Question about Lowrance Boating
.i'm installing a lowrance mds-8 radar that I
4 Suggested Answers
SOURCE: Lowrance LCX 28c HD with Navionics HotMaps Premium SD chip. Chip worked fine last fall but when I went to use yesterday the Lowrance would not read the chip.
I had the same problem with my handheld Lowrance Hunt C. After installing the card and locking it in place, I had to slide the card "out" toward the locking mechanism. It barely moves, but worked after that. Whenever I load the card, I now slide it out or wiggle it and it works every time.
Posted on May 12, 2009
fishdoctorfi
  • 178 Answers
SOURCE: Can I use my existing transducer(1000 watt tilted
As long as the connection is the same.....maybe. The difference will be the angle of beam from boat to bottom. May not cover the same area...or you could loose zoom etc. something will be different.
Posted on Dec 27, 2009
Editor925
  • 285 Answers
SOURCE: How does my Lowrance HDS-5
To connect a LRA 2400 to a Lowrance HDS-5 sounder/chartplotter, you can run an ethernet RJ45 cable from your Radar Processing box to the HDS-5 unit. You will need an adaptor cable for the RJ 45 cable to hook into the HDS-5 head unit. This is part no 000-0127-56.
As for the different transducer pinouts, I am not sure what transducer you have now so I cannot say if there is any kind of converter plug available, however, the HDS-5 units do seem to run best using the transducers that are made for them. Your best option may be to buy the transducer that is made for them, and this will directly connect to the display unit.
Hope that helps!
Posted on Mar 11, 2011
Lowrance lcx-111c hd, single beam transducer
Hey Tingo,
I have two 113's,, the problem sounds like the transducer is going bad,, Try this.. unplug all your connections,, replug them and see if it helps...
Don't get me started on $$$ updates....
May 15, 2017 | Lowrance Lcx 112c 10.4" Screen Color Gps...
Radar option
No it will NOT operate radar.
Feb 24, 2010 | Lowrance LCX-27C GPS Receiver
Can I use my existing transducer(1000 watt tilted angle low profile Airemar) which is being used on a Lowrance LCX 113C HD on the new Lowrance HDS 10 50/200 machine?
Dec 26, 2009 | Lowrance Boating
The unit cant find its location
I went to lowrance at self service tab, went though the steps, then called them with the results. They sold me and sending a new gps module.
Thanks Tom
Nov 23, 2009 | Lowrance LCX-111C GPS Receiver
Trying to figure out how to start up my fuel guage on my Lowrance
You need to purchase a EP 60 fuel flow meter. Once you have it installed in your boat, you need to monitor it. You set it up under NMEA DEVICES on your setup menu,
Jun 18, 2009 | Lowrance Lcx 28c Hd 7" Gps Fish Finder...
Apr 20, 2009 | Lowrance Lcx 28c Hd 7" Gps Fish Finder...
Lowrance LCX-15MT Ihave used this unit as a echo sounder from new just purchased LGC 12w arial to use GPS as well but keeps coming up(GPS module not responding)
Go to lowrance's website and run through their set up tutorial / instructions for the unit, there is also a software upgrade you can do online for the unit.
Sep 09, 2008 | Lowrance GPS
Lowrance LCX-19C GPS Receiver Problem
It sounds like you may have to send it out for service, but before you you do there are a few things you can try.
Low voltage can cause erratic behavior. Since you already wired directly to the battery, check the plug for corrosion.
Try unplugging the transducer cable to see if the display still behaves erratically. You wont see depth readings but you should still see the screen going black. If no erratic behavior with transducer unplugged then problem is in the transducer cable or the plug. A common source of failure is at the plug because the added stress of plugging and unplugging cables can cause the socket to twist slightly which can cause a short.
Make sure you have the latest software update.
How to see if your LCX-19C is already using version 1.8.0 software:
  1. Press the MENU button twice on your LCX-19C.
  2. Select SYSTEM SETUP.
  3. Select SOFTWARE INFORMATION.
  4. The software version for your unit is located under the line that says "LCX-19C" (ex. "Version 1.8.0").
  5. If your version is the same version listed above, there is no need to download the software.
If it is lower than 1.8.0 you can download the update from this link: LCX-19C UPDATE
Copy it onto a blank MMC card and install it in your GPS. The GPS should prompt you on how to install the update.
If you need to send the unit in for service click this link: LOWRANCE SERVICE
Mar 15, 2008 | Lowrance LCX-19C GPS Receiver
Boating Logo
164 people viewed this question
Top Lowrance Boating Experts
Phil Walker
Phil Walker
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
