Question about Cycling
How do you remove & fit new tubless tyre using double sided adhesive tapes (road bicycle)
  • 4,924 Answers
How to attach loose scanner glass
The glass plate in scanners is almost always held in by some kind of 2 sided adhesive tape AND plastic clips. Th adhesive probably failed, but the glass plate is probably at an angle and not resting on the plastic clips correctly. These act as a failsafe in this very situation, so the glass plate doesn't break or damage the scanner guts.
Anyway, if you want a permanent repair, this is the tape you should use: Amazon com 3M Scotch Heavy Duty Mounting Tape Clear 4010 Double Sided...
It will definitely support the weight of the glass and then some. Be careful with this stuff, it will remove paint (or worse) from drywall. You should only need 4 strips, one for each edge of the glass. Apply it firmly to the glass, then stick the glass onto the plastic bracket.
Apr 13, 2014 | Epson Perfection 1240U Flatbed Scanner
Tip
Emergency bicycle TYRE repair
If you are considering going on a long bike trip and don't want to carry a spare tyre here is the alternative . If you are on the road far from anywhere and your tyre bulges and splits and blows the tube with a bang then you may need this . I used this technique when I was 100km from civilization . Get a PET plastic bottle -you may find these on the side of the road . As the PET plastic can take pressure it is an ideal candidate for emergency repair . If you don't have a knife to cut it use broken glass on the road or use your bike's cable to cut it (slow). Cut the piece to fit inside,try to avoid jagged edges . It's ok to curl the pet plastic around the tube and insert in tyre -make sure that is is larger than the hole . Fit tyre to rim -be careful to seat it properly around mend ,then pump slowly and constantly check to make sure tyre is seated . Be careful when you ride as this is ONLY an emergency repair but it sure beats walking 100km in the heat. Also make sure your brake blocks aren't rubbing near the repair -ti will bulge some -don't inflate to full pressure -just enough to be usable . I used this trick to get me home from Brookton to Perth Western Australia on fully loaded touring bike .
on Mar 02, 2010 | Cycling
How do you remove a flat tire
Thetyres are normallt tubless, with the air let out you need to push the side wall into the centre of the hub to brake the seal between the hub and the tyre, place it on the ground and stand on the side wall until it brakes away, once the seal is broken a good pair of tyre levers will lever the tyre from the rim.
Jul 02, 2012 | Garden
What size inner tubes fit a Mongoose 29' road bike and which brand is best?
29ER INNER TUBES WILL SUIT FOR YOUR BIKE AND COMING TO THE BRAND New Michelin Tyres, SIEMENS / GE CT Scan Tube ARE GOOD IN PRESENT MARKET.
Parts For Porsche Panamera
Jun 15, 2012 | Cycling
How do I remove tyres from trims to fit new tyres?
Good Afternoon
Deflate to make it easier and use two spoons, the same as you would when changing a tyre on a bicycle. If you get stuck, ask your retailer for help or ask at a bicycle repair store.
Jun 07, 2011 | Quinny Buzz Three Wheel Stroller
Won`t stick to the dash
Did you clean the area with rubbing Alcohol? If not do that, any dirt or plastic protection chemicals like Armorall will not allow the adhesive pad to stick. If the pad is now useless remove it and use 3M double side adhesive tape in it place.
May 04, 2011 | Garmin GPS
Can i change my pulsar 150 2003 to alloy wheels with tubles tyre and what is the advantage after changing this
That sounds like a lot of work and expense, if alloy wheels are available. Unless you have some alloy wheels of another bike and the axles, sprocket and brakes are compatible.
There is no real advantage, apart from tubless tyres can sometimes have punctures repaired without removing the tyres from the rims.
If punctures are a worry, then fit heavy duty inner tubes, which will last for years
Feb 25, 2011 | Bajaj Pulsar 150 Motorcycles
Can you please provide me a list of all major bike types?
I have listed the most famous bike types: BMX Bicycle
Bicycle Moto Cross (BMX) bicycles are designed for rough off road riding and are typically single speed. People also use them for stunt riding, and you may see some fitted with stunt pegs.
Mountain Bike (MTB)
A mountain bike is designed for trail riding and downhill riding. It can also be ridden on the road. They come in many shapes and forms. Some have no suspension, whilst others have front and rear suspension. A mountain bike without rear suspension is usually called a hard tail bike.
Most MTBs use 26 inch wheels which is the standard. This size wheel is fairly strong, especially when coupled with the large off road tyres that are fitted to MTBs.
An MTB is suited for off road riding and will handle rough terrain quite easy. It is very stable on rough terrain, but is a lot slower to ride on the road when compared to a road bike. It is also suitably geared for climbing hills.
Hybrid Bicycle
Another style of bike that has a similar riding position to a mountain bike, but better road speed is a Hybrid bicycle. Hybrids are a cross between a mountain bike and a road bike. They have an upright comfortable position, road tyres, and are usually a lot lighter than a mountain bike.
Hybrid bicycles are typically used for commuting.
Touring Bicycle
A touring bicycle is designed for loaded cycle touring and has the capability to be fitted with mudguards, racks, panniers and extra water cages. They are typically fitted with wider road type tyres that are suitable for gravel riding also.
They usually come with a stronger frame and longer chainstays so that the back of your feet don't hit the rear panniers. They are usually fitted with a relaxed drop bar style handlebar. The geometry of the frame is also different and allows for much more easier steering and handling when loaded.
Expedition Bicycle
As above for touring, but usually fitted with Trekking bars and MTB gear and is designed for extreme off road conditions.
Randonneur or 'All Rounder'
A rare beast in Australia where we like to specialise. 'Randonneur' is a French term, coined to describe a bike that can do a bit of everything - you can ride with the pack or take a doddle with the kids, you can ride light or carry a load, you'd use it to visit Gran on Sunday then pick up some groceries on the way home. They are the 'family station wagon' of cycling. However, like any Jack of All Trades, they do everything well but the specialists do it better. They can carry a load but not like a heavy tourer. They are fast but heavier than a racer and with more comfortable geometry. They have wider wheels and tyres to ride on rough roads but wont handle true off road work.
Typically, they look like any other racing or flat bar road bike ... until you look at the details. Most randonneurs start life as a touring bike or hybrid, and are then modified by the owner over time to reflect how they are used.
Dec 21, 2010 | Cycling
Just assembled the road machine. Wheel is squeeking - should I tighten or loosen?
May be the tyre is too tightly snugged up against the roller, i had this prob before, it is recommended that you use a roller tyre, you can buy them on chainreactioncycles.com
Jan 22, 2010 | Limited Kinetic By Kurt Edition Road...
What size tire tube goes in a 700x28c Denali Bike tire? I installed a schwinn 26inch tube, rode the bike around the block, parked it in the garage and two hours latter, sitting in the garage, the tube blew...
700c tyres are bigger than 26".The tubes you need measure 700x28 (to32).This size is used in Hybrid style bikes.Make sure you get the same type of valve(Schreader are the same as car,Presta are narrower)or it won't fit the hole in your rim.
Make sure when inflating that the tube isn't trapped between the tyre and the rim.Only inflate to the pressure written on the sidewall of the tyre.
Sep 25, 2009 | GMC Denali 700cc Women's Road Bicycle
Cycling Logo
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
