Question about Canon MP970 Photo All-In-One InkJet Printer
U52 the type f print head is incorrect - Canon MP970 Photo All-In-One InkJet Printer
SOURCE: Canon Mp 610 error u052 incorrect print head
Hi I have U051, and U052 coming up, I did what it said to do press ok if that doesn't work turn it off, now it is continuously going to these problems. What do I do.
Posted on Mar 17, 2009
komguy
  • 2306 Answers
SOURCE: incorrect printhead
It just means that the printhead is defective, All of the Canon machines say that when the printhead goes out.
Posted on Jul 27, 2009
komguy
  • 2306 Answers
SOURCE: Error msg - Print head is incorrect.
The printhead has gone out, you need a replacement, # QY6-0059-000. Around $50.00
Posted on Aug 03, 2009
SOURCE: cannon MP510 printer has Error, - The type of print head
I solved this on mine by removing and reinstalling the print head.
1. Remove and set aside the ink cartidges (don't make a mess)
2. lift the gray print head lock lever that is to the left of where the ink cartridges go.
3. Lift out the print head out without touching the ink ports inside, the contacts on the back, or the print nozzles on the bottom. The print head is the grey thing with circular ink ports that seat the ink cartridges. there are good pictures in the PDF of the Easy Setup Instructions available on the Canon Printer website. Look under the printer, then support, then downloads: http://gdlp01.c-wss.com/gds/0900002776/mp510_esi_us_v2.pdf .
4. Put the print head back in, lock the lever, reinstall the cartridges in the roper positions. And voila!
If this doesn't work you may actually need a new print head.
Posted on Nov 11, 2009
SOURCE: I have a Canon PIXMA MX 860. Why am I getting U052
says code uo52
Posted on Sep 05, 2010
Errr u052 cannot print .
A lot of Canon printer's users come across with the error message, "U052 This type of print head is incorrect." It is a very common error on Canon printers and is fairly easy to troubleshoot.
There are two different scenarios related to U052 kind of error message.One is where the print head is not installed at all and then it is giving the 'U052 This type of print head is incorrect' error message.
And, the second scenario is where the print head is installed nut it is not functioning properly or probably not working at all. The below section will show step by step troubleshooting of both the scenarios.
Jun 19, 2014 | Canon MX882 All-In-One InkJet Printer
Error code u52
3. Lift out the print head out without touching the ink ports inside, the contacts on the back, or the print nozzles on the bottom. The print head is the grey thing with circular ink ports that seat the ink cartridges. you can find good pictures in the below service manual get it it will be helpful you can download it from the below link:
http://goo.gl/abjVvi
good luck
Jul 27, 2013 | Canon PIXMA MP780 All-In-One InkJet...
Alarm tyoe of print head is incorrect
its usually part of the replacement ink cartridge, are they original inks or 3rd party
Jul 15, 2010 | Canon PIXMA MP830 All-In-One InkJet...
The type of print head is incorrect. Install the
yes . put exactly the cartridge that is compatible with your printer , make sure that you are replacing with the one that has the same number on it as that of the previous cartridge
Jul 07, 2010 | Canon Pixma MP500 All-In-One InkJet...
REPLACED PRINT CARTRIDGE NOW STATES THE TYPE OF PRINT HEAD IS INCORRECT.
Canon support suggests that perhaps your print head needs to be reseated. This would be too complicated to explain, plus the documentation at Canon support has pictures to help you perform this task.
You must be willing to use the "Search" feature in order to view this solution. Type in the question:
"The type of print head is incorrect" > Click <Search>
Canon MP830 Reseat Print Head
Dec 21, 2009 | Canon MP830 All-In-One Printer
I have problem with my mp600, in the lcd displayed error code u52. how to fix it?
This means The type of print head is incorrect. Install the correct print head." U052
The solution is follow the directions given in the Easy Setup Instructions to install the Print Head.
If the Print Head is already installed, remove the Print Head once and then reinstall it.
If the error is not resolved, the Print Head may be damaged and may need replacing.
Oct 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
The type of print head is incorrect. install correct print head
That happens when the printhead goes out, you'll need a new printhead,QY6-0075-000 around $50.00
Aug 11, 2009 | Canon MP610 Photo All-In-One Printer
The type of print head is incorrect, please install the correct print head
patchiepoops,
make sure everything clicks. canon is known for their ''slide and click fittings''
don von gideonberg
May 28, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Says: The type of print head is incorrect.
I received a suggestion from one of your techs to clean the gold contacts with distilled water using a cotton swab. It worked. Thank you.
May 14, 2009 | Canon Pixma MP800 All-In-One InkJet...
Canon MP970 Photo All-In-One InkJet Printer Logo
176 people viewed this question
old marine
old marine
