Question about Westinghouse LTV-32w4 32.02 in. LCD HDTV
32H540S noise problem
Need assistance determining what the root cause is of buzzing noise from new tv. Doesn't happen when muted. But does still happen when the tv speakers are turned off through the audio settings.
  • 1 more comment
  • Anonymous Jun 02, 2008
    When tv is off a high pitch buzzing sound is emitted.If turn on and then back off it stopps for awhile then starts again.
  • us345197 Jun 30, 2008
    I contacted Westinghouse and we worked through some tech suggestions with them. One being to have the backlight all the way up, nothing worked. I returned the TV for the same make and model only to find the same issue. Must be inherent in the design. Oh well. Overall, the picture and audio is great...especially for the price. Just need to ignore the minor buzzing at very low volume settings.
    Thanks for your comment.
  • Linda Meredith
    Linda Meredith Jan 03, 2014
    Mine has started doing the buzzing. When the news was on, the display across bottom for school closings made it buzz louder. Any solutions.
    Problem Solver:
  • 8 Answers
Contact the NY Service Center for Westinghouse. web is www.asnyonine.com
Posted on Jun 30, 2008
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
Dryer no power
Hello Robert, I am happy to assist you!
I understand your dryer is inoperable. First, let's try resetting your appliance. This can be done by either unplugging it or flipping the household circuit breaker off. It is important to wait roughly ten minutes, and then turn your dryer on. If the issue persists, you may either have a communication error from the main control board or timer itself may not be operating correctly. If you noticed minimum blinking or a buzzing noise before shutting off, it could be a faulty power supply or it could possibly have another issue with the door lock assembly. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Best regards!
Chris
Dec 29, 2013 | Frigidaire Electric Dryer
Lg lcd tv buzzing sound
You have problems on the sound portion of your board. It could be a bad solder joint causing it to arc to another component or to ground. It could also be just a plain ole bad Amplifier or something. When you mute it you turn all the voltage off to your AF Amps and naurally the noise will stop. Find the sound board and check it for cold solder joints.
Gillight
Dec 03, 2013 | Televison & Video
Tv making loud buzzing noise
A common cause are failure of decopling capacitors in the audio section, and or the circuit board power distribution that feeds the audio board. Most of the capacitors are surface mount components. The standard fix is to start by changing the circuit boards that have the defective parts.
If the set is under warranty, call for warranty service. Out of warranty service is expensive for these TV sets.
Jerry G.
Jun 12, 2012 | LG 32LG30 32 in. LCD HDTV
A buzzing noise coming from inside the tv but still buzzes when on mute but doesnt buzz when tv guide is up on the screen or when a channel is showing what time it starts
plasma tvs buzz a lot, depending on screen brightness. its probably normal but if you can hear loudly over your volume, may be a bad board or plasma panel. from behind tv, left side = y board, right side = z board, middle = power board ---- bad panel can buzz from anywhere... if you hear all parts buzzing, its probably normal plasma noise
Jun 01, 2010 | Samsung Televison & Video
I have a Samsung rear projection tv. It has been
The Lamp probably is bad but it going bad would not cause a buzzing sound. I have a hunch that the Color Wheel Motor is bad causing the buzzing noise. It is a major repair and the cost would be expensive. But this is the deal, you will need to get a qualified repair person out to confirm the symptom to be sure. You can go ahead and replace the Lamp to get the set working again and use it for as long as you can stand the buzzing noise. If it is the Color Wheel Motor, I would check prices on replacement sets just to get a feel of how much you are willing to spend for repairs.
I hope this helps,
Skyassoc
Oct 28, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Hitachi plasma buzzing noise
sounds like bad audio pcb if buzz comes thru
the speakers,
Aug 19, 2009 | Televison & Video
Constant buzzing noise
is the buzzing happening with the volume off?
Oct 10, 2007 | Maxent MX-42HPM20 42 in. Plasma HDTV
Loud Buzzing Noise
Check filtr capacitor in power unit.
Check filter capacitor on supply to audio amp ic. or Amp ic itself is defective.
Gopali
Apr 23, 2007 | JVC AV-30W475 30" TV
Westinghouse LTV-32w4 32.02 in. LCD HDTV Logo
264 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
