Question about Home
Hi, shower keeps going hot an cold - Home
    Problem Solver:
  • 10 Answers
Are any other people running water at the same time?or do you have enough hot water stored?
Posted on Oct 17, 2010
Mira 88 manual mixer not supplying hot water.
You need a new cartridge for the shower located behind the handle.
Jan 26, 2014 | Home
Moen single handled shower the hot water turns cooler then cold after a minute
Your whole house is likely plumbed wrong so that it is impossible to have equal pressures of both hot and cold at your shower. If you had your home plumbed with aquapex using a radiator for the hot water and a radiator for the cold water and have the radiators fed with a 1 inch line you can have close to perfect pressures.
Nov 15, 2013 | Moen Home
Hi, we have recently purchaed a new triton alicante shower only to find that it constantly alternates from hot to cold. the alteration is too frequent to be enjoy a shower since it wll go hot then 20odd...
try taking the handle off and moving just the stem till the right side has all cold and left side is all hot..this mite adjust the stem
Nov 22, 2010 | Home
Just had a single handle shower faucet installed in my new walk-out developed basement and it seems there is a control on it I want to remove. I can't get the handle to go beyond mid-point and I want more...
Hi im Rossouw
The rest of ur house water in the showers fine?
If not they must install a prv (Presure reducing velve) on the cold going to the house and geyser befor it t,s of to the house and even if the rest of the house water is fine u must ask ur plumber who intalled it if he took the cold water going to the new shower strait of the mains if so he must corect it by t-ing in at the right cold water supply or put a velve on the cold water to ruduse the cold presure . then u will have more hot presure and that means lovely hot shower
plz vote and rate my advice thanx
Jul 17, 2010 | Delta & Single Handle Shower Faucet
My shower temperature is unstable , keeps going hot and clod
I think you posted in the wrong area, but, you might need to replace the mixer valve in the controls of the shower, this is what controls the temp while it's running, they get old and need to be replaced every so often. I don't know how your shower is set up, or what brand it is, but it's easier to do if you only have one control knob (one controls both hot & cold), than if you have two seperate(one for hot, one for cold).
Sep 28, 2009 | Aquatronics AMS602WR Coaxial Car Speaker
My thermostatic concealed shower valve only gives either boiling hot water or cold water, there is no inbetween temperature? the cold is fed from mains and the hot from a combi boiler. the plumber has said...
If the hot and cold are fitted the wrong way round then the thermostat on the shower unit cannot operate properly!
Most thermostatic mixer showers have a 'bi-metallic' thermostat, if you supply the hot to the cold and vice versa IT WILL NOT WORK.
It is like wearing the left shoe on the right foot and the right on the left! It doesn't work.
Re-install the hot and cold to the correct supply, and this will sort it.
I hope this helps.
Jul 07, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
I have exactly the same problem
you need to change the cartridge, it is a temp control and is going bad so it keeps you from burning yourself it is like a mixing valve and is givng more cold water, that way you don;t get burned,,
Jun 18, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Shower goes hot and cold
If you are having trouble only at the one fixture (shower), and no where else, the problem is most likely in the shower valve...which either needs new cartridges, or a complete replacement.
hope this helps
Jan 08, 2009 | Home
Cold water suply filling up header tank in loft thru hot water suply on shower.
hi did you run a seperate cold water supply from the storage tank to the shower pump & also a seperate hot supply from the hot water cylinder, it sounds as though the cold water is crossing into the hot service & pushing its way up to the tank as its the only way it can go, sounds as though the cold water connection to the shower is not tank fed & possibly directly off the water main.?
Oct 05, 2008 | Home
Home Logo
148 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
