Question about JVC AV-56WP84 56" Rear Projection Television
2004 jvc 56in projection tv, has sound but no picture
    Genius:
  • 1,456 Answers
Hello
Change the channel to ensure the problem isn't with the current station broadcast. Check the channel at a later time to see if the broadcast problem is resolved.
The type of programming you are trying to watch determines the proper input source. Press the "Input" button on the remote control to change to the proper input source. For example, if the source is a cable or satellite service, press the "Input" button until "TV" mode is selected. A component device, such as a DVD player, will operate on a different input source, such as "Video-1."
Check the coaxial cable, which connects your television broadcast service provider to your television. You need to securely connect the coaxial cable to the "ATSC/Digital Cable In" jack on the back of the television, and the other end to the wall jack. If the cable appears damaged, replace it with a new cable.
If you are using a component device as the source of your programming, ensure the component cables are plugged into the "Video Input" and "Audio Input" jacks on the back of the television or that the S-Video cable is plugged into the "S-Video Input" jack on the back of the television. Connect the other end of the cables to the "Video Output" and "Audio Output" jacks or "S-Video Output" jack on the component device.
Posted on Oct 02, 2010
Samsund rear projection tv
I hate to tell you this but its a good chance its your light engine,if the dots begin to spread over the TV it is the Light engine.
Jun 11, 2009 | Samsung HLN567W 56" Rear Projection HDTV
Jvc 56in. rear projection. wavy lines, double visioned
you need to change converance chips do both STK392-120 you can also use 150
Apr 25, 2009 | JVC AV-56WP74 56" Rear Projection...
Our JVC 56in rear projection tv cut off and when we tried to turn it back on is makes a thumping sound and the blue light on the front blinks and the thumping sound gets louder... Help??
The problem is one of the video drive IC's on the crt boards is bad. These IC's are located behind the front speaker grille. The board connected to the bottom of the crt's will have these ic's on them. They will be screwed into a metal "heatsink" The part number is TDA6111Q
Nov 28, 2008 | JVC AV-56WP74 56" Rear Projection...
No sound on my 52in jvc tv
i unplugged my tv and when i turned it back on had picture but no sound and all cards are still in tack.
Jul 31, 2008 | JVC HD-52G886 52" Rear Projection HDTV
JVC 56in. is broken
id probably get a new model once they are past the 5 year mark its about time for a new one
Jul 22, 2008 | JVC AV-56WP74 56" Rear Projection...
Green is tilted
Put the convergence controls at roughly center and manually adjust the green tube for the best pix. Then, go back and set up your electronic convergence and see what that does for you....accordianman
Feb 24, 2008 | JVC AV-56WP74 56" Rear Projection...
Tv has a brownish green tint to it
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Dec 03, 2007 | JVC AV-56WP30 56" Rear Projection...
No picture on tv screen
When you say no picture, is there any sound or noise coming from rear of set when you try to turn on. If so then you have no high voltage and maybe a cap in the HV line that is bad. If no sound at all, then maybe a fuse or open resistor in powersupply.
Jul 21, 2007 | JVC AV-48WP30 48" Rear Projection...
Jvc tv picture quality
sounds like your crt tubes...meaning Red, Green and Blue are out of alignment...or possibly 1 of the crt's is burned out.
Jan 29, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV-56WP84 56" Rear Projection Television Logo
117 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
easy alberta
easy alberta
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
