Question about HP Mini Notebook
I just baught a new hp mini 110 netbook and I just tried turning in on and the screen will just come up as a blank black screen. I have tried turning it off and taking out the battery and it still comes up blank. The song even plays but the screen stays blank.
babes_ganda0
  • 381 Answers
SOURCE: hp mini 1000 - no startup display
you got error this windows/OS system so u need to re-install the OS/Windows..good luck and have nice day
Posted on Jun 18, 2009
furlough5
  • 28 Answers
SOURCE: hp mini screen is blank
Hello imlapd. If you don't even see words on the screen when you first turn it on (the BIOS puts things on the screen before it boots to Windows), then there are 2 possible causes. First, the video output or something else on the motherboard is bad. Second, the LCD display (the laptop screen) has failed. The cost to fix either one of these will be close to what the laptop cost brand new if not more. The good news is, if your HP Mini is less than a year old or you got an extended warranty, HP will fix it for free. You just have to call their customer service.
800-HP invent
or
800-474-6836
Be prepared to provide the following information: Serial Number (S/N), product name, model number, and a brief description of the issue.
Posted on Aug 27, 2009
  • 1584 Answers
SOURCE: I have an HP mini 110. Less then 2 weeks old. It
TYake it back to shop and get them to fix it. DO NOTHING TO IT.
Posted on Jan 20, 2010
  • 144 Answers
SOURCE: THE SCREEN OF MY HP MINI 110 IS BLANK
TRY DOING LIKE FN F5 OR THE ONE FOR LCD SCREEN THAT SHOULD FIX IT
Posted on Mar 26, 2010
  • 58 Answers
SOURCE: My hp dv4-1435dx screen is blank.
This could be due to presence of static charges on the notebook or hardware malfunction of the video card or defective LCD display screen of the notebook. To resolve the issue, perform the following steps.
Step 1: Hard Reset
To perform a hard reset, please follow the steps listed below:
1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
2. Remove the battery from the notebook battery compartment.
3. Press and hold down the power button for about 20 seconds.
4. Insert the battery and plug the AC adapter back into the notebook PC.
5. Press the power button to turn the notebook PC back on.
This will discharge the static charges from the notebook. Now check if the display works fine or not. Incase, if the issue persists, then the video card or LCD screen must have gone bad, and to isolate the same, please connect an external monitor to the notebook and check for the display on it. You can follow the steps below to connect an external monitor to the notebook.
1. Turn off the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear/side of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
At this time, please follow the instructions mentioned below for switching the display to the external monitor:
The notebook's video card supports three modes. Built-in screen only; external video only; and both on simultaneously (mirrored). If you're not seeing the image on the desired device(s), the notebook's video card is probably in another mode. Press FN + F4 to cycle through the display options: Notebook display, External monitor, both.
If you press FN + F4 once, the external monitor will display & there will be no Notebook LCD display.
If you press FN + F4 twice, the external monitor will display & there will be some shading on the Notebook LCD.
If you press FN + F4 thrice, both Notebook LCD & external monitor will display.
If the issue persists on the external monitor, then this could be due to defective video card on the notebook. However, if the display on the external monitor is fine, then the issue is with the LCD display panel of the notebook. In either cases, the notebook requires a detailed onsite diagnosis by a service technician.
If your notebook is under HP warranty, then contact HP to get the notebook repaired for free of cost.
Posted on Jun 01, 2010
Testimonial: "Thanks a lot, the turning off and on didnt work so i guess it is one of the other two. dont have an external monitor to plug it to here. Will see a technician, thanks."
I need to reset my Hp netbook mini 110-3130NR to factory settings
you going to your user account profile and then type account name wit h password.
Jan 04, 2013 | HP Mini 110-3130NR 10.1-Inch Netbook Black
Recover windows 7 mini 110 3130nr
take the big battery out first?
if F11 is dead that means, HDD bad, or corrupted.
reload from HP recovery media at HP, we are NOT HP.
it came new with W7 and never changed?
Sep 02, 2017 | HP XH021UA 110-3130nr Mini Netbook PC -...
I can't access windows on my hp mini. I just get a blank screen
Blank as in black?
Do you have power?
Remove any usb devices and then try and start it.
if that doesn't work, disconnect the unit from power and remove the battery. Wait 30 seconds. Put in the battery and power up.
Jan 02, 2011 | HP Mini 1000 Netbook
I have an HP Mini 110. I have turned off the
Try this: Remove Mini from A/C power; remove battery. Hold power button for 10 seconds; reinstall battery & A/C power. Try starting normally. Your netbook doesn't appear to have an external VGA port, or I would suggest trying to connect to an external monitor. Your monitor back-light may be burned out.
Mar 10, 2010 | HP Pavilion ze2000 Notebook
How do I fix a HP mini netbook where I downloaded a worm, now it comes on and goes to a blue/black screen. I've tried everything I know.
Try Safe mode if you haven't already. If you have, the only other option I know (if it's windows) is reloading the operating system. sorry.
Feb 12, 2010 | HP Mini 110-1037NR Netbook
Hp mini 1000 - no startup display
Jun 18, 2009 | HP Mini 1000 Netbook
HP Mini Notebook Logo
152 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
