Question about Panasonic Lumix DMC-TZ3 Digital Camera
The shutter wont open and close, it seems to be stuck?
    Brigadier General:
  • 3,006 Answers
Do you mean the shutter or do you mean the lens cover?
If you mean the lens cover then you have a lens error. This is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact Panasonic's service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you.
If you really did mean the shutter, then this is not user-serviceable in any way and the only fix is to either send the camera to Panasonic for repair or to replace the camera.
Posted on Oct 02, 2010
3 Suggested Answers
virtualhost
  • 2185 Answers
SOURCE: My Ricoh R7, the shutter is jammed and wont close
If you are sure that your battery if fully charged but still does not do any good, then do this little trick:
1. Hold the camera on your right hand with the lens facing the ground.
2. As you press the power on button, tap or hit the camera's base to your left palm. Do this several times.
Chances are, there could be a sand or granule of dust that got stuck on the sides of the lens, preventing it to retract properly.
Hope this helps.
Posted on Nov 03, 2009
  • 291 Answers
SOURCE: The shutter is stuck closed. Why and how do I
This is not something you can easily fix yourself. The entire lens unit needs to come out, in order to realign or replace the shutter blades. Try PhotoTech Repair in NYC. They are Nikon authorized repair facility, and usually complete repairs within the week.
here is the website, you can easily ship it to them.
www.phototech.com
Posted on Mar 30, 2010
All outside pictures come out very white. Inside seems to be okay. Have tried 'reset' but still no good.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 04, 2011 | Casio Exilim EX-S600 Digital Camera
It seems as if my lens is not working. I getting a black screen when I change to shoot mode.
Mar 21, 2011 | Canon PowerShot S3 IS Digital Camera
My s2is powershot camera works fine but it seems the lens will not open there is nothing in the view finder, it takes picture but it is black
Dec 18, 2010 | Canon PowerShot S2 IS Digital Camera
I have lines on the picture. Would you know if
By the way, if you confirm that it is a stuck shutter from the article, recommend the pencil tapping method of step 5a for your particular problem (seems like you may have shutter stuck "open").
Jul 09, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Shutter appears to be stuck closed.
Theirs oil on the shutter blades causing it to stay closed, Thats why you can't see though the lens or the viewfinder also, This comes from the grease from the zoom assy, It's a major job to fix it, Has to be fixed by a repair shop
Jun 04, 2010 | Canon PowerShot S3 IS Digital Camera
A 620 canon camera iris does not open, photos seem
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 23, 2010 | Canon PowerShot A620 Digital Camera
The shutter will not open.
i have a canon zr60a all seems to work fine but it seems to have the shutter closed and ive tried everything .can anyone please help i bought it from a lady needing to pay a bill wonted to help but seems she stuck it to me ....lol now im the one needs help thanks chaz114@hotmail.com
Nov 16, 2009 | Canon ZR70MC Mini DV Digital Camcorder
Stopped focusing properly. Now get only black when looking through view finder or on screen. other features seem to be working correctly
A stuck shutter is a common failure mode for some model digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Nov 13, 2009 | Canon PowerShot S2 IS Digital Camera
Seems to be o.k. with sounds and menu screens,but no image of pic shows in viewer,and no image is recorded when transferred to computer
Oct 22, 2009 | Canon PowerShot A530 Digital Camera
The LCD screen has gone blank...the other features seem to be fine...but can't click pictures any more...they appear black..
Jul 24, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Panasonic Lumix DMC-TZ3 Digital Camera Logo
488 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
