, 2008 | Fuji Finepix S5800 Digital Camera
Fuji FinePix 3800 Initialization glitch
Turn camera from "off" to "play" ( photo view..._
Pressing the “MENU/OK” button as you would to erases files. There is an option to format the xD-Picture Card. Formatting erases protected files, but allows you to then take photos.
Nov 15, 2007 | Fuji FinePix S7000 Digital Camera
Cameras Logo
29 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
