Have 3 phase mr slim 36000 unit single phase power can I buy a inverter to make work?
  • 4 Answers
No, a 3 phase equipment cannot be used on single phase power supply.
Posted on Oct 02, 2010
Can i get a 200v invertor to run a 3-phase sewing machine at home
You will have to check with an electrical whole shop (business) but I doubt it as there are 3 different phases in three phase each one needing its own inverter
It would possibly be cheaper to get a single phase motor to replace the 3 phase unit or enquire from your power utility , the possibility of having 3 phase connected to the premises.
Jun 16, 2015 | Sewing Machines
Digital inverter generator has no 240 volt output
Most power inverters are strictly single-phase. Meaning true 120V or 240V, and no splitting or duplication. It sounds as if your inverter is a single phase 120V, and likely is not stackable on the AC side.
I recommend looking for a Low Frequency Split Phase power Inverter if you want both 240 and 110 volts.
Aug 09, 2013 | Vacuums
We had a Delta vfd037b23a running a fan (we only use it to change the speed) and it was 3 phase input and only drawing 7.5 amps (max is 17). We have moved and no longer have 3 phase line power, we do have...
To cut down on power usage, look into either purchasing or trading for a smaller three phase inverter.
Or the best choice for you is to get a VFD that runs off either single or three phase so that you can move it about at will (to single or three phase set ups).
As for hurting the VFD by using it in the overpowered but underused mode, not likely.
Oct 29, 2012 | Delta Vfd037b23a Ac Drive Vfd B Inverter...
Mr. silm 42000 btu air conditioner in door working outdoornot working
mr. slim air conditioner good brand. wall type or casset type (Roof model)?..
1) may be your control processing unit (PCB) damage.
2) Refrigerant gas leaking. low pressure switch off.
3) Compressor not working properly.
4) This is 3 phase model may be Ac power not correct.
my opinion call Service person.
Mar 22, 2011 | Mitsubishi Heating & Cooling
P8 showing on air cond and air con is not working
P8-Abnormality in outdoor unit.
Solution:
1) Check the indoor/outdoor connecting wire in proper point.
2) Change the connection of electric wiring, if reversed phase.
3) Check the protection device, if malfunction, replace it.
4) Measure the resistance of the outdoor coil thermistor.
If the resistance is normal, replace the
outdoor controller board
Thanks.
Feb 05, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
I have a miller cp 300. It is wired for 3 phase power. I need to hook it up to 230 volt power. How do I do this correctly.
You cannot do this... 3 phase and single phase cannot be inter used... see 3 phase is 440 V AC, single phase is 230 Vots AC. This is unless the unit has Dual capability, in this case the wiring could only be wired to a Single Phase. of the unit. You will need a slow blow breaker of the correct rating and also the cable must be similarly CURRENT rated. If it IS only 3 phase, you can purchase after market single phase to 3 phase converters, that will allow you to plug the 3 phase into a single phase circuit and work, they quite costly though.
Mar 22, 2010 | Welding Tools
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
