The router keeps on disconnecting, too hurting and I have a lot of clients! Only works after I shut it off.
  • 32,281 Answers
A wireless router that keeps on disconnecting can be caused by any one or more problems. Please click on this link and follow my instruction to determine the cause :-
Normal 0
http://www.fixya.com/support/r3559120-wireless_router_disconnecting
Posted on Oct 02, 2010
Netgear router DN2200/wireless problems.
that really shouldn't hurt it unless it included a pretty nasty fall as he tripped over the cord.
are you certain it still has the correct power cord? i've seen people accidently switch the modem power cord and the router power cord and the router tends to not like that.
good luck
Mar 15, 2013 | NetGear DGN2200 Refurbished WirelessN N300...
How many pc's, laptop's & printer's can i link up to belkin n1 vision wireless router model f5d8232-4
You can uplink a fairly good number of PCs or laptops with Belkin N1 as it supports high bandwidth. Keep in mind that upon adding every new PC, the overall bandwidth for the other PCs is reduced. If the PCs/ laptops do not require much bandwidth, you can connect / add more PCs to the network.
Generally, I have uplinked upto 10-15 clients to one router and the network worked just fine. It all depends upon the network environment and the bandwidth usage by each client PC. If the PCs are using just email and simple internet browsing (and remain idle for most of the time), you can add more clients to your network as not all the systems consume network resources at the same time.
Hope it helps! Good Luck!
CreativeTECH
Apr 01, 2011 | Belkin N1 Vision Wireless Router
My router keeps dropping
In your routers settings, generally under DHCP, there is a client lease time setting that will sometimes make the router disconnect the computer. Go into your router's admin page, generally by opening your web browser and typing in the IP address of your router. Many routers don't have a password in place to access the admin page, however, some use username and password as 'admin', or username 'admin' and password is left blank.
Check this client lease setting, this has been the problem with other persons I have helped with the same problem.
Let me know if you have any other questions. If so, please remember to include the model and sub model (if one exists) of your router.
If you found this answer helpful, please remember to leave positive feedback.
Thank You,
Brian
Feb 27, 2011 | D-Link DIR-600 Router
I have a US Robotics usr5461 wireless router. It
You might want to check your firmware version to make sure you have the lastest.
BETA Firmware Version 3.93.35.0.9This firmware fixes the following issues:
  • Printing issues with CUPS version 1.2.
USR5461a-v4.3.93.35.09.usr 1.8 MB 06-05-08
Firmware Version 3.93.35.0.8This firmware fixes the following issues:
  • DST (Daylight Saving time) Firewall issue with how IAC (Internet Access Control) works.
  • PPPoE server disconnect/reconnect
  • PPPoE inactivity timer
  • PPTP client disconnect/reconnect
  • backup/restore settings
Note: If upgrading from Version 3.91.37.0.3, follow these instructions before proceeding.
  1. With a thin tool, such as a paper clip, briefly press the RESET button on the back of the router.
  2. Wait about 30 seconds.
  3. Continue with instructions below.
Important: To ensure a successful upgrade, please perform the firmware upgrade from a client that is physically wired to the router. A wireless client may become disassociated from the router during the upgrade process resulting in an incomplete upgrade.
  1. Download this file to a temporary location on your computer's hard disk drive.
  2. To upgrade your USRobotics Wireless MAXg Router with all operating systems, open an Internet browser and enter the router's IP address. The default IP address of the router is 192.168.2.1
  3. Enter your User name and Password. Click OK.
  4. Click Device in the main menu.
  5. Under the "Upgrade Router" section, enter the location of the USR5461-v3.93.35.0.8.usr file in the text box, or click the Browse button to search for the file. Then click the Upgrade button to begin the upgrade process.
  6. When the upgrade process is complete, the router will reboot. To re-establish a connection with your router, wait approximately 15 seconds and click Continue.
USR5461-v3.93.35.0.8.usr 1.8 MB 10-25-06
Dec 31, 2009 | U.S. Robotics USRobotics USR5461 Wireless...
The router now has 6-8 computers on it at a time, and it seems to be crashing. Is it because there are too many computers on the router?
Generally a Router can handle 254 System/Computer at a time.
Try Rebooting and then Re-configuring the Router if the issue persists after rebooting the Router.
Jul 29, 2009 | D-Link AirPlus DI-614+ Wireless Router
Dial up?
Technically no, not unless the PC where the modem is connected to is used as a Gateway/Share Internet Connection and is connected to the WAN side of the router. However, this arrangement would need a lot of manual configuration and settings on the modem side PC as well as the client PCs.
Alternately, you may be better off connecting the modem PC to a hub rather than a router and set static IP adds on the client PCs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 24, 2008 | Netopia ADSL2+ 11G WIIRELESS ROUTER 400MW...
Belkin wireless set up
Hi, As you ave the modem in bridge mode and also it works ine with wired connection just follow the instruction below for wireless
1.Login in to the router - > wireless settings
2.Configure your wireless using SSID and WEP and save settings
3.Laptop : Using windows wireless client configure the client using the same SSID ,WEP as configured in the router(view available wireless network in wireless properties)
(by default OEM wirelesss client takes over the wireless configuration in branded pc.to disable it and use windows wireless client..control panel ->administrative tools -> services -> enabl2 wireless zero configuration)
14.after all configuration shut the desktop,laptop,router,mdm and pwr them in seq..first modem and then router and then your desktop or laptop
Cheers !!!
Feb 24, 2008 | Belkin (F5D7231-4) Wireless Router
Moto Surfboard SBG900 and VPN Client = SLOW
Please see the specicification, also check with you company
IT Admin, to release it to the Max speed or to check the
net work cable, may be too long, also Test the cable with a Data Test meter and conform the data quality. Or change the port from main router.
Otherwise change the whole networking router.
Regards
Nov 15, 2007 | Arris SURFboard SBG900 (49402201900) Modem
Why won´t my FTP Client work with my D-Link router?
Make sure your FTP client software is set to passive. For security reasons the D-Link router does not deal with an active FTP client. An active FTP client can allow a hacker masquerading as an FTP server to gain access to your computer. Please contact your FTP client software manufacturer to determine how to configure the client for passive rather than active. Note: You will not be able to use an active connection through most NAT routers.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Computers & Internet Logo
588 people viewed this question
David Payne
David Payne
