Question about RIM BlackBerry Storm 9530 Smartphone
My phone says reload software 513 on a blackberry storm 9539 and i have tried to load everything threw the app loader, but it wont recognize my phone at all which may be due to windows 7 or the phone could just be a very expensive paper weight now. I tried the local verizon store and honestly they are dumb as rocks when it comes to anything other than sales....they even got rude when i asked about information on the insurance if that tells ya their lack of anything other than sell the product. is there anyway to wipe this phone via usb so i can start over from the app loader?
I tried tto put the password 3 times and it was wrong... the screen is all white now and it says RELOAD SOFTWARE 513 WHAT CAN I DO OR HOW DO I FIX IT I HAVE THE BB 9530
download a program called jl commander ...plug blackberry in and open jl use that to wipe device ..the open desktop manager ( the software that came with the blackberry ) and it should show that you need software and load from there ..if not d'load from blackberry site and us app loader in desktop manager to load it
May 28, 2010 | RIM BlackBerry Storm 9530 Smartphone
How can i reload software 513 on my bberry
All you need to do is sync your blackberry with your blackberry desktop manager and run the application loader. You will lose all data on the phone because you will be re-installing the software.
Mar 03, 2010 | RIM BlackBerry Storm 9530 Smartphone
Blackberry grrrr
First of all, install the Blackberry desktop manager if you haven't already got it installed - then get the device software - start from here, and select your service provider:
http://na.blackberry.com/eng/support/downloads/download_sites.jsp
Once you have downloaded the correct software and installed it on your PC, connect the BB, run the desktop manager and go to "application loader" - select your device (which will probably be identified as something like "USB: PINxxxxxx"), select which components you want to load, and click "OK".
Then make a cup of coffee, since it's a pretty slow process.
Sep 14, 2009 | RIM BlackBerry Storm 9530 Smartphone
Reload software 513 for blackberry storm
I'm not too sure if all your data will still be there. But you can fix this yourself. You should be able to reload the device software with the Blackberry Manager.
Aug 29, 2009 | RIM BlackBerry Storm 9530 Smartphone
Reload Software 513 in Black Berry Bold 9000 series.
Your Blackberry probably just needs a firmware restore. Here's a guide on how to restore the blackberry firmware, the website is at : Restore Blackberry to factory settings. Download the Blackberry Desktop manager and run the application loader.
Aug 22, 2009 | RIM BlackBerry Storm 9530 Smartphone
How to reload software 513?
I have a blackberry curve that drove me crazy because the application loader didnt work with mine either but here is what I tried and it worked for mine so hopefully it will work for yours. First, go to the blackberry.com website and click on software. Then click on device software. Select the version that is compatible with your phone. Be sure that your phone is connected to the computer with the USB cord that is came with. Then click download and follow the instructions from there. This should reload the software on your phone.
Jul 20, 2009 | RIM BlackBerry Storm 9530 Smartphone
How do i reload software 513 for my blackberry storm.
What you need to try to do is reinstall the blackberry OS (operating system) on your device.
Assuming you have verizon
First install Blackberry desktop manager it should be in the CD that came with the phone.
If you can't find it download it https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=5E695511C1F9656B8E3E63DAB060F469
Then download the OS software for your phone http://vzw.smithmicro.com/blackberry/download.aspx?ct=personal"
Install it
Connect your phone to your computer and start Desktop manager
Click on application loader, on update software click start, click ok on USB pin selection.
when you get to the device backup and restore options, click settings and make sure backup options box is unchecked and device data boxes are both checked, click ok, click next, skip the email signup stuffs,and finish.
After the software is installed the phone should boot back up
Jul 13, 2009 | RIM BlackBerry Storm 9530 Smartphone
I got my password wrong on my blackberry storm
This is a security feature in the BlackBerry. It means you have to reload the device software into the BlackBerry via a computer. All data on the phone has been erased. The device software varies depending on the model of the phone and what carrier it is used on.
Jun 28, 2009 | RIM BlackBerry Storm 9530 Smartphone
Reload software 513 error
After typing an incorrect password ten times and restarting the BlackBerry smartphone, the following error appears:JVM 513
All of the data and applications on the BlackBerry smartphone have been deleted and The BlackBerry® Device Software must be reloaded on to the BlackBerry smartphone (Due to the Java Virtual Machine (JVM) error, the BlackBerry smartphone will not show a Connected state in the BlackBerry® Desktop Manager. Proceed to reload the BlackBerry Device Software using the Application Loader)
To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 and 4.6, perform the following steps:
1) Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
2) Double-click Application Loader.
3) Click Add/Remove Applications.
4) Type your BlackBerry smartphone password and click OK.
5) Select the check boxes next to the names of the applications you want to load.
6) Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications.
7) Click OK.
8) Click Next > Finish
9) When the process has completed, the message The loading operation was successful will appear. Click Main Menu to return to BlackBerry Desktop Manager.
Apr 10, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Need to reload software 513 blackberry
the Application error 513, reset message says that the device OS is toasted and needs to be rebuilt. In order to do this, you need to have Blackberry Desktop manager on your computer, your data cable, and a download for your device software. Either from blackberry or your carrier. The easiest method is to download and install the device software. Once it's installed, launch desktop manager and plug in the phone. If the phone is detected, you will be prompted to update. Follow the prompts. If not, you will have to do it the hard way. open command prompt (start>run>cmd) and goto C:\program files\common files\Research in Motion\Apploader Then choose Loader /NOJVM That's going to rebuild the blackberry.
Mar 27, 2009 | RIM BlackBerry Storm 9530 Smartphone
RIM BlackBerry Storm 9530 Smartphone Logo
103 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
